root/Development/ray/doc/man/man1/pmblur.1
Revision: 1.3
Committed: Tue Jan 18 03:59:40 2005 UTC (20 years, 11 months ago) by greg
CVS Tags: rad3R8, rad3R7P2, rad3R7P1
1 .\" RCSid "$Id: pmblur.1,v 1.2 2003/12/09 15:59:06 greg Exp $"
2 .TH PMBLUR 1 3/3/98 RADIANCE
3 .SH NAME
4 pmblur - generate views for camera motion blurring
5 .SH SYNOPSIS
6 .B pmblur
7 .B speed
8 .B nsamp
9 .B v0file
10 .B v1file
11 .SH DESCRIPTION
12 .I Pmblur
13 takes two viewfiles and generates
14 .I nsamp
15 views starting from
16 .I v0file
17 and moving towards
18 .I v1file.
19 When rendered and averaged together, these views will result in
20 a picture with motion blur due to a camera changing from v0 to v1
21 in a relative time unit of 1, whose shutter is open starting at v0 for
22 .I speed
23 of these time units.
24 Either
25 .I pinterp(1)
26 or
27 .I rpict(1)
28 may be called to do the actual work.
29 (The given
30 .I v0file
31 must also be passed on the command line to the chosen renderer, since
32 .I pmblur
33 provides supplemental view specifications only.)\0
34 .PP
35 For
36 .I pinterp,
37 feed the output of
38 .I pmblur
39 to the standard input of
40 .I pinterp
41 and apply the
42 .I \-B
43 option to blur views together.
44 In most cases, two pictures with z-buffers at v0 and v1 will
45 get a satisfactory result, though the perfectionist may wish to
46 apply the
47 .I \-ff
48 option together with the
49 .I \-fr
50 option of
51 .I pinterp.
52 .PP
53 To use
54 .I pmblur
55 with
56 .I rpict,
57 apply the
58 .I \-S
59 option to indicate a rendering sequence, and set the
60 .I \-o
61 option with a formatted file name to save multiple output
62 pictures.
63 When all the renderings are finished, combine them with the
64 .I pcomb(1)
65 program, using appropriate scalefactors to achieve an average.
66 Note that using
67 .I rpict
68 is MUCH more expensive than using
69 .I pinterp,
70 and it is only recommended if the scene and application
71 absolutely demand it (e.g. there is prominent refraction that
72 must be modeled accurately).
73 .PP
74 For both
75 .I pinterp
76 and
77 .I rpict,
78 the computation time will be proportional to the number of views from
79 .I pmblur.
80 We have found a
81 .I nsamp
82 setting somewhere between 5 and 10 to be adequate for most images.
83 Relatively larger values are appropriate for faster camera motion.
84 .PP
85 The
86 .I \-pm
87 option of
88 .I rpict
89 may be used instead or in combination to blur animated frames, with
90 the added advantage of blurring reflections and refractions according
91 to their proper motion.
92 However, this option will result in more noise and expense than using
93 .I pmblur
94 with
95 .I pinterp
96 as a post-process.
97 If both blurring methods are used, a smaller value should be given to the
98 .I rpict
99 .I \-pm
100 option equal to the shutter speed divided by the number of pmblur views.
101 This will be just enough to blur the boundaries of the ghosts
102 which may appear using
103 .I pmblur
104 with a small number of time samples.
105 .SH EXAMPLES
106 To use
107 .I pinterp
108 to simulate motion blur between two frames of a walk-through
109 animation, where the camera shutter is open for 1/4 of the
110 interframe distance:
111 .IP "" .2i
112 pmblur .25 8 fr1023.pic fr1024.pic | pinterp -B -vf fr1023.pic -x 640 -y 480
113 fr1023.pic fr1023.zbf fr1024.pic fr1024.zbf > fr1023b.pic
114 .SH AUTHOR
115 Greg Ward
116 .SH BUGS
117 Changes in the view shift and lift vectors or the fore and aft
118 clipping planes are not blurred.
119 .SH "SEE ALSO"
120 pcomb(1), pdfblur(1), pinterp(1), pmdblur(1), rcalc(1), rpict(1), vwright(1)
