| 1 |
.\" RCSid "$Id"
| 2 |
.TH PMBLUR 1 3/3/98 RADIANCE
| 3 |
.SH NAME
| 4 |
pmblur - generate views for camera motion blurring
| 5 |
.SH SYNOPSIS
| 6 |
.B pmblur
| 7 |
.B speed
| 8 |
.B nsamp
| 9 |
.B v0file
| 10 |
.B v1file
| 11 |
.SH DESCRIPTION
| 12 |
.I Pmblur
| 13 |
takes two viewfiles and generates
| 14 |
.I nsamp
| 15 |
views starting from
| 16 |
.I v0file
| 17 |
and moving towards
| 18 |
.I v1file.
| 19 |
When rendered and averaged together, these views will result in
| 20 |
a picture with motion blur due to a camera changing from v0 to v1
| 21 |
in a relative time unit of 1, whose shutter is open starting at v0 for
| 22 |
.I speed
| 23 |
of these time units.
| 24 |
Either
| 25 |
.I pinterp(1)
| 26 |
or
| 27 |
.I rpict(1)
| 28 |
may be called to do the actual work.
| 29 |
(The given
| 30 |
.I v0file
| 31 |
must also be passed on the command line to the chosen renderer, since
| 32 |
.I pmblur
| 33 |
provides supplemental view specifications only.)\0
| 34 |
.PP
| 35 |
For
| 36 |
.I pinterp,
| 37 |
feed the output of
| 38 |
.I pmblur
| 39 |
to the standard input of
| 40 |
.I pinterp
| 41 |
and apply the
| 42 |
.I \-B
| 43 |
option to blur views together.
| 44 |
In most cases, two pictures with z-buffers at v0 and v1 will
| 45 |
get a satisfactory result, though the perfectionist may wish to
| 46 |
apply the
| 47 |
.I \-ff
| 48 |
option together with the
| 49 |
.I \-fr
| 50 |
option of
| 51 |
.I pinterp.
| 52 |
.PP
| 53 |
To use
| 54 |
.I pmblur
| 55 |
with
| 56 |
.I rpict,
| 57 |
apply the
| 58 |
.I \-S
| 59 |
option to indicate a rendering sequence, and set the
| 60 |
.I \-o
| 61 |
option with a formatted file name to save multiple output
| 62 |
pictures.
| 63 |
When all the renderings are finished, combine them with the
| 64 |
.I pcomb(1)
| 65 |
program, using appropriate scalefactors to achieve an average.
| 66 |
Note that using
| 67 |
.I rpict
| 68 |
is MUCH more expensive than using
| 69 |
.I pinterp,
| 70 |
and it is only recommended if the scene and application
| 71 |
absolutely demand it (e.g. there is prominent refraction that
| 72 |
must be modeled accurately).
| 73 |
.PP
| 74 |
For both
| 75 |
.I pinterp
| 76 |
and
| 77 |
.I rpict,
| 78 |
the computation time will be proportional to the number of views from
| 79 |
.I pmblur.
| 80 |
We have found a
| 81 |
.I nsamp
| 82 |
setting somewhere between 5 and 10 to be adequate for most images.
| 83 |
Relatively larger values are appropriate for faster camera motion.
| 84 |
.PP
| 85 |
The
| 86 |
.I \-pm
| 87 |
option of
| 88 |
.I rpict
| 89 |
may be used instead or in combination to blur animated frames, with
| 90 |
the added advantage of blurring reflections and refractions according
| 91 |
to their proper motion.
| 92 |
However, this option will result in more noise and expense than using
| 93 |
.I pmblur
| 94 |
with
| 95 |
.I pinterp
| 96 |
as a post-process.
| 97 |
If both blurring methods are used, a smaller value should be given to the
| 98 |
.I rpict
| 99 |
.I \-pm
| 100 |
option equal to the shutter speed divided by the number of pmblur views.
| 101 |
This will be just enough to blur the boundaries of the ghosts
| 102 |
which may appear using
| 103 |
.I pmblur
| 104 |
with a small number of time samples.
| 105 |
.SH EXAMPLES
| 106 |
To use
| 107 |
.I pinterp
| 108 |
to simulate motion blur between two frames of a walk-through
| 109 |
animation, where the camera shutter is open for 1/4 of the
| 110 |
interframe distance:
| 111 |
.IP "" .2i
| 112 |
pmblur .25 8 fr1023.pic fr1024.pic | pinterp -B -vf fr1023.pic -x 640 -y 480
| 113 |
fr1023.pic fr1023.zbf fr1024.pic fr1024.zbf > fr1023b.pic
| 114 |
.SH AUTHOR
| 115 |
Greg Ward
| 116 |
.SH BUGS
| 117 |
Changes in the view shift and lift vectors or the fore and aft
| 118 |
clipping planes are not blurred.
| 119 |
.SH "SEE ALSO"
| 120 |
pcomb(1), pdfblur(1), pinterp(1), rcalc(1), rpict(1), vwright(1)
