root/radiance/ray/doc/man/man1/pmblur.1
Revision: 1.6
Committed: Fri Oct 5 00:59:38 2012 UTC (12 years, 8 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R2P1, rad5R3, HEAD
# User Rev Content
1 greg 1.6 .\" RCSid "$Id: pmblur.1,v 1.5 2008/11/10 19:08:17 greg Exp $"
2 greg 1.1 .TH PMBLUR 1 3/3/98 RADIANCE
3     .SH NAME
4     pmblur - generate views for camera motion blurring
5     .SH SYNOPSIS
6     .B pmblur
7     .B speed
8     .B nsamp
9     .B v0file
10     .B v1file
11     .SH DESCRIPTION
12     .I Pmblur
13     takes two viewfiles and generates
14     .I nsamp
15     views starting from
16     .I v0file
17     and moving towards
18     .I v1file.
19     When rendered and averaged together, these views will result in
20     a picture with motion blur due to a camera changing from v0 to v1
21     in a relative time unit of 1, whose shutter is open starting at v0 for
22     .I speed
23     of these time units.
24     Either
25     .I pinterp(1)
26     or
27     .I rpict(1)
28     may be called to do the actual work.
29     (The given
30     .I v0file
31     must also be passed on the command line to the chosen renderer, since
32     .I pmblur
33     provides supplemental view specifications only.)\0
34     .PP
35     For
36     .I pinterp,
37     feed the output of
38     .I pmblur
39     to the standard input of
40     .I pinterp
41     and apply the
42     .I \-B
43     option to blur views together.
44     In most cases, two pictures with z-buffers at v0 and v1 will
45     get a satisfactory result, though the perfectionist may wish to
46     apply the
47     .I \-ff
48     option together with the
49     .I \-fr
50     option of
51     .I pinterp.
52     .PP
53     To use
54     .I pmblur
55     with
56     .I rpict,
57     apply the
58     .I \-S
59     option to indicate a rendering sequence, and set the
60     .I \-o
61     option with a formatted file name to save multiple output
62     pictures.
63     When all the renderings are finished, combine them with the
64     .I pcomb(1)
65     program, using appropriate scalefactors to achieve an average.
66     Note that using
67     .I rpict
68     is MUCH more expensive than using
69     .I pinterp,
70     and it is only recommended if the scene and application
71     absolutely demand it (e.g. there is prominent refraction that
72     must be modeled accurately).
73     .PP
74     For both
75     .I pinterp
76     and
77     .I rpict,
78     the computation time will be proportional to the number of views from
79     .I pmblur.
80     We have found a
81     .I nsamp
82     setting somewhere between 5 and 10 to be adequate for most images.
83     Relatively larger values are appropriate for faster camera motion.
84     .PP
85     The
86     .I \-pm
87     option of
88     .I rpict
89     may be used instead or in combination to blur animated frames, with
90     the added advantage of blurring reflections and refractions according
91     to their proper motion.
92     However, this option will result in more noise and expense than using
93     .I pmblur
94     with
95     .I pinterp
96     as a post-process.
97     If both blurring methods are used, a smaller value should be given to the
98     .I rpict
99     .I \-pm
100     option equal to the shutter speed divided by the number of pmblur views.
101     This will be just enough to blur the boundaries of the ghosts
102     which may appear using
103     .I pmblur
104     with a small number of time samples.
105     .SH EXAMPLES
106     To use
107     .I pinterp
108     to simulate motion blur between two frames of a walk-through
109     animation, where the camera shutter is open for 1/4 of the
110     interframe distance:
111     .IP "" .2i
112 greg 1.5 pmblur .25 8 fr1023.hdr fr1024.hdr | pinterp \-B \-vf fr1023.hdr \-x 640 \-y 480
113     fr1023.hdr fr1023.zbf fr1024.hdr fr1024.zbf > fr1023b.hdr
114 greg 1.1 .SH AUTHOR
115     Greg Ward
116     .SH BUGS
117     Changes in the view shift and lift vectors or the fore and aft
118     clipping planes are not blurred.
119     .SH "SEE ALSO"
120 greg 1.6 pcomb(1), pdfblur(1), pinterp(1), pmblur2(1),
121     pmdblur(1), rcalc(1), rpict(1), vwright(1)
