| 1 |
.\" RCSid "$Id: pmapdump.1,v 1.8 2019/08/14 18:03:23 rschregle Exp $"
| 2 |
.TH PMAPDUMP 1 "$Date: 2019/08/14 18:03:23 $ $Revision: 1.8 $" RADIANCE
| 3 |
| 4 |
.SH NAME
| 5 |
pmapdump - generate RADIANCE scene description or point list representing
| 6 |
photon positions and (optionally) flux
| 7 |
| 8 |
.SH SYNOPSIS
| 9 |
pmapdump [\fB-a\fR] [\fB-n\fR \fInum1\fR] [\fB-r\fR \fIradscale1\fR]
| 10 |
[\fB-f\fR | \fB-c\fR \fIrcol1\fR \fIgcol1\fR \fIbcol1\fR]
| 11 |
\fIpmap1\fR
| 12 |
[\fB-a\fR] [\fB-n\fR \fInum2\fR] [\fB-r\fR \fIradscale2\fR]
| 13 |
[\fB-f\fR | \fB-c\fR \fIrcol2\fR \fIgcol2\fR \fIbcol2\fR]
| 14 |
\fIpmap2\fR ...
| 15 |
| 16 |
.SH DESCRIPTION
| 17 |
\fIpmapdump\fR takes one or more photon map files generated with
| 18 |
\fImkpmap(1)\fR as input and, by default, sends a RADIANCE scene description
| 19 |
of their photon distributions to the standard output. Photons are
| 20 |
represented as spheres of material type \fIglow\fR. These can be
| 21 |
visualised with e.g. \fIobjview(1)\fR, \fIrpict(1)\fR, or \fIrvu(1)\fR to
| 22 |
assess the location and local density of photons in relation to the scene
| 23 |
geometry. No additional light sources are necessary, as the spheres
| 24 |
representing the photons are self-luminous.
| 25 |
.PP
| 26 |
Alternatively, photons can also be output as an ASCII point list, where
| 27 |
each line contains a photon's position and colour.
| 28 |
This point list can be imported in a 3D point cloud processor/viewer
| 29 |
to interactively explore the photon map.
| 30 |
.PP
| 31 |
An arbitrary number of photon maps can be specified on the command line and
| 32 |
the respective photon type is determined automagically. Per default, the
| 33 |
different photon types are visualised as colour coded spheres/points
| 34 |
according to the following default schema:
| 35 |
.IP
| 36 |
\fIBlue\fR: global photons
| 37 |
.br
| 38 |
\fICyan\fR: precomputed global photons
| 39 |
.br
| 40 |
\fIRed\fR: caustic photons
| 41 |
.br
| 42 |
\fIGreen\fR: volume photons
| 43 |
.br
| 44 |
\fIMagenta\fR: direct photons
| 45 |
.br
| 46 |
\fIYellow\fR: contribution photons
| 47 |
.PP
| 48 |
These colours can be overridden for individual photon maps with the \fB-c\fR
| 49 |
option (see below). Alternatively, photons can be individually coloured
| 50 |
according to their actual RGB flux with the \fB-f\fR option (see below);
| 51 |
while this makes it difficult to discern photon types, it can be used to
| 52 |
quantitatively analyse colour bleeding effects, for example.
| 53 |
| 54 |
.SH OPTIONS
| 55 |
Options are effective for the photon map file immediately following on the
| 56 |
command line, and are reset to their defaults after completion of each dump.
| 57 |
As such they must be set individually for each photon map.
| 58 |
| 59 |
.IP "\fB-a\fR"
| 60 |
Boolean switch to output photons as a point list in ASCII (text) format
| 61 |
instead of a RADIANCE scene.
| 62 |
Each output line consists of 6 tab-separated floating point values: the
| 63 |
X, Y, Z coordinates of the photon's position, and the R, G, B colour
| 64 |
channels of its flux. These values. notably the flux, are expressed in
| 65 |
scientific notation if necessary to accommodate their high dynamic range.
| 66 |
| 67 |
.IP
| 68 |
As \fIpmapdump\fR groups its options per photon map, this option must be
| 69 |
specified per photon map for consistent output. This prevents erroneously
| 70 |
dumping RADIANCE scene descriptions along with point lists, which will
| 71 |
fail to load in the 3D point cloud processor/viewer.
| 72 |
| 73 |
.IP "\fB-c\fR \fIrcol\fR \fIgcol\fR \fIbcol\fR"
| 74 |
Specifies a custom sphere/point colour for the next photon map. The colour
| 75 |
is specified as an RGB triplet, with each component in the range (0..1].
| 76 |
Without this option, the default colour for the corresponding photon type
| 77 |
is used. This option is mutually exclusive with \fB-f\fR.
| 78 |
| 79 |
.IP "\fB-f\fR"
| 80 |
Boolean switch to colour each sphere/point according to the corresponding
| 81 |
photon's RGB flux instead of a constant colour. The flux is adjusted for
| 82 |
the fraction of dumped photons to maintain the total flux contained in the
| 83 |
dumped photon map. Note that no exposure is applied, and as such the
| 84 |
resulting colours can span several orders of magnitude and may require tone
| 85 |
mapping with \fIpcond(1)\fR for visualisation. This option is mutually
| 86 |
exclusive with \fB-c\fR.
| 87 |
| 88 |
.IP "\fB-n \fInum\fR"
| 89 |
Specifies the number of spheres or points to dump for the next photon map.
| 90 |
The dump is performed by random sampling with \fInum\fR as target count,
| 91 |
hence the number actually output will be approximate. \fINum\fR may be
| 92 |
suffixed by a case-insensitive multiplier for convenience, where
| 93 |
\fIk\fR = 10^3 and \fIm\fR = 10^6, although the latter may lead to problems
| 94 |
when processing the output geometry with \fIoconv(1)\fR. The default number
| 95 |
is 10k.
| 96 |
| 97 |
.IP "\fB-r \fIradscale\fR"
| 98 |
Specifies a relative scale factor \fIradscale\fR for the sphere radius. The
| 99 |
sphere radius is determined automatically from an estimated average distance
| 100 |
between spheres so as to reduce clustering, assuming a uniform distribution.
| 101 |
In cases where the distribution is substantially nonuniform (e.g. highly
| 102 |
localised caustics) the radius can be manually corrected with this option.
| 103 |
The default value is 1.0. This option is ignored for point list output
| 104 |
in conjuction with \fB-a\fR.
| 105 |
| 106 |
.SH NOTES
| 107 |
The RADIANCE scene output may contain many overlapping spheres in areas with
| 108 |
high photon density, particularly in caustics. This results in inefficient
| 109 |
and slow octree generation with \fIoconv(1)\fR. Generally this can be
| 110 |
improved by reducing \fInum\fR and/or \fIradscale\fR.
| 111 |
| 112 |
.SH EXAMPLES
| 113 |
Visualise the distribution of global and caustic photons superimposed
| 114 |
on the scene geometry with 5000 pale red and 10000 pale blue spheres,
| 115 |
respectively:
| 116 |
.IP
| 117 |
pmapdump -n 5k -c 1 0.4 0.4 global.pm -n 10k -c 0.4 0.4 1 caustic.pm |
| 118 |
oconv - scene.rad > scene_pm.oct
| 119 |
.PP
| 120 |
Visualise the caustic photon distribution superimposed on the scene geometry
| 121 |
with 10000 spheres coloured according to the photons' respective RGB flux:
| 122 |
.IP
| 123 |
pmapdump -n 10k -f caustic.pm | oconv - scene.rad > scene_pm.oct
| 124 |
.PP
| 125 |
But Capt. B wants 'em bigger:
| 126 |
.IP
| 127 |
pmapdump -r 4.0 bonzo.pm > bonzo_bigballz.rad
| 128 |
.PP
| 129 |
RADIANCE scene dumps may also be viewed on their own by simply piping the
| 130 |
output of \fIpmapdump\fR directly into \fIobjview(1)\fR (using the default
| 131 |
number of spheres in this example):
| 132 |
.IP
| 133 |
pmapdump zombo.pm | objview
| 134 |
.PP
| 135 |
Instead of a RADIANCE scene, dump photons as a (really long) point list to
| 136 |
an ASCII file for import into a 3D point cloud processor/viewer:
| 137 |
.IP
| 138 |
pmapdump -a -f -n 1m lotsa.pm > lotsa_pointz.txt
| 139 |
| 140 |
.SH AUTHOR
| 141 |
Roland Schregle (roland.schregle@{hslu.ch,gmail.com})
| 142 |
| 143 |
.SH COPYRIGHT
| 144 |
(c) Fraunhofer Institute for Solar Energy Systems,
| 145 |
.br
| 146 |
(c) Lucerne University of Applied Sciences and Arts,
| 147 |
.br
| 148 |
(c) Tokyo University of Science.
| 149 |
| 150 |
.SH ACKNOWLEDGEMENTS
| 151 |
Development of the RADIANCE photon mapping extension was supported by:
| 152 |
| 153 |
.RS
| 154 |
\fIFraunhofer Institute for Solar Energy Systems\fR
| 155 |
funded by
| 156 |
the German Research Foundation (\fIDFG LU204/10-2\fR, "Fassadenintegrierte
| 157 |
Regelsysteme (FARESYS)"),
| 158 |
| 159 |
\fILucerne University of Applied Sciences and Arts\fR
| 160 |
funded by
| 161 |
the Swiss National Science Foundation (\fISNSF 147053\fR, "Daylight redirecting components"),
| 162 |
| 163 |
\fITokyo University of Science\fR
| 164 |
funded by the JSPS Grants-in-Aid for Scientific
| 165 |
Research Programme (\fIKAKENHI JP19KK0115\fR, "Three-dimensional light flow").
| 166 |
.RE
| 167 |
| 168 |
Many thanks also to the many individuals who tested the code and provided
| 169 |
valuable feedback. Special greetz to Don Gregorio, PAB and Capt.\~B!
| 170 |
| 171 |
.SH "SEE ALSO"
| 172 |
mkpmap(1), objview(1), oconv(1), rpict(1), rvu(1),
| 173 |
.br
| 174 |
\fIThe RADIANCE Photon Map Manual\fR,
| 175 |
.br
| 176 |
\fIDevelopment and Integration of the RADIANCE Photon Map Extension:
| 177 |
Technical Report\fR,
| 178 |
.br
| 179 |
\fIThe RADIANCE Out-of-Core Photon Map: Technical Report\fR,
| 180 |
.br
| 181 |
\fIBonzo Daylighting Tool a.k.a. EvilDRC [TM]\fR
| 182 |
