root/radiance/ray/doc/man/man1/pmapdump.1
Revision: 1.6
Committed: Tue Jan 22 18:31:28 2019 UTC (6 years, 4 months ago) by rschregle
Changes since 1.5: +4 -4 lines
Honourable mention of Capt. B. :^)
1 .\" RCSid "$Id: pmapdump.1,v 1.5 2019/01/22 18:29:08 rschregle Exp $"
2 .TH PMAPDUMP 1 "$Date: 2019/01/22 18:29:08 $ $Revision: 1.5 $" RADIANCE
3
4 .SH NAME
5 pmapdump - generate RADIANCE scene description or point list representing
6 photon positions and (optionally) flux
7
8 .SH SYNOPSIS
9 pmapdump [\fB-a\fR] [\fB-n\fR \fInum1\fR] [\fB-r\fR \fIradscale1\fR]
10 [\fB-f\fR | \fB-c\fR \fIrcol1\fR \fIgcol1\fR \fIbcol1\fR]
11 \fIpmap1\fR
12 [\fB-a\fR] [\fB-n\fR \fInum2\fR] [\fB-r\fR \fIradscale2\fR]
13 [\fB-f\fR | \fB-c\fR \fIrcol2\fR \fIgcol2\fR \fIbcol2\fR]
14 \fIpmap2\fR ...
15
16 .SH DESCRIPTION
17 \fIpmapdump\fR takes one or more photon map files generated with
18 \fImkpmap(1)\fR as input and, by default, sends a RADIANCE scene description
19 of their photon distributions to the standard output. Photons are
20 represented as spheres of material type \fIglow\fR. These can be
21 visualised with e.g. \fIobjview(1)\fR, \fIrpict(1)\fR, or \fIrvu(1)\fR to
22 assess the location and local density of photons in relation to the scene
23 geometry. No additional light sources are necessary, as the spheres
24 representing the photons are self-luminous.
25 .PP
26 Alternatively, photons can also be output as an ASCII point list, where
27 each line contains a photon's position and colour.
28 This point list can be imported in a 3D point cloud processor/viewer
29 to interactively explore the photon map.
30 .PP
31 An arbitrary number of photon maps can be specified on the command line and
32 the respective photon type is determined automagically.Per default, the
33 different photon types are visualised as colour coded spheres/points
34 according to the following default schema:
35 .IP
36 \fIBlue\fR: global photons
37 .br
38 \fICyan\fR: precomputed global photons
39 .br
40 \fIRed\fR: caustic photons
41 .br
42 \fIGreen\fR: volume photons
43 .br
44 \fIMagenta\fR: direct photons
45 .br
46 \fIYellow\fR: contribution photons
47 .PP
48 These colours can be overridden for individual photon maps with the \fB-c\fR
49 option (see below). Alternatively, photons can be individually coloured
50 according to their actual RGB flux with the \fB-f\fR option (see below);
51 while this makes it difficult to discern photon types, it can be used to
52 quantitatively analyse colour bleeding effects, for example.
53
54 .SH OPTIONS
55 Options are effective for the photon map file immediately following on the
56 command line, and are reset to their defaults after completion of each dump.
57 As such they may be set individually for each photon map.
58
59 .IP "\fB-a\fR"
60 Boolean switch to output photons as a point list in ASCII (text) format
61 instead of a RADIANCE scene.
62 Each output line consists of 6 tab-separated floating point values: the
63 X, Y, Z coordinates of the photon's position, and the R, G, B colour
64 channels of its flux. These values. notably the flux, may be expressed
65 in scientific notation to accommodate their high dynamic range.
66
67 .IP "\fB-f\fR"
68 Boolean switch to colour each sphere/point according to the corresponding
69 photon's RGB flux instead of a constant colour. Note that no exposure is
70 applied, and as such the resulting colours can span several orders of
71 magnitude and may require tone mapping with \fIpcond(1)\fR for
72 visualisation. This option is mutually exclusive with \fB-c\fR.
73
74 .IP "\fB-c\fR \fIrcol\fR \fIgcol\fR \fIbcol\fR"
75 Specifies a custom sphere/point colour for the next photon map. The colour
76 is specified as an RGB triplet, with each component in the range (0..1].
77 Without this option, the default colour for the corresponding photon type
78 is used. This option is mutually exclusive with \fB-f\fR.
79
80 .IP "\fB-n \fInum\fR"
81 Specifies the number of spheres or points to dump for the next photon map.
82 The dump is performed by random sampling with \fInum\fR as target count,
83 hence the number actually output will be approximate. \fINum\fR may be
84 suffixed by a case-insensitive multiplier for convenience, where
85 \fIk\fR = 10^3 and \fIm\fR = 10^6, although the latter may lead to problems
86 when processing the output geometry with \fIoconv(1)\fR. The default number
87 is 10k.
88
89 .IP "\fB-r \fIradscale\fR"
90 Specifies a relative scale factor \fIradscale\fR for the sphere radius. The
91 sphere radius is determined automatically from an estimated average distance
92 between spheres so as to reduce clustering, assuming a uniform distribution.
93 In cases where the distribution is substantially nonuniform (e.g. highly
94 localised caustics) the radius can be manually corrected with this option.
95 The default value is 1.0. This option is ignored for point list output
96 in conjuction with \fB-a\fR.
97
98 .SH NOTES
99 The RADIANCE scene output may contain many overlapping spheres in areas with
100 high photon density, particularly in caustics. This results in inefficient
101 and slow octree generation with \fIoconv(1)\fR. Generally this can be
102 improved by reducing \fInum\fR and/or \fIradscale\fR.
103
104 .SH EXAMPLES
105 Visualise the distribution of global and caustic photons superimposed
106 on the scene geometry with 5000 pale red and 10000 pale blue spheres,
107 respectively:
108 .IP
109 pmapdump -n 5k -c 1 0.4 0.4 global.pm -n 10k -c 0.4 0.4 1 caustic.pm |
110 oconv - scene.rad > scene_pm.oct
111 .PP
112 Visualise the caustic photon distribution superimposed on the scene geometry
113 with 10000 spheres coloured according to the photons' respective RGB flux:
114 .IP
115 pmapdump -n 10k -f caustic.pm | oconv - scene.rad > scene_pm.oct
116 .PP
117 RADIANCE scene dumps may also be viewed on their own by simply piping the
118 output of \fIpmapdump\fR directly into \fIobjview(1)\fR (using the default
119 number of spheres in this example):
120 .IP
121 pmapdump zombo.pm | objview
122 .PP
123 Dump photons as a (really long) point list to an ASCII file for import in
124 a 3D point cloud viewer:
125 .IP
126 pmapdump -a -f -n 1m lotsa.pm > lotsa-pointz.txt
127 .PP
128 Capt. B wants 'em bigger:
129 .IP
130 pmapdump -r 4.0 bonzo.pm > bigbonzo-pm.rad
131
132 .SH AUTHOR
133 Roland Schregle (roland.schregle@{hslu.ch,gmail.com})
134
135 .SH COPYRIGHT
136 (c) Fraunhofer Institute for Solar Energy Systems, Lucerne University of
137 Applied Sciences and Arts.
138
139 .SH ACKNOWLEDGEMENT
140 Development of the RADIANCE photon mapping extension was sponsored by the
141 German Research Foundation (DFG) and the Swiss National Science Foundation
142 (SNF). Greetz to Capt. B!
143
144 .SH "SEE ALSO"
145 mkpmap(1), objview(1), oconv(1), rpict(1), rvu(1),
146 \fIThe RADIANCE Photon Map Manual\fR,
147 \fIBonzo Daylighting Tool [TM]\fR
148
149
