--- ray/doc/man/man1/pmapdump.1 2018/11/21 19:42:20 1.3 +++ ray/doc/man/man1/pmapdump.1 2019/01/10 18:29:34 1.4 @@ -1,26 +1,30 @@ -.\" RCSid "$Id: pmapdump.1,v 1.3 2018/11/21 19:42:20 rschregle Exp $" -.TH PMAPDUMP 1 "$Date: 2018/11/21 19:42:20 $ $Revision: 1.3 $" RADIANCE +.\" RCSid "$Id: pmapdump.1,v 1.4 2019/01/10 18:29:34 rschregle Exp $" +.TH PMAPDUMP 1 "$Date: 2019/01/10 18:29:34 $ $Revision: 1.4 $" RADIANCE .SH NAME pmapdump - generate RADIANCE scene description of photon map distribution .SH SYNOPSIS pmapdump [\fB-n\fR \fInspheres1\fR] [\fB-r\fR \fIradscale1\fR] -[\fB-c\fR \fIrcol1\fR \fIgcol1\fR \fIbcol1\fR] \fIpmap1\fR -[\fB-n\fR \fInspheres2\fR] [\fB-r\fR \fIradscale2\fR] -[\fB-c\fR \fIrcol2\fR \fIgcol2\fR \fIbcol2\fR] \fIpmap2\fR ... + [\fB-f\fR | \fB-c\fR \fIrcol1\fR \fIgcol1\fR \fIbcol1\fR] \fIpmap1\fR + [\fB-n\fR \fInspheres2\fR] [\fB-r\fR \fIradscale2\fR] + [\fB-f\fR | \fB-c\fR \fIrcol2\fR \fIgcol2\fR \fIbcol2\fR] \fIpmap2\fR + ... .SH DESCRIPTION \fIpmapdump\fR takes one or more photon map files generated with \fImkpmap(1)\fR as input and sends a RADIANCE scene description of their -photon distributions to the standard output. This can be visualised with +photon distributions to the standard output. Photons are represented as +spheres of material type \fIglow\fR. These can be visualised with e.g. \fIobjview(1)\fR, \fIrpict(1)\fR, or \fIrvu(1)\fR to assess the -location and local density of photons in relation to the scene geometry. +location and local density of photons in relation to the scene geometry. No +additional light sources are necessary, as the spheres representing the +photons are self-luminous. .PP An arbitrary number of photon maps can be specified on the command line and -the respective photon type is determined automagically. The different -photon types are visualised as colour coded spheres according to the -following default schema: +the respective photon type is determined automagically. Per default, the +different photon types are visualised as colour coded spheres according to +the following default schema: .IP \fIBlue\fR: global photons .br @@ -35,7 +39,10 @@ following default schema: \fIYellow\fR: contribution photons .PP These colours can be overridden for individual photon maps with the \fB-c\fR -option (see below). +option (see below). Alternatively, photons can be individually coloured +according to their actual RGB flux with the \fB-f\fR option (see below); +while this makes it difficult to discern photon types, it can be used to +quantitatively analyse colour bleeding effects. .SH OPTIONS Options are effective for the photon map file immediately following on the @@ -62,8 +69,15 @@ The default value is 1.0. Specifies a custom sphere colour for the next photon map. The colour is specified as an RGB triplet, with each component in the range (0..1]. Without this option, the default colour for the corresponding photon type -is used. +is used. This option is mutually exclusive with \fB-f\fR. +.IP "\fB-f\fR" +Boolean switch to colour each sphere according to the corresponding photon's +RGB flux instead of a constant colour. Note that the resulting colours can +span several orders of magnitude and may require tone mapping with +\fIpcond(1)\fR for visualisation. This option is mutually exclusive with +\fB-c\fR. + .SH NOTES The output may contain many overlapping spheres in areas with high photon density, particularly in caustics. This results in inefficient and slow @@ -71,16 +85,21 @@ octree generation with \fIoconv(1)\fR. Generally this reducing \fInspheres\fR and/or \fIradscale\fR. .SH EXAMPLES -To visualise the distribution of global and caustic photons superimposed +Visualise the distribution of global and caustic photons superimposed on the scene geometry with 5000 pale red and 10000 pale blue spheres, respectively: .IP pmapdump -n 5k -c 1 0.4 0.4 global.pm -n 10k -c 0.4 0.4 1 caustic.pm | oconv - scene.rad > scene_pmdump.oct .PP -Alternatively, the dump may be viewed on its own by piping the output of -\fIpmapdump\fR directly into \fIobjview(1)\fR (using the default number of -spheres in this example): +Visualise the caustic photon distribution superimposed on the scene geometry +with 10000 spheres coloured according to the photons' respective RGB flux: +.IP +pmapdump -n 10k -f caustic.pm | oconv - scene.rad > scene_pmdump.oct +.PP +Dumps may also be viewed on their own by piping the output of \fIpmapdump\fR +directly into \fIobjview(1)\fR (using the default number of spheres in this +example): .IP pmapdump zombo.pm | objview
