root/Development/ray/doc/man/man1/pmapdump.1
Revision: 1.9
Committed: Fri Aug 7 01:26:20 2020 UTC (5 years, 1 month ago) by rschregle
CVS Tags: rad5R4, rad5R3, rad6R0, HEAD
Changes since 1.8: +37 -12 lines
docs(pmapdump): Updated acknowlegements and copyright.
# User Rev Content
1 rschregle 1.9 .\" RCSid "$Id: pmapdump.1,v 1.8 2019/08/14 18:03:23 rschregle Exp $"
2     .TH PMAPDUMP 1 "$Date: 2019/08/14 18:03:23 $ $Revision: 1.8 $" RADIANCE
3 greg 1.1
4     .SH NAME
5 rschregle 1.5 pmapdump - generate RADIANCE scene description or point list representing
6     photon positions and (optionally) flux
7 greg 1.1
8     .SH SYNOPSIS
9 rschregle 1.5 pmapdump [\fB-a\fR] [\fB-n\fR \fInum1\fR] [\fB-r\fR \fIradscale1\fR]
10     [\fB-f\fR | \fB-c\fR \fIrcol1\fR \fIgcol1\fR \fIbcol1\fR]
11     \fIpmap1\fR
12     [\fB-a\fR] [\fB-n\fR \fInum2\fR] [\fB-r\fR \fIradscale2\fR]
13     [\fB-f\fR | \fB-c\fR \fIrcol2\fR \fIgcol2\fR \fIbcol2\fR]
14     \fIpmap2\fR ...
15 greg 1.1
16     .SH DESCRIPTION
17     \fIpmapdump\fR takes one or more photon map files generated with
18 rschregle 1.5 \fImkpmap(1)\fR as input and, by default, sends a RADIANCE scene description
19     of their photon distributions to the standard output. Photons are
20     represented as spheres of material type \fIglow\fR. These can be
21     visualised with e.g. \fIobjview(1)\fR, \fIrpict(1)\fR, or \fIrvu(1)\fR to
22     assess the location and local density of photons in relation to the scene
23     geometry. No additional light sources are necessary, as the spheres
24     representing the photons are self-luminous.
25     .PP
26     Alternatively, photons can also be output as an ASCII point list, where
27     each line contains a photon's position and colour.
28     This point list can be imported in a 3D point cloud processor/viewer
29     to interactively explore the photon map.
30 greg 1.1 .PP
31     An arbitrary number of photon maps can be specified on the command line and
32 rschregle 1.7 the respective photon type is determined automagically. Per default, the
33 rschregle 1.5 different photon types are visualised as colour coded spheres/points
34     according to the following default schema:
35 greg 1.1 .IP
36     \fIBlue\fR: global photons
37     .br
38     \fICyan\fR: precomputed global photons
39     .br
40     \fIRed\fR: caustic photons
41     .br
42     \fIGreen\fR: volume photons
43     .br
44     \fIMagenta\fR: direct photons
45     .br
46     \fIYellow\fR: contribution photons
47 rschregle 1.2 .PP
48     These colours can be overridden for individual photon maps with the \fB-c\fR
49 rschregle 1.5 option (see below). Alternatively, photons can be individually coloured
50 rschregle 1.4 according to their actual RGB flux with the \fB-f\fR option (see below);
51     while this makes it difficult to discern photon types, it can be used to
52 rschregle 1.5 quantitatively analyse colour bleeding effects, for example.
53 greg 1.1
54     .SH OPTIONS
55     Options are effective for the photon map file immediately following on the
56     command line, and are reset to their defaults after completion of each dump.
57 rschregle 1.7 As such they must be set individually for each photon map.
58 greg 1.1
59 rschregle 1.5 .IP "\fB-a\fR"
60     Boolean switch to output photons as a point list in ASCII (text) format
61     instead of a RADIANCE scene.
62     Each output line consists of 6 tab-separated floating point values: the
63     X, Y, Z coordinates of the photon's position, and the R, G, B colour
64 rschregle 1.7 channels of its flux. These values. notably the flux, are expressed in
65     scientific notation if necessary to accommodate their high dynamic range.
66
67     .IP
68     As \fIpmapdump\fR groups its options per photon map, this option must be
69     specified per photon map for consistent output. This prevents erroneously
70     dumping RADIANCE scene descriptions along with point lists, which will
71 rschregle 1.9 fail to load in the 3D point cloud processor/viewer.
72 rschregle 1.7
73     .IP "\fB-c\fR \fIrcol\fR \fIgcol\fR \fIbcol\fR"
74     Specifies a custom sphere/point colour for the next photon map. The colour
75     is specified as an RGB triplet, with each component in the range (0..1].
76     Without this option, the default colour for the corresponding photon type
77     is used. This option is mutually exclusive with \fB-f\fR.
78 rschregle 1.5
79     .IP "\fB-f\fR"
80 rschregle 1.8 Boolean switch to colour each sphere/point according to the corresponding
81     photon's RGB flux instead of a constant colour. The flux is adjusted for
82     the fraction of dumped photons to maintain the total flux contained in the
83     dumped photon map. Note that no exposure is applied, and as such the
84     resulting colours can span several orders of magnitude and may require tone
85     mapping with \fIpcond(1)\fR for visualisation. This option is mutually
86     exclusive with \fB-c\fR.
87 rschregle 1.5
88     .IP "\fB-n \fInum\fR"
89     Specifies the number of spheres or points to dump for the next photon map.
90     The dump is performed by random sampling with \fInum\fR as target count,
91     hence the number actually output will be approximate. \fINum\fR may be
92     suffixed by a case-insensitive multiplier for convenience, where
93     \fIk\fR = 10^3 and \fIm\fR = 10^6, although the latter may lead to problems
94     when processing the output geometry with \fIoconv(1)\fR. The default number
95     is 10k.
96 greg 1.1
97     .IP "\fB-r \fIradscale\fR"
98     Specifies a relative scale factor \fIradscale\fR for the sphere radius. The
99     sphere radius is determined automatically from an estimated average distance
100     between spheres so as to reduce clustering, assuming a uniform distribution.
101 rschregle 1.5 In cases where the distribution is substantially nonuniform (e.g. highly
102 greg 1.1 localised caustics) the radius can be manually corrected with this option.
103 rschregle 1.5 The default value is 1.0. This option is ignored for point list output
104     in conjuction with \fB-a\fR.
105 rschregle 1.2
106 greg 1.1 .SH NOTES
107 rschregle 1.5 The RADIANCE scene output may contain many overlapping spheres in areas with
108     high photon density, particularly in caustics. This results in inefficient
109     and slow octree generation with \fIoconv(1)\fR. Generally this can be
110     improved by reducing \fInum\fR and/or \fIradscale\fR.
111 greg 1.1
112     .SH EXAMPLES
113 rschregle 1.4 Visualise the distribution of global and caustic photons superimposed
114 rschregle 1.2 on the scene geometry with 5000 pale red and 10000 pale blue spheres,
115     respectively:
116 greg 1.1 .IP
117 rschregle 1.2 pmapdump -n 5k -c 1 0.4 0.4 global.pm -n 10k -c 0.4 0.4 1 caustic.pm |
118 rschregle 1.5 oconv - scene.rad > scene_pm.oct
119 greg 1.1 .PP
120 rschregle 1.4 Visualise the caustic photon distribution superimposed on the scene geometry
121     with 10000 spheres coloured according to the photons' respective RGB flux:
122     .IP
123 rschregle 1.5 pmapdump -n 10k -f caustic.pm | oconv - scene.rad > scene_pm.oct
124 rschregle 1.4 .PP
125 rschregle 1.7 But Capt. B wants 'em bigger:
126     .IP
127     pmapdump -r 4.0 bonzo.pm > bonzo_bigballz.rad
128     .PP
129 rschregle 1.5 RADIANCE scene dumps may also be viewed on their own by simply piping the
130     output of \fIpmapdump\fR directly into \fIobjview(1)\fR (using the default
131     number of spheres in this example):
132 greg 1.1 .IP
133     pmapdump zombo.pm | objview
134 rschregle 1.5 .PP
135 rschregle 1.7 Instead of a RADIANCE scene, dump photons as a (really long) point list to
136 rschregle 1.9 an ASCII file for import into a 3D point cloud processor/viewer:
137 rschregle 1.5 .IP
138 rschregle 1.7 pmapdump -a -f -n 1m lotsa.pm > lotsa_pointz.txt
139 greg 1.1
140     .SH AUTHOR
141     Roland Schregle (roland.schregle@{hslu.ch,gmail.com})
142
143     .SH COPYRIGHT
144 rschregle 1.9 (c) Fraunhofer Institute for Solar Energy Systems,
145     .br
146     (c) Lucerne University of Applied Sciences and Arts,
147     .br
148     (c) Tokyo University of Science.
149
150     .SH ACKNOWLEDGEMENTS
151     Development of the RADIANCE photon mapping extension was supported by:
152 greg 1.1
153 rschregle 1.9 .RS
154     \fIFraunhofer Institute for Solar Energy Systems\fR
155     funded by
156     the German Research Foundation (\fIDFG LU204/10-2\fR, "Fassadenintegrierte
157     Regelsysteme (FARESYS)"),
158
159     \fILucerne University of Applied Sciences and Arts\fR
160     funded by
161     the Swiss National Science Foundation (\fISNSF 147053\fR, "Daylight redirecting components"),
162
163     \fITokyo University of Science\fR
164     funded by the JSPS Grants-in-Aid for Scientific
165     Research Programme (\fIKAKENHI JP19KK0115\fR, "Three-dimensional light flow").
166     .RE
167
168     Many thanks also to the many individuals who tested the code and provided
169     valuable feedback. Special greetz to Don Gregorio, PAB and Capt.\~B!
170 greg 1.1
171     .SH "SEE ALSO"
172     mkpmap(1), objview(1), oconv(1), rpict(1), rvu(1),
173 rschregle 1.9 .br
174 rschregle 1.5 \fIThe RADIANCE Photon Map Manual\fR,
175 rschregle 1.9 .br
176     \fIDevelopment and Integration of the RADIANCE Photon Map Extension:
177     Technical Report\fR,
178     .br
179     \fIThe RADIANCE Out-of-Core Photon Map: Technical Report\fR,
180     .br
181     \fIBonzo Daylighting Tool a.k.a. EvilDRC [TM]\fR
182 greg 1.1
