root/Development/ray/doc/man/man1/pkgBSDF.1
Revision: 1.3
Committed: Thu Aug 25 15:16:22 2011 UTC (14 years, 4 months ago) by greg
CVS Tags: rad4R2P2, rad4R2P1, rad4R2, rad4R1
Changes since 1.2: +3 -1 lines
Added searching of RAYPATH libraries for input files
# User Rev Content
1 greg 1.3 .\" RCSid $Id: pkgBSDF.1,v 1.2 2011/06/23 18:17:12 greg Exp $
2 greg 1.1 .TH PKGBSDF 1 6/23/2011 RADIANCE
3     .SH NAME
4     pkgBSDF - package BSDFs provided as XML for Radiance
5     .SH SYNOPSIS
6     .B pkgBSDF
7     [
8     .B \-i
9     ][
10     .B \-s
11     ]
12     .B "bsdf.xml .."
13     .SH DESCRIPTION
14     .I PkgBSDF
15     takes one or more XML files, each describing the bidirectional scattering
16     distribution function of a surface or geometric system, and packages
17     them into RADIANCE scene descriptions.
18 greg 1.3 If the input file(s) do not begin with a '.' or '/', the directories
19     in the RAYPATH environment variable will be searched.
20 greg 1.1 One rectangle is produced for each BSDF that has
21     no detail geometry and/or no rear-side reflectance distribution.
22     If both front and back reflectance distributions are present with
23     detail geometry, then two rectangles will be used to sandwich
24     the geometry extracted from the BSDF file.
25 greg 1.2 The front surface will always be centered just in front of the
26     origin facing the positive Z-direction, with "up" in the positive
27     Y-direction.
28     The back surface, if present, will parallel the front surface at
29     a distance slightly greater than the BSDF system thickness.
30     Scene units will always be in meters.
31 greg 1.1 .PP
32     The
33     .I \-i
34     option causes
35     .I pkgBSDF
36     to produce frozen octree instances for any detail geometry,
37     which may reduce memory requirements in scenes with many
38     references to the same complex BSDF object.
39     .PP
40     Normally,
41     .I pkgBSDF
42     produces one RADIANCE scene file for each XML input, replacing
43     the required '.xml' suffix with '.rad' in the same directory.
44     The
45     .I \-s
46     option sends the RADIANCE scene description to the standard
47     output rather than writing it to a file, but only works
48     for a single XML input.
49     Any instance octree is still written out to a file generated
50     by replacing the '.xml' suffix with '.oct' in the same directory.
51     .SH EXAMPLE
52     Package all the XML files in the current directory as Radiance
53     scene files, employing frozen octree instances for any
54     detail geometry:
55     .IP "" .2i
56     pkgBSDF -i *.xml
57     .SH AUTHOR
58     Greg Ward
59     .SH "SEE ALSO"
60     genBSDF(1), oconv(1), xform(1)
