1 |
.\" RCSid "$Id: pinterp.1,v 1.3 2004/01/01 19:31:45 greg Exp $" |
2 |
.TH PINTERP 1 1/24/96 RADIANCE |
3 |
.SH NAME |
4 |
pinterp - interpolate/extrapolate view from pictures |
5 |
.SH SYNOPSIS |
6 |
.B pinterp |
7 |
8 |
view options |
9 |
10 |
.B "\-t threshold" |
11 |
12 |
.B "\-z zout" |
13 |
14 |
.B \-f |
15 |
.I type |
16 |
17 |
.B \-B |
18 |
19 |
.B \-a|q |
20 |
21 |
.B "\-e exposure" |
22 |
23 |
.B \-n |
24 |
25 |
.B "pictfile zspec .." |
26 |
.SH DESCRIPTION |
27 |
.I Pinterp |
28 |
interpolates or extrapolates a new view from |
29 |
one or more RADIANCE pictures and |
30 |
sends the result to the standard output. |
31 |
The input picture files must contain correct view specifications, as |
32 |
maintained by |
33 |
.I rpict(1), |
34 |
.I rvu(1), |
35 |
.I pfilt(1) |
36 |
and |
37 |
.I pinterp. |
38 |
Specifically, |
39 |
.I pinterp |
40 |
will not work on pictures processed by |
41 |
.I pcompos(1) |
42 |
or |
43 |
.I pcomb(1). |
44 |
Each input file must be accompanied by a z specification, which |
45 |
gives the distance to each pixel in the image. |
46 |
If |
47 |
.I zspec |
48 |
is an existing file, it is assumed to contain a short floating point |
49 |
number for each pixel, written in scanline order. |
50 |
This file is usually generated by the |
51 |
.I \-z |
52 |
option of |
53 |
.I rpict(1). |
54 |
If |
55 |
.I zspec |
56 |
is a positive number rather than a file, it will be used as a |
57 |
constant value for the corresponding image. |
58 |
This may be useful for certain transformations on "flat" images or |
59 |
when the viewpoint remains constant. |
60 |
.PP |
61 |
The |
62 |
.I \-n |
63 |
option specifies that input and output |
64 |
z distances are along the view direction, |
65 |
rather than absolute distances to intersection points. |
66 |
This option is usually appropriate with a constant z |
67 |
specification, and should not be used with |
68 |
.I rpict(1) |
69 |
z files. |
70 |
.PP |
71 |
The |
72 |
.I \-z |
73 |
option writes out interpolated z values to the specified file. |
74 |
Normally, this information is thrown away. |
75 |
.PP |
76 |
.I Pinterp |
77 |
rearranges the pixels from the input pictures to produce a |
78 |
reasonable estimate of the desired view. |
79 |
Pixels that map within the |
80 |
.I \-t |
81 |
threshold of each other (.02 times the z distance |
82 |
by default) are considered coincident. |
83 |
With the |
84 |
.I \-a |
85 |
option, image points that coincide will be averaged together, giving |
86 |
a smooth result. |
87 |
The |
88 |
.I \-q |
89 |
option turns averaging off, which means that the first mapped pixel |
90 |
for a given point will be used. |
91 |
This makes the program run faster and |
92 |
take less memory, but at the expense of image quality. |
93 |
By default, two or more pictures are averaged together, and a single |
94 |
picture is treated with the faster algorithm. |
95 |
This may be undesirable when a quick result is desired from multiple |
96 |
input pictures in the first case, or a single picture is being |
97 |
reduced in size (anti-aliased) in the second case. |
98 |
.PP |
99 |
Portions which were hidden or missing in the input pictures must be |
100 |
"filled in" somehow, and a number of methods are provided by the |
101 |
.I \-f |
102 |
option. |
103 |
The default value for this option is |
104 |
.I \-fa, |
105 |
which results in both foreground and background filling. |
106 |
The foreground fill algorithm spreads each input pixel to cover all |
107 |
output pixels within a parallelogram corresponding to that pixel's |
108 |
projection in the new view. |
109 |
Without it, each input pixel contributes to at most one output |
110 |
pixel. |
111 |
The background algorithm fills in those areas in the final picture |
112 |
that have not been filled with foreground pixels. |
113 |
It does this by looking at the boundary surrounding each blank area |
114 |
and picking the |
115 |
farthest pixels to each side, assuming that this will make a suitable |
116 |
background. |
117 |
The |
118 |
.I \-ff |
119 |
option tells the program to use only the foreground fill, the |
120 |
.I \-fb |
121 |
option says use only background fill, and the |
122 |
.I \-f0 |
123 |
option says not to use either fill algorithm. |
124 |
.PP |
125 |
Even when both fill algorithms are used, there may still be some unfilled |
126 |
pixels. |
127 |
By default, these pixels are painted black and assigned a z distance |
128 |
of zero. |
129 |
The |
130 |
.I \-fc |
131 |
option can be used to change the color used for unfilled pixels, and |
132 |
the |
133 |
.I \-fz |
134 |
option can be used to set the z distance (always along the view direction). |
135 |
Alternatively, the |
136 |
.I \-fr |
137 |
option can be used to compute these pixels using |
138 |
.I rtrace(1). |
139 |
The argument to this option is a quoted string containing arguments |
140 |
for |
141 |
.I rtrace. |
142 |
It must contain the octree used to generate the input |
143 |
pictures, along with any other options necessary to match the |
144 |
calculation used for the input pictures. |
145 |
The |
146 |
.I \-fs |
147 |
option can be used to place a limit on the distance (in pixels) over which |
148 |
the background fill algorithm is used. |
149 |
The default value for this option is 0, which is interpreted as no limit. |
150 |
A value of 1 is equivalent to turning background fill off. |
151 |
When combined with the |
152 |
.I \-fr |
153 |
option, this is roughly equivalent to the |
154 |
.I \-ps |
155 |
option of |
156 |
.I rpict(1). |
157 |
.PP |
158 |
In order of increasing quality and cost, one can use the |
159 |
.I \-fa |
160 |
option alone, or the |
161 |
.I \-fr |
162 |
option paired with |
163 |
.I \-fs |
164 |
or |
165 |
.I \-ff |
166 |
or |
167 |
.I \-f0. |
168 |
The last combination will result in the recalculation of all pixels |
169 |
not adequately accounted for in the input pictures, with an |
170 |
associated computational expense. |
171 |
It is rare that the |
172 |
.I \-fs |
173 |
option results in appreciable image degradation, so it is usually |
174 |
the second combination that is used when the background fill |
175 |
algorithm results in objectionable artifacts. |
176 |
.PP |
177 |
The |
178 |
.I \-B |
179 |
option may be used to average multiple views read from the standard |
180 |
input into a single, blurred output picture. |
181 |
This is similar to running |
182 |
.I pinterp |
183 |
multiple times and averaging the output together with a program like |
184 |
.I pcomb(1). |
185 |
This option is useful for simulating motion blur and depth of field. |
186 |
(See |
187 |
.I pmdblur(1).)\0 |
188 |
The input views are reported in the information header of the output |
189 |
file, along with the averaged view. |
190 |
The picture dimensions computed from the first view will be the |
191 |
ones used, regardless whether or not the subsequent views agree. |
192 |
(The reported pixel aspect ratio in the output is determined from |
193 |
these original dimensions and the averaged view.)\0 |
194 |
Note that the expense of the |
195 |
.I \-fr |
196 |
option is proportional to the number of views computed, and the |
197 |
.I \-z |
198 |
output file will be the z-buffer of the last view interpolated |
199 |
rather than an averaged distance map. |
200 |
.PP |
201 |
In general, |
202 |
.I pinterp |
203 |
performs well when the output view is flanked by two nearby input |
204 |
views, such as might occur in a walk-through animation sequence. |
205 |
The algorithms start to break down when there is a large difference |
206 |
between the view desired and the view(s) provided. |
207 |
Specifically, obscured objects may appear to have holes in them and |
208 |
large areas at the image borders may not be filled by the |
209 |
foreground or background algorithms. |
210 |
Also, specular reflections and highlights will not be interpolated |
211 |
very well, since their view-dependent appearance will be |
212 |
incompletely compensated for by the program. |
213 |
(The |
214 |
.I \-a |
215 |
option offers some benefit in this area.)\0 |
216 |
.PP |
217 |
The |
218 |
.I \-e |
219 |
option may be used to adjust the output image exposure, with the |
220 |
same specification given as for |
221 |
.I pfilt. |
222 |
The actual adjustment will be rounded to the nearest integer f-stop |
223 |
if the |
224 |
.I \-q |
225 |
option is in effect (or there is only a single input picture). |
226 |
.SH EXAMPLE |
227 |
To interpolate two frames of a walk-through animation, anti-alias to |
228 |
512x400 and increase the exposure by 2.5 f-stops: |
229 |
.IP "" .2i |
230 |
pinterp -vf 27.vf -a -x 512 -y 400 -e +2.5 30.pic 30.z 20.pic 20.z > 27.pic |
231 |
.PP |
232 |
To extrapolate a second eyepoint for a stereo pair and recalculate |
233 |
background regions: |
234 |
.IP "" .2i |
235 |
pinterp -vf right.vf -ff -fr "-av .1 .1 .1 scene.oct" left.pic left.z > right.pic |
236 |
.SH AUTHOR |
237 |
Greg Ward |
238 |
.SH "SEE ALSO" |
239 |
getinfo(1), pdfblur(1), pfilt(1), pmblur(1), pmdblur(1), rpict(1), |
240 |
ranimate(1), rtrace(1), rvu(1) |
