root/radiance/ray/doc/man/man1/pinterp.1
Revision: 1.7
Committed: Sat Feb 21 00:06:05 2009 UTC (15 years, 4 months ago) by greg
CVS Tags: rad5R2, rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R1, rad4R0, rad4R2P1
Changes since 1.6: +5 -1 lines
Added example for converting view type
1 .\" RCSid "$Id: pinterp.1,v 1.6 2008/11/10 19:08:17 greg Exp $"
2 .TH PINTERP 1 1/24/96 RADIANCE
3 .SH NAME
4 pinterp - interpolate/extrapolate view from pictures
5 .SH SYNOPSIS
6 .B pinterp
7 [
8 view options
9 ][
10 .B "\-t threshold"
11 ][
12 .B "\-z zout"
13 ][
14 .B \-f
15 .I type
16 ][
17 .B \-B
18 ][
19 .B \-a|q
20 ][
21 .B "\-e exposure"
22 ][
23 .B \-n
24 ]
25 .B "pictfile zspec .."
26 .SH DESCRIPTION
27 .I Pinterp
28 interpolates or extrapolates a new view from
29 one or more RADIANCE pictures and
30 sends the result to the standard output.
31 The input picture files must contain correct view specifications, as
32 maintained by
33 .I rpict(1),
34 .I rvu(1),
35 .I pfilt(1)
36 and
37 .I pinterp.
38 Specifically,
39 .I pinterp
40 will not work on pictures processed by
41 .I pcompos(1)
42 or
43 .I pcomb(1).
44 Each input file must be accompanied by a z specification, which
45 gives the distance to each pixel in the image.
46 If
47 .I zspec
48 is an existing file, it is assumed to contain a short floating point
49 number for each pixel, written in scanline order.
50 This file is usually generated by the
51 .I \-z
52 option of
53 .I rpict(1).
54 If
55 .I zspec
56 is a positive number rather than a file, it will be used as a
57 constant value for the corresponding image.
58 This may be useful for certain transformations on "flat" images or
59 when the viewpoint remains constant.
60 .PP
61 The
62 .I \-n
63 option specifies that input and output
64 z distances are along the view direction,
65 rather than absolute distances to intersection points.
66 This option is usually appropriate with a constant z
67 specification, and should not be used with
68 .I rpict(1)
69 z files.
70 .PP
71 The
72 .I \-z
73 option writes out interpolated z values to the specified file.
74 Normally, this information is thrown away.
75 .PP
76 .I Pinterp
77 rearranges the pixels from the input pictures to produce a
78 reasonable estimate of the desired view.
79 Pixels that map within the
80 .I \-t
81 threshold of each other (.02 times the z distance
82 by default) are considered coincident.
83 With the
84 .I \-a
85 option, image points that coincide will be averaged together, giving
86 a smooth result.
87 The
88 .I \-q
89 option turns averaging off, which means that the first mapped pixel
90 for a given point will be used.
91 This makes the program run faster and
92 take less memory, but at the expense of image quality.
93 By default, two or more pictures are averaged together, and a single
94 picture is treated with the faster algorithm.
95 This may be undesirable when a quick result is desired from multiple
96 input pictures in the first case, or a single picture is being
97 reduced in size (anti-aliased) in the second case.
98 .PP
99 Portions which were hidden or missing in the input pictures must be
100 "filled in" somehow, and a number of methods are provided by the
101 .I \-f
102 option.
103 The default value for this option is
104 .I \-fa,
105 which results in both foreground and background filling.
106 The foreground fill algorithm spreads each input pixel to cover all
107 output pixels within a parallelogram corresponding to that pixel's
108 projection in the new view.
109 Without it, each input pixel contributes to at most one output
110 pixel.
111 The background algorithm fills in those areas in the final picture
112 that have not been filled with foreground pixels.
113 It does this by looking at the boundary surrounding each blank area
114 and picking the
115 farthest pixels to each side, assuming that this will make a suitable
116 background.
117 The
118 .I \-ff
119 option tells the program to use only the foreground fill, the
120 .I \-fb
121 option says use only background fill, and the
122 .I \-f0
123 option says not to use either fill algorithm.
124 .PP
125 Even when both fill algorithms are used, there may still be some unfilled
126 pixels.
127 By default, these pixels are painted black and assigned a z distance
128 of zero.
129 The
130 .I \-fc
131 option can be used to change the color used for unfilled pixels, and
132 the
133 .I \-fz
134 option can be used to set the z distance (always along the view direction).
135 Alternatively, the
136 .I \-fr
137 option can be used to compute these pixels using
138 .I rtrace(1).
139 The argument to this option is a quoted string containing arguments
140 for
141 .I rtrace.
142 It must contain the octree used to generate the input
143 pictures, along with any other options necessary to match the
144 calculation used for the input pictures.
145 The
146 .I \-fs
147 option can be used to place a limit on the distance (in pixels) over which
148 the background fill algorithm is used.
149 The default value for this option is 0, which is interpreted as no limit.
150 A value of 1 is equivalent to turning background fill off.
151 When combined with the
152 .I \-fr
153 option, this is roughly equivalent to the
154 .I \-ps
155 option of
156 .I rpict(1).
157 .PP
158 In order of increasing quality and cost, one can use the
159 .I \-fa
160 option alone, or the
161 .I \-fr
162 option paired with
163 .I \-fs
164 or
165 .I \-ff
166 or
167 .I \-f0.
168 The last combination will result in the recalculation of all pixels
169 not adequately accounted for in the input pictures, with an
170 associated computational expense.
171 It is rare that the
172 .I \-fs
173 option results in appreciable image degradation, so it is usually
174 the second combination that is used when the background fill
175 algorithm results in objectionable artifacts.
176 .PP
177 The
178 .I \-B
179 option may be used to average multiple views read from the standard
180 input into a single, blurred output picture.
181 This is similar to running
182 .I pinterp
183 multiple times and averaging the output together with a program like
184 .I pcomb(1).
185 This option is useful for simulating motion blur and depth of field.
186 (See
187 .I pmdblur(1).)\0
188 The input views are reported in the information header of the output
189 file, along with the averaged view.
190 The picture dimensions computed from the first view will be the
191 ones used, regardless whether or not the subsequent views agree.
192 (The reported pixel aspect ratio in the output is determined from
193 these original dimensions and the averaged view.)\0
194 Note that the expense of the
195 .I \-fr
196 option is proportional to the number of views computed, and the
197 .I \-z
198 output file will be the z-buffer of the last view interpolated
199 rather than an averaged distance map.
200 .PP
201 In general,
202 .I pinterp
203 performs well when the output view is flanked by two nearby input
204 views, such as might occur in a walk-through animation sequence.
205 The algorithms start to break down when there is a large difference
206 between the view desired and the view(s) provided.
207 Specifically, obscured objects may appear to have holes in them and
208 large areas at the image borders may not be filled by the
209 foreground or background algorithms.
210 Also, specular reflections and highlights will not be interpolated
211 very well, since their view-dependent appearance will be
212 incompletely compensated for by the program.
213 (The
214 .I \-a
215 option offers some benefit in this area.)\0
216 .PP
217 The
218 .I \-e
219 option may be used to adjust the output image exposure, with the
220 same specification given as for
221 .I pfilt.
222 The actual adjustment will be rounded to the nearest integer f-stop
223 if the
224 .I \-q
225 option is in effect (or there is only a single input picture).
226 .SH EXAMPLE
227 To interpolate two frames of a walk-through animation, anti-alias to
228 512x400 and increase the exposure by 2.5 f-stops:
229 .IP "" .2i
230 pinterp \-vf 27.vf \-a \-x 512 \-y 400 \-e +2.5 30.hdr 30.z 20.hdr 20.z > 27.hdr
231 .PP
232 To extrapolate a second eyepoint for a stereo pair and recalculate
233 background regions:
234 .IP "" .2i
235 pinterp \-vf right.vf \-ff \-fr "\-av .1 .1 .1 scene.oct" left.hdr left.z > right.hdr
236 .PP
237 To convert an angular fisheye to a hemispherical fisheye:
238 .IP "" .2i
239 pinterp \-vf fish.hdr \-vth -ff fish.hdr 1 > hemi.hdr
240 .SH AUTHOR
241 Greg Ward
242 .SH "SEE ALSO"
243 getinfo(1), pdfblur(1), pfilt(1), pmblur(1), pmdblur(1), rpict(1),
244 ranimate(1), rtrace(1), rvu(1)
