root/radiance/ray/doc/man/man1/pinterp.1
Revision: 1.7
Committed: Sat Feb 21 00:06:05 2009 UTC (16 years, 2 months ago) by greg
CVS Tags: rad5R2, rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R1, rad4R0, rad4R2P1
Changes since 1.6: +5 -1 lines
Added example for converting view type
# User Rev Content
1 greg 1.7 .\" RCSid "$Id: pinterp.1,v 1.6 2008/11/10 19:08:17 greg Exp $"
2 greg 1.1 .TH PINTERP 1 1/24/96 RADIANCE
3     .SH NAME
4     pinterp - interpolate/extrapolate view from pictures
5     .SH SYNOPSIS
6     .B pinterp
7     [
8     view options
9     ][
10     .B "\-t threshold"
11     ][
12     .B "\-z zout"
13     ][
14     .B \-f
15     .I type
16     ][
17     .B \-B
18     ][
19     .B \-a|q
20     ][
21     .B "\-e exposure"
22     ][
23     .B \-n
24     ]
25     .B "pictfile zspec .."
26     .SH DESCRIPTION
27     .I Pinterp
28     interpolates or extrapolates a new view from
29     one or more RADIANCE pictures and
30     sends the result to the standard output.
31     The input picture files must contain correct view specifications, as
32     maintained by
33     .I rpict(1),
34 greg 1.3 .I rvu(1),
35 greg 1.1 .I pfilt(1)
36     and
37     .I pinterp.
38     Specifically,
39     .I pinterp
40     will not work on pictures processed by
41     .I pcompos(1)
42     or
43     .I pcomb(1).
44     Each input file must be accompanied by a z specification, which
45     gives the distance to each pixel in the image.
46     If
47     .I zspec
48     is an existing file, it is assumed to contain a short floating point
49     number for each pixel, written in scanline order.
50     This file is usually generated by the
51     .I \-z
52     option of
53     .I rpict(1).
54     If
55     .I zspec
56     is a positive number rather than a file, it will be used as a
57     constant value for the corresponding image.
58     This may be useful for certain transformations on "flat" images or
59     when the viewpoint remains constant.
60     .PP
61     The
62     .I \-n
63     option specifies that input and output
64     z distances are along the view direction,
65     rather than absolute distances to intersection points.
66     This option is usually appropriate with a constant z
67     specification, and should not be used with
68     .I rpict(1)
69     z files.
70     .PP
71     The
72     .I \-z
73     option writes out interpolated z values to the specified file.
74     Normally, this information is thrown away.
75     .PP
76     .I Pinterp
77     rearranges the pixels from the input pictures to produce a
78     reasonable estimate of the desired view.
79     Pixels that map within the
80     .I \-t
81     threshold of each other (.02 times the z distance
82     by default) are considered coincident.
83     With the
84     .I \-a
85     option, image points that coincide will be averaged together, giving
86     a smooth result.
87     The
88     .I \-q
89     option turns averaging off, which means that the first mapped pixel
90     for a given point will be used.
91     This makes the program run faster and
92     take less memory, but at the expense of image quality.
93     By default, two or more pictures are averaged together, and a single
94     picture is treated with the faster algorithm.
95     This may be undesirable when a quick result is desired from multiple
96     input pictures in the first case, or a single picture is being
97     reduced in size (anti-aliased) in the second case.
98     .PP
99     Portions which were hidden or missing in the input pictures must be
100     "filled in" somehow, and a number of methods are provided by the
101     .I \-f
102     option.
103     The default value for this option is
104     .I \-fa,
105     which results in both foreground and background filling.
106     The foreground fill algorithm spreads each input pixel to cover all
107     output pixels within a parallelogram corresponding to that pixel's
108     projection in the new view.
109     Without it, each input pixel contributes to at most one output
110     pixel.
111     The background algorithm fills in those areas in the final picture
112     that have not been filled with foreground pixels.
113     It does this by looking at the boundary surrounding each blank area
114     and picking the
115     farthest pixels to each side, assuming that this will make a suitable
116     background.
117     The
118     .I \-ff
119     option tells the program to use only the foreground fill, the
120     .I \-fb
121     option says use only background fill, and the
122     .I \-f0
123     option says not to use either fill algorithm.
124     .PP
125     Even when both fill algorithms are used, there may still be some unfilled
126     pixels.
127     By default, these pixels are painted black and assigned a z distance
128     of zero.
129     The
130     .I \-fc
131     option can be used to change the color used for unfilled pixels, and
132     the
133     .I \-fz
134     option can be used to set the z distance (always along the view direction).
135     Alternatively, the
136     .I \-fr
137     option can be used to compute these pixels using
138     .I rtrace(1).
139     The argument to this option is a quoted string containing arguments
140     for
141     .I rtrace.
142     It must contain the octree used to generate the input
143     pictures, along with any other options necessary to match the
144     calculation used for the input pictures.
145     The
146     .I \-fs
147     option can be used to place a limit on the distance (in pixels) over which
148     the background fill algorithm is used.
149     The default value for this option is 0, which is interpreted as no limit.
150     A value of 1 is equivalent to turning background fill off.
151     When combined with the
152     .I \-fr
153     option, this is roughly equivalent to the
154     .I \-ps
155     option of
156     .I rpict(1).
157     .PP
158     In order of increasing quality and cost, one can use the
159     .I \-fa
160     option alone, or the
161     .I \-fr
162     option paired with
163     .I \-fs
164     or
165     .I \-ff
166     or
167     .I \-f0.
168     The last combination will result in the recalculation of all pixels
169     not adequately accounted for in the input pictures, with an
170     associated computational expense.
171     It is rare that the
172     .I \-fs
173     option results in appreciable image degradation, so it is usually
174     the second combination that is used when the background fill
175     algorithm results in objectionable artifacts.
176     .PP
177     The
178     .I \-B
179     option may be used to average multiple views read from the standard
180     input into a single, blurred output picture.
181     This is similar to running
182     .I pinterp
183     multiple times and averaging the output together with a program like
184     .I pcomb(1).
185     This option is useful for simulating motion blur and depth of field.
186 greg 1.4 (See
187     .I pmdblur(1).)\0
188 greg 1.1 The input views are reported in the information header of the output
189     file, along with the averaged view.
190     The picture dimensions computed from the first view will be the
191     ones used, regardless whether or not the subsequent views agree.
192     (The reported pixel aspect ratio in the output is determined from
193     these original dimensions and the averaged view.)\0
194     Note that the expense of the
195     .I \-fr
196     option is proportional to the number of views computed, and the
197     .I \-z
198     output file will be the z-buffer of the last view interpolated
199     rather than an averaged distance map.
200     .PP
201     In general,
202     .I pinterp
203     performs well when the output view is flanked by two nearby input
204     views, such as might occur in a walk-through animation sequence.
205     The algorithms start to break down when there is a large difference
206     between the view desired and the view(s) provided.
207     Specifically, obscured objects may appear to have holes in them and
208     large areas at the image borders may not be filled by the
209     foreground or background algorithms.
210     Also, specular reflections and highlights will not be interpolated
211     very well, since their view-dependent appearance will be
212     incompletely compensated for by the program.
213     (The
214     .I \-a
215     option offers some benefit in this area.)\0
216     .PP
217     The
218     .I \-e
219     option may be used to adjust the output image exposure, with the
220     same specification given as for
221     .I pfilt.
222     The actual adjustment will be rounded to the nearest integer f-stop
223     if the
224     .I \-q
225     option is in effect (or there is only a single input picture).
226     .SH EXAMPLE
227     To interpolate two frames of a walk-through animation, anti-alias to
228     512x400 and increase the exposure by 2.5 f-stops:
229     .IP "" .2i
230 greg 1.6 pinterp \-vf 27.vf \-a \-x 512 \-y 400 \-e +2.5 30.hdr 30.z 20.hdr 20.z > 27.hdr
231 greg 1.1 .PP
232     To extrapolate a second eyepoint for a stereo pair and recalculate
233     background regions:
234     .IP "" .2i
235 greg 1.6 pinterp \-vf right.vf \-ff \-fr "\-av .1 .1 .1 scene.oct" left.hdr left.z > right.hdr
236 greg 1.7 .PP
237     To convert an angular fisheye to a hemispherical fisheye:
238     .IP "" .2i
239     pinterp \-vf fish.hdr \-vth -ff fish.hdr 1 > hemi.hdr
240 greg 1.1 .SH AUTHOR
241     Greg Ward
242     .SH "SEE ALSO"
243 greg 1.4 getinfo(1), pdfblur(1), pfilt(1), pmblur(1), pmdblur(1), rpict(1),
244     ranimate(1), rtrace(1), rvu(1)
