| 1 |
.\" RCSid "$Id"
| 2 |
.TH PINTERP 1 1/24/96 RADIANCE
| 3 |
.SH NAME
| 4 |
pinterp - interpolate/extrapolate view from pictures
| 5 |
.SH SYNOPSIS
| 6 |
.B pinterp
| 7 |
| 8 |
view options
| 9 |
| 10 |
.B "\-t threshold"
| 11 |
| 12 |
.B "\-z zout"
| 13 |
| 14 |
.B \-f
| 15 |
.I type
| 16 |
| 17 |
.B \-B
| 18 |
| 19 |
.B \-a|q
| 20 |
| 21 |
.B "\-e exposure"
| 22 |
| 23 |
.B \-n
| 24 |
| 25 |
.B "pictfile zspec .."
| 26 |
.SH DESCRIPTION
| 27 |
.I Pinterp
| 28 |
interpolates or extrapolates a new view from
| 29 |
one or more RADIANCE pictures and
| 30 |
sends the result to the standard output.
| 31 |
The input picture files must contain correct view specifications, as
| 32 |
maintained by
| 33 |
.I rpict(1),
| 34 |
.I rview(1),
| 35 |
.I pfilt(1)
| 36 |
and
| 37 |
.I pinterp.
| 38 |
Specifically,
| 39 |
.I pinterp
| 40 |
will not work on pictures processed by
| 41 |
.I pcompos(1)
| 42 |
or
| 43 |
.I pcomb(1).
| 44 |
Each input file must be accompanied by a z specification, which
| 45 |
gives the distance to each pixel in the image.
| 46 |
If
| 47 |
.I zspec
| 48 |
is an existing file, it is assumed to contain a short floating point
| 49 |
number for each pixel, written in scanline order.
| 50 |
This file is usually generated by the
| 51 |
.I \-z
| 52 |
option of
| 53 |
.I rpict(1).
| 54 |
If
| 55 |
.I zspec
| 56 |
is a positive number rather than a file, it will be used as a
| 57 |
constant value for the corresponding image.
| 58 |
This may be useful for certain transformations on "flat" images or
| 59 |
when the viewpoint remains constant.
| 60 |
.PP
| 61 |
The
| 62 |
.I \-n
| 63 |
option specifies that input and output
| 64 |
z distances are along the view direction,
| 65 |
rather than absolute distances to intersection points.
| 66 |
This option is usually appropriate with a constant z
| 67 |
specification, and should not be used with
| 68 |
.I rpict(1)
| 69 |
z files.
| 70 |
.PP
| 71 |
The
| 72 |
.I \-z
| 73 |
option writes out interpolated z values to the specified file.
| 74 |
Normally, this information is thrown away.
| 75 |
.PP
| 76 |
.I Pinterp
| 77 |
rearranges the pixels from the input pictures to produce a
| 78 |
reasonable estimate of the desired view.
| 79 |
Pixels that map within the
| 80 |
.I \-t
| 81 |
threshold of each other (.02 times the z distance
| 82 |
by default) are considered coincident.
| 83 |
With the
| 84 |
.I \-a
| 85 |
option, image points that coincide will be averaged together, giving
| 86 |
a smooth result.
| 87 |
The
| 88 |
.I \-q
| 89 |
option turns averaging off, which means that the first mapped pixel
| 90 |
for a given point will be used.
| 91 |
This makes the program run faster and
| 92 |
take less memory, but at the expense of image quality.
| 93 |
By default, two or more pictures are averaged together, and a single
| 94 |
picture is treated with the faster algorithm.
| 95 |
This may be undesirable when a quick result is desired from multiple
| 96 |
input pictures in the first case, or a single picture is being
| 97 |
reduced in size (anti-aliased) in the second case.
| 98 |
.PP
| 99 |
Portions which were hidden or missing in the input pictures must be
| 100 |
"filled in" somehow, and a number of methods are provided by the
| 101 |
.I \-f
| 102 |
option.
| 103 |
The default value for this option is
| 104 |
.I \-fa,
| 105 |
which results in both foreground and background filling.
| 106 |
The foreground fill algorithm spreads each input pixel to cover all
| 107 |
output pixels within a parallelogram corresponding to that pixel's
| 108 |
projection in the new view.
| 109 |
Without it, each input pixel contributes to at most one output
| 110 |
pixel.
| 111 |
The background algorithm fills in those areas in the final picture
| 112 |
that have not been filled with foreground pixels.
| 113 |
It does this by looking at the boundary surrounding each blank area
| 114 |
and picking the
| 115 |
farthest pixels to each side, assuming that this will make a suitable
| 116 |
background.
| 117 |
The
| 118 |
.I \-ff
| 119 |
option tells the program to use only the foreground fill, the
| 120 |
.I \-fb
| 121 |
option says use only background fill, and the
| 122 |
.I \-f0
| 123 |
option says not to use either fill algorithm.
| 124 |
.PP
| 125 |
Even when both fill algorithms are used, there may still be some unfilled
| 126 |
pixels.
| 127 |
By default, these pixels are painted black and assigned a z distance
| 128 |
of zero.
| 129 |
The
| 130 |
.I \-fc
| 131 |
option can be used to change the color used for unfilled pixels, and
| 132 |
the
| 133 |
.I \-fz
| 134 |
option can be used to set the z distance (always along the view direction).
| 135 |
Alternatively, the
| 136 |
.I \-fr
| 137 |
option can be used to compute these pixels using
| 138 |
.I rtrace(1).
| 139 |
The argument to this option is a quoted string containing arguments
| 140 |
for
| 141 |
.I rtrace.
| 142 |
It must contain the octree used to generate the input
| 143 |
pictures, along with any other options necessary to match the
| 144 |
calculation used for the input pictures.
| 145 |
The
| 146 |
.I \-fs
| 147 |
option can be used to place a limit on the distance (in pixels) over which
| 148 |
the background fill algorithm is used.
| 149 |
The default value for this option is 0, which is interpreted as no limit.
| 150 |
A value of 1 is equivalent to turning background fill off.
| 151 |
When combined with the
| 152 |
.I \-fr
| 153 |
option, this is roughly equivalent to the
| 154 |
.I \-ps
| 155 |
option of
| 156 |
.I rpict(1).
| 157 |
.PP
| 158 |
In order of increasing quality and cost, one can use the
| 159 |
.I \-fa
| 160 |
option alone, or the
| 161 |
.I \-fr
| 162 |
option paired with
| 163 |
.I \-fs
| 164 |
or
| 165 |
.I \-ff
| 166 |
or
| 167 |
.I \-f0.
| 168 |
The last combination will result in the recalculation of all pixels
| 169 |
not adequately accounted for in the input pictures, with an
| 170 |
associated computational expense.
| 171 |
It is rare that the
| 172 |
.I \-fs
| 173 |
option results in appreciable image degradation, so it is usually
| 174 |
the second combination that is used when the background fill
| 175 |
algorithm results in objectionable artifacts.
| 176 |
.PP
| 177 |
The
| 178 |
.I \-B
| 179 |
option may be used to average multiple views read from the standard
| 180 |
input into a single, blurred output picture.
| 181 |
This is similar to running
| 182 |
.I pinterp
| 183 |
multiple times and averaging the output together with a program like
| 184 |
.I pcomb(1).
| 185 |
This option is useful for simulating motion blur and depth of field.
| 186 |
(See also
| 187 |
.I pdfblur(1).)\0
| 188 |
The input views are reported in the information header of the output
| 189 |
file, along with the averaged view.
| 190 |
The picture dimensions computed from the first view will be the
| 191 |
ones used, regardless whether or not the subsequent views agree.
| 192 |
(The reported pixel aspect ratio in the output is determined from
| 193 |
these original dimensions and the averaged view.)\0
| 194 |
Note that the expense of the
| 195 |
.I \-fr
| 196 |
option is proportional to the number of views computed, and the
| 197 |
.I \-z
| 198 |
output file will be the z-buffer of the last view interpolated
| 199 |
rather than an averaged distance map.
| 200 |
.PP
| 201 |
In general,
| 202 |
.I pinterp
| 203 |
performs well when the output view is flanked by two nearby input
| 204 |
views, such as might occur in a walk-through animation sequence.
| 205 |
The algorithms start to break down when there is a large difference
| 206 |
between the view desired and the view(s) provided.
| 207 |
Specifically, obscured objects may appear to have holes in them and
| 208 |
large areas at the image borders may not be filled by the
| 209 |
foreground or background algorithms.
| 210 |
Also, specular reflections and highlights will not be interpolated
| 211 |
very well, since their view-dependent appearance will be
| 212 |
incompletely compensated for by the program.
| 213 |
(The
| 214 |
.I \-a
| 215 |
option offers some benefit in this area.)\0
| 216 |
.PP
| 217 |
The
| 218 |
.I \-e
| 219 |
option may be used to adjust the output image exposure, with the
| 220 |
same specification given as for
| 221 |
.I pfilt.
| 222 |
The actual adjustment will be rounded to the nearest integer f-stop
| 223 |
if the
| 224 |
.I \-q
| 225 |
option is in effect (or there is only a single input picture).
| 226 |
.SH EXAMPLE
| 227 |
To interpolate two frames of a walk-through animation, anti-alias to
| 228 |
512x400 and increase the exposure by 2.5 f-stops:
| 229 |
.IP "" .2i
| 230 |
pinterp -vf 27.vf -a -x 512 -y 400 -e +2.5 30.pic 30.z 20.pic 20.z > 27.pic
| 231 |
.PP
| 232 |
To extrapolate a second eyepoint for a stereo pair and recalculate
| 233 |
background regions:
| 234 |
.IP "" .2i
| 235 |
pinterp -vf right.vf -ff -fr "-av .1 .1 .1 scene.oct" left.pic left.z > right.pic
| 236 |
.SH AUTHOR
| 237 |
Greg Ward
| 238 |
.SH "SEE ALSO"
| 239 |
getinfo(1), pdfblur(1), pfilt(1), pmblur(1), rpict(1), ranimate(1),
| 240 |
rtrace(1), rview(1)
