root/Development/ray/doc/man/man1/phisto.1
Revision: 1.2
Committed: Tue Dec 9 15:59:06 2003 UTC (21 years, 11 months ago) by greg
CVS Tags: rad3R8, rad3R7P2, rad3R7P1, rad3R6P1, rad3R6
Fixed RCSid specification
1 .\" RCSid "$Id$"
2 .TH PHISTO 1 3/12/98 RADIANCE
3 .SH NAME
4 phisto - compute a luminance histogram from one or more RADIANCE pictures
5 .SH SYNOPSIS
6 .B phisto
7 .B "picture .."
8 .SH DESCRIPTION
9 .I Phisto
10 is a script that calls
11 .I pfilt(1),
12 .I rcalc(1)
13 and
14 .I histo(1)
15 to compute a histogram of log luminance values for foveal samples in
16 the given picture files.
17 A foveal sample covers approximately 1 degree, though this script does
18 not use this exact area.
19 The minimum and maximum values are determined, and 100 histogram bins
20 are uniformly divided between these extrema.
21 Foveal samples less than 1e-7 candelas/sq.meter are silently ignored.
22 If no picture is named on the command line, the standard input is read.
23 .PP
24 The primary function of this script is to precompute histograms for the
25 .I pcond(1)
26 program, which may then be used to compute multiple, identical exposures.
27 This is especially useful for animations and image comparisons.
28 .SH EXAMPLE
29 .PP
30 To compute two identical tone mappings for image1.pic and image2.pic:
31 .IP "" .2i
32 phisto image1.pic image2.pic > both.histo
33 .br
34 pcond -I -h image1.pic < both.histo > image1m.pic
35 .br
36 pcond -I -h image2.pic < both.histo > image2m.pic
37 .SH AUTHOR
38 Greg Ward Larson
39 .SH "SEE ALSO"
40 histo(1), pcond(1), pfilt(1), pvalue(1), rcalc(1), total(1)
