--- ray/doc/man/man1/pfilt.1 2003/12/09 15:59:06 1.2 +++ ray/doc/man/man1/pfilt.1 2023/12/12 16:31:45 1.7 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: pfilt.1,v 1.2 2003/12/09 15:59:06 greg Exp $" +.\" RCSid "$Id: pfilt.1,v 1.7 2023/12/12 16:31:45 greg Exp $" .TH PFILT 1 11/8/96 RADIANCE .SH NAME pfilt - filter a RADIANCE picture @@ -12,7 +12,8 @@ pfilt - filter a RADIANCE picture ] .SH DESCRIPTION .I Pfilt -performs anti-aliasing and scaling on a RADIANCE picture. +performs anti-aliasing and scaling on a RADIANCE picture +or hyperspectral image. The program makes two passes on the picture file in order to set the exposure to the correct average value. If no @@ -69,7 +70,7 @@ Multiple exposure options have a cumulative effect. Color-balance the image as if it were illuminated by fixtures of the given type. The specification must match a pattern listed in the lamp -lookup table (see the -f option below). +lookup table (see the \-f option below). .TP .BR -f \ lampdat Use the specified lamp lookup table rather than the default (lamp.tab). @@ -105,7 +106,7 @@ of any given output pixel. This option may be used to mitigate the problems associated with inadequate image sampling, at the expense of a slightly blurred image. -The fraction given should not exceed the output picture dimensions +The fraction given should not be less than the output picture dimensions over the input picture dimensions (x_o*y_o/x_i/y_i), or blurring will occur over the entire image. This option implies the @@ -140,9 +141,10 @@ are not used in setting the exposure. .SH ENVIRONMENT RAYPATH directories to search for lamp lookup table .SH FILES -/usr/tmp/rt?????? +/tmp/rt?????? .SH AUTHOR Greg Ward .SH "SEE ALSO" -getinfo(1), ies2rad(1), pcompos(1), pflip(1), pinterp(1), -pvalue(1), protate(1), rad(1), rpict(1), ximage(1) +getinfo(1), ies2rad(1), pcomb(1), pcompos(1), pflip(1), pinterp(1), +pvalue(1), protate(1), rad(1), rcomb(1), rmtxop(1), +rpict(1), ximage(1)
