root/radiance/ray/doc/man/man1/pfilt.1
Revision: 1.7
Committed: Tue Dec 12 16:31:45 2023 UTC (18 months, 2 weeks ago) by greg
1 .\" RCSid "$Id: pfilt.1,v 1.6 2023/12/08 17:56:26 greg Exp $"
2 .TH PFILT 1 11/8/96 RADIANCE
3 .SH NAME
4 pfilt - filter a RADIANCE picture
5 .SH SYNOPSIS
6 .B pfilt
7 [
8 .B options
9 ]
10 [
11 .B file
12 ]
13 .SH DESCRIPTION
14 .I Pfilt
15 performs anti-aliasing and scaling on a RADIANCE picture
16 or hyperspectral image.
17 The program makes two passes on the picture file in order to
18 set the exposure to the correct average value.
19 If no
20 .I file
21 is given, the standard input is read.
22 .TP 10n
23 .BI -x \ res
24 Set the output x resolution to
25 .I res.
26 This must be less than or equal to the x dimension
27 of the target device.
28 If
29 .I res
30 is given as a slash followed by a real number, the input resolution
31 is divided by this number to get the output resolution.
32 By default, the output resolution is the same as the input.
33 .TP
34 .BI -y \ res
35 Set the output y resolution to
36 .I res,
37 similar to the specification of the x resolution above.
38 .TP
39 .BI -p \ rat
40 Set the pixel aspect ratio to
41 .I rat.
42 Either the x or the y resolution will be reduced so that the pixels have
43 this ratio for the specified picture.
44 If
45 .I rat
46 is zero, then the x and y resolutions will adhere to the given maxima.
47 Zero is the default.
48 .TP
49 .BI -c
50 Pixel aspect ratio is being corrected, so do not write PIXASPECT
51 variable to output file.
52 .TP
53 .BI -e \ exp
54 Adjust the exposure.
55 If
56 .I exp
57 is preceded by a '+' or '-', the exposure is interpreted in f-stops
58 (ie. the power of two).
59 Otherwise,
60 .I exp
61 is interpreted as a straight multiplier.
62 The individual primaries can be changed using
63 .I \-er,
64 .I \-eg
65 and
66 .I \-eb.
67 Multiple exposure options have a cumulative effect.
68 .TP
69 .BR -t \ lamp
70 Color-balance the image as if it were illuminated by fixtures of
71 the given type.
72 The specification must match a pattern listed in the lamp
73 lookup table (see the \-f option below).
74 .TP
75 .BR -f \ lampdat
76 Use the specified lamp lookup table rather than the default (lamp.tab).
77 .TP
78 .BR \-1
79 Use only one pass on the file.
80 This allows the exposure to be controlled absolutely, without
81 any averaging.
82 Note that a single pass is much quicker and should be used whenever
83 the desired exposure is known and star patterns are not required.
84 .TP
85 .BR \-2
86 Use two passes on the input.
87 This is the default.
88 .TP
89 .BR \-b
90 Use box filtering (default).
91 Box filtering averages the input pixels corresponding
92 to each separate output pixel.
93 .TP
94 .BI -r \ rad
95 Use Gaussian filtering with a radius of
96 .I rad
97 relative to the output pixel size.
98 This option with a radius around 0.6 and a reduction in image width and
99 height of 2 or 3 produces the highest quality pictures.
100 A radius greater than 0.7 results in a defocused picture.
101 .TP
102 .BI -m \ frac
103 Limit the influence of any given input pixel to
104 .I frac
105 of any given output pixel.
106 This option may be used to mitigate the problems associated with
107 inadequate image sampling, at the expense of a slightly blurred
108 image.
109 The fraction given should not be less than the output picture dimensions
110 over the input picture dimensions (x_o*y_o/x_i/y_i), or blurring
111 will occur over the entire image.
112 This option implies the
113 .I \-r
114 option for Gaussian filtering, which defaults to a radius of 0.6.
115 .TP
116 .BI -h \ lvl
117 Set intensity considered ``hot'' to
118 .I lvl.
119 This is the level above which areas of the image will begin
120 to exhibit star diffraction patterns (see below).
121 The default is 100 watts/sr/m2.
122 .TP
123 .BI -n \ N
124 Set the number of points on star patterns to
125 .I N.
126 A value of zero turns star patterns off.
127 The default is 0.
128 (Note that two passes are required for star patterns.)\0
129 .TP
130 .BI -s \ val
131 Set the spread for star patterns to
132 .I val.
133 This is the value a star pattern will have at the
134 edge of the image.
135 The default is .0001.
136 .TP
137 .BR \-a
138 Average hot spots as well.
139 By default, the areas of the picture above the hot level
140 are not used in setting the exposure.
141 .SH ENVIRONMENT
142 RAYPATH directories to search for lamp lookup table
143 .SH FILES
144 /tmp/rt??????
145 .SH AUTHOR
146 Greg Ward
147 .SH "SEE ALSO"
148 getinfo(1), ies2rad(1), pcomb(1), pcompos(1), pflip(1), pinterp(1),
149 pvalue(1), protate(1), rad(1), rcomb(1), rmtxop(1),
150 rpict(1), ximage(1)
