root/radiance/ray/doc/man/man1/pextrem.1
Revision: 1.3
Committed: Fri Feb 4 20:11:48 2022 UTC (2 years, 4 months ago) by greg
CVS Tags: rad5R4, HEAD
Changes since 1.2: +6 -2 lines
feat(pvalue,pextrem): Added -O option to report watts/sr/meter^2 always
1 .\" RCSid "$Id: pextrem.1,v 1.2 2003/12/09 15:59:06 greg Exp $"
2 .TH PEXTREM 1 11/15/93 RADIANCE
3 .SH NAME
4 pextrem - find minimum and maximum values in RADIANCE picture
5 .SH SYNOPSIS
6 .B pextrem
7 [
8 .B "-o | -O"
9 ]
10 [
11 picture
12 ]
13 .SH DESCRIPTION
14 .I Pextrem
15 locates the minimum and maximum values for the input
16 .I picture,
17 and prints their pixel locations and color values.
18 The first line printed contains the x and y pixel location
19 (x measured from the left margin, y measured from the bottom),
20 followed by the red, green and blue values.
21 The second line printed contains the same information for the
22 maximum value.
23 .PP
24 The
25 .I \-o
26 option prints the original (radiance) values, undoing any exposure
27 or color correction done on the picture.
28 If the input is XYZE, then the second channel is in candelas/meter^2,
29 unless
30 .I \-O
31 is specified, when watts/sr/meter^2 are always reported.
32 .PP
33 If no input
34 .I picture
35 is given, the standard input is read.
36 .SH AUTHOR
37 Greg Ward
38 .SH BUGS
39 The luminance value is used for comparison of pixels, although in
40 certain anomolous cases (ie. highly saturated colors) it is possible that
41 .I pextrem
42 will not pick the absolute minimum or maximum luminance value.
43 This is because a fast integer-space comparison is used.
44 A more reliable floating-point comparison would be slower by
45 an order of magnitude.
46 .SH "SEE ALSO"
47 falsecolor(1), getinfo(1), pcomb(1), pcompos(1), pextrem(1), pfilt(1),
48 pflip(1), protate(1), psign(1), rpict(1), ximage(1)
