root/Development/ray/doc/man/man1/pexpand.1
Revision: 1.3
Committed: Tue Sep 4 17:36:40 2007 UTC (18 years, 4 months ago) by greg
CVS Tags: rad6R0, rad5R4, rad5R3, rad5R2, rad5R1, rad5R0, rad4R2P2, rad4R2P1, rad4R2, rad4R1, rad4R0, rad3R9, HEAD
Added backslashes in front of hyphens (thanks to Bernd Zeimetz for his effort)
# User Rev Content
1 greg 1.3 .\" RCSid "$Id: pexpand.1,v 1.2 2003/12/09 15:59:06 greg Exp $"
2 greg 1.1 .TH PEXPAND 1 6/24/98 RADIANCE
3     .SH NAME
4     pexpand - expand requested commands in metafile
5     .SH SYNOPSIS
6     .B pexpand
7     [
8     .B +/\-EPDOCSURIlrtmvsp
9     ]
10     file ..
11     .SH DESCRIPTION
12     .I Pexpand
13     reads each metafile
14     .I file
15     in sequence and expands any commands specified in a '+' option,
16     and deletes any commands specified in a '-' option.
17     This is necessary because most drivers will not support many
18     metafile commands such as 'v' (vector string) and 'O', 'C', and 's'
19     (segments).
20     .I Pexpand
21     will expand '+' instances into the corresponding primitives which
22     are supported, and delete all '-' instances.
23     .PP
24     Certain commands are currently considered basic, and must be supported
25     by all drivers.
26     The commands 'D', 'E', 'S', 'U', 'R', 'l', 'r', and 't' are
27     basic (see metafile(5)).
28     .PP
29     If no input files are specified, the standard input is read.
30     .TP 10n
31     .BR +EPDOCSURIlrtmvsp
32     Expand the requested command(s).
33     .TP
34     .BR \-EPDOCSURIlrtmvsp
35     Delete the requested command(s).
36     .SH EXAMPLE
37     To expand vector strings and segements, and delete pauses from "meta":
38     .IP "" .2i
39 greg 1.3 pexpand +vOCs \-P meta
40 greg 1.1 .SH FILES
41     /usr/lib/meta/vchars.mta (see metafile(5))
42     .SH AUTHOR
43     Greg Ward
44     .SH "SEE ALSO"
45     metafile(5), psort(1)
