root/Development/ray/doc/man/man1/pexpand.1
Revision: 1.3
Committed: Tue Sep 4 17:36:40 2007 UTC (18 years ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R0, rad5R1, rad4R2, rad6R0, rad4R1, rad4R0, rad3R9, rad4R2P1, rad4R2P2, HEAD
Added backslashes in front of hyphens (thanks to Bernd Zeimetz for his effort)
1 .\" RCSid "$Id: pexpand.1,v 1.2 2003/12/09 15:59:06 greg Exp $"
2 .TH PEXPAND 1 6/24/98 RADIANCE
3 .SH NAME
4 pexpand - expand requested commands in metafile
5 .SH SYNOPSIS
6 .B pexpand
7 [
8 .B +/\-EPDOCSURIlrtmvsp
9 ]
10 file ..
11 .SH DESCRIPTION
12 .I Pexpand
13 reads each metafile
14 .I file
15 in sequence and expands any commands specified in a '+' option,
16 and deletes any commands specified in a '-' option.
17 This is necessary because most drivers will not support many
18 metafile commands such as 'v' (vector string) and 'O', 'C', and 's'
19 (segments).
20 .I Pexpand
21 will expand '+' instances into the corresponding primitives which
22 are supported, and delete all '-' instances.
23 .PP
24 Certain commands are currently considered basic, and must be supported
25 by all drivers.
26 The commands 'D', 'E', 'S', 'U', 'R', 'l', 'r', and 't' are
27 basic (see metafile(5)).
28 .PP
29 If no input files are specified, the standard input is read.
30 .TP 10n
31 .BR +EPDOCSURIlrtmvsp
32 Expand the requested command(s).
33 .TP
34 .BR \-EPDOCSURIlrtmvsp
35 Delete the requested command(s).
36 .SH EXAMPLE
37 To expand vector strings and segements, and delete pauses from "meta":
38 .IP "" .2i
39 pexpand +vOCs \-P meta
40 .SH FILES
41 /usr/lib/meta/vchars.mta (see metafile(5))
42 .SH AUTHOR
43 Greg Ward
44 .SH "SEE ALSO"
45 metafile(5), psort(1)
