1 |
.\" RCSid "$Id$" |
2 |
.TH PDFBLUR 1 1/24/96 RADIANCE |
3 |
.SH NAME |
4 |
pdfblur - generate views for depth-of-field blurring |
5 |
.SH SYNOPSIS |
6 |
.B pdfblur |
7 |
.B aperture |
8 |
.B distance |
9 |
.B nsamp |
10 |
.B viewfile |
11 |
.SH DESCRIPTION |
12 |
.I Pdfblur |
13 |
takes the given |
14 |
.I viewfile |
15 |
and computes |
16 |
.I nsamp |
17 |
views based on a focus distance of |
18 |
.I distance |
19 |
and an aperture diameter of |
20 |
.I aperture |
21 |
(both in world coordinate units). |
22 |
When rendered and averaged together, these views will result in |
23 |
a picture with the specified depth of field. |
24 |
Either |
25 |
.I pinterp(1) |
26 |
or |
27 |
.I rpict(1) |
28 |
may be called to do the actual work. |
29 |
(The given |
30 |
.I viewfile |
31 |
must also be passed on the command line to the chosen renderer, since |
32 |
.I pdfblur |
33 |
provides supplemental view specifications only.)\0 |
34 |
.PP |
35 |
For |
36 |
.I pinterp, |
37 |
feed the output of |
38 |
.I pdfblur |
39 |
to the standard input of |
40 |
.I pinterp |
41 |
and apply the |
42 |
.I \-B |
43 |
option to blur views together. |
44 |
In most cases, a single picture with z-buffer is all that is required |
45 |
to get a satisfactory result, though the perfectionist may wish to |
46 |
apply three pictures arranged in a triangle about the aperature, or |
47 |
alternatively apply the |
48 |
.I \-ff |
49 |
option together with the |
50 |
.I \-fr |
51 |
option of |
52 |
.I pinterp. |
53 |
(The latter may actually work out to be faster, since rendering |
54 |
three views takes three times as long as a single view, and the |
55 |
.I \-fr |
56 |
option will end up recomputing relatively few pixels by |
57 |
comparison.)\0 |
58 |
.PP |
59 |
To use |
60 |
.I pdfblur |
61 |
with |
62 |
.I rpict, |
63 |
apply the |
64 |
.I \-S |
65 |
option to indicate a rendering sequence, and set the |
66 |
.I \-o |
67 |
option with a formatted file name to save multiple output |
68 |
pictures. |
69 |
When all the renderings are finished, combine them with the |
70 |
.I pcomb(1) |
71 |
program, using appropriate scalefactors to achieve an average. |
72 |
Note that using |
73 |
.I rpict |
74 |
is MUCH more expensive than using |
75 |
.I pinterp, |
76 |
and it is only recommended if the scene and application |
77 |
absolutely demand it (e.g. there is prominent refraction that |
78 |
must be modeled accurately). |
79 |
.PP |
80 |
For both |
81 |
.I pinterp |
82 |
and |
83 |
.I rpict, |
84 |
the computation time will be proportional to the number of views from |
85 |
.I pdfblur. |
86 |
We have found a |
87 |
.I nsamp |
88 |
setting somewhere between 5 and 10 to be adequate for most images. |
89 |
Relatively larger values are appropriate for larger aperatures. |
90 |
.SH EXAMPLES |
91 |
To use |
92 |
.I pinterp |
93 |
to simulate an aperture of 0.5 inches on a lens focused at a |
94 |
distance of 57 inches: |
95 |
.IP "" .2i |
96 |
rpict -vf myview -x 640 -y 480 -z orig.zbf scene.oct > orig.pic |
97 |
.br |
98 |
pdfblur 0.5 57 8 orig.pic | pinterp -B -vf orig.pic -x 640 -y 480 |
99 |
orig.pic orig.zbf > blurry.pic |
100 |
.PP |
101 |
To use |
102 |
.I rpict |
103 |
exclusively to do the same: |
104 |
.IP "" .2i |
105 |
pdfblur .5 57 5 myview | rpict -S 1 -vf myview -x 640 -y 480 |
106 |
-o view%d.pic scene.oct |
107 |
.br |
108 |
pcomb -s .2 view1.pic -s .2 view2.pic -s .2 view3.pic -s .2 |
109 |
view4.pic -s .2 view5.pic > blurry.pic |
110 |
.SH AUTHOR |
111 |
Greg Ward |
112 |
.SH BUGS |
113 |
This program really only works with perspective views. |
114 |
.SH "SEE ALSO" |
115 |
pcomb(1), pinterp(1), pmblur(1), rcalc(1), rpict(1), vwright(1) |
