--- ray/doc/man/man1/pdfblur.1 2003/12/09 15:59:06 1.2 +++ ray/doc/man/man1/pdfblur.1 2005/01/18 01:37:43 1.3 @@ -1,11 +1,10 @@ -.\" RCSid "$Id: pdfblur.1,v 1.2 2003/12/09 15:59:06 greg Exp $" +.\" RCSid "$Id: pdfblur.1,v 1.3 2005/01/18 01:37:43 greg Exp $" .TH PDFBLUR 1 1/24/96 RADIANCE .SH NAME pdfblur - generate views for depth-of-field blurring .SH SYNOPSIS .B pdfblur .B aperture -.B distance .B nsamp .B viewfile .SH DESCRIPTION @@ -14,11 +13,11 @@ takes the given .I viewfile and computes .I nsamp -views based on a focus distance of -.I distance -and an aperture diameter of +views based on an aperture diameter of .I aperture -(both in world coordinate units). +(in world coordinate units) and a focal distance equal to the length of the +.I \-vd +view direction vector. When rendered and averaged together, these views will result in a picture with the specified depth of field. Either @@ -87,6 +86,22 @@ We have found a .I nsamp setting somewhere between 5 and 10 to be adequate for most images. Relatively larger values are appropriate for larger aperatures. +.PP +The +.I \-pd +option of +.I rpict +may be used instead or in combination with or instead of +.I pdfblur +to blur depth-of-field. +If used in combination, +it is best to set the +.I \-pd +option to the overall +.I aperture +divided by +.I nsamp +to minimize ghosting in the output. .SH EXAMPLES To use .I pinterp
