root/Development/ray/doc/man/man1/pdfblur.1
Revision: 1.6
Committed: Tue Sep 4 17:36:40 2007 UTC (18 years, 3 months ago) by greg
Changes since 1.5: +7 -7 lines
Added backslashes in front of hyphens (thanks to Bernd Zeimetz for his effort)
# User Rev Content
1 greg 1.6 .\" RCSid "$Id: pdfblur.1,v 1.5 2005/01/18 20:19:56 greg Exp $"
2 greg 1.1 .TH PDFBLUR 1 1/24/96 RADIANCE
3     .SH NAME
4     pdfblur - generate views for depth-of-field blurring
5     .SH SYNOPSIS
6     .B pdfblur
7     .B aperture
8     .B nsamp
9     .B viewfile
10     .SH DESCRIPTION
11     .I Pdfblur
12     takes the given
13     .I viewfile
14     and computes
15     .I nsamp
16 greg 1.3 views based on an aperture diameter of
17 greg 1.1 .I aperture
18 greg 1.3 (in world coordinate units) and a focal distance equal to the length of the
19     .I \-vd
20     view direction vector.
21 greg 1.1 When rendered and averaged together, these views will result in
22     a picture with the specified depth of field.
23     Either
24     .I pinterp(1)
25     or
26     .I rpict(1)
27     may be called to do the actual work.
28     (The given
29     .I viewfile
30     must also be passed on the command line to the chosen renderer, since
31     .I pdfblur
32     provides supplemental view specifications only.)\0
33     .PP
34     For
35     .I pinterp,
36     feed the output of
37     .I pdfblur
38     to the standard input of
39     .I pinterp
40     and apply the
41     .I \-B
42     option to blur views together.
43     In most cases, a single picture with z-buffer is all that is required
44     to get a satisfactory result, though the perfectionist may wish to
45     apply three pictures arranged in a triangle about the aperature, or
46     alternatively apply the
47     .I \-ff
48     option together with the
49     .I \-fr
50     option of
51     .I pinterp.
52     (The latter may actually work out to be faster, since rendering
53     three views takes three times as long as a single view, and the
54     .I \-fr
55     option will end up recomputing relatively few pixels by
56     comparison.)\0
57     .PP
58     To use
59     .I pdfblur
60     with
61     .I rpict,
62     apply the
63     .I \-S
64     option to indicate a rendering sequence, and set the
65     .I \-o
66     option with a formatted file name to save multiple output
67     pictures.
68     When all the renderings are finished, combine them with the
69     .I pcomb(1)
70     program, using appropriate scalefactors to achieve an average.
71     Note that using
72     .I rpict
73     is MUCH more expensive than using
74     .I pinterp,
75     and it is only recommended if the scene and application
76     absolutely demand it (e.g. there is prominent refraction that
77     must be modeled accurately).
78     .PP
79     For both
80     .I pinterp
81     and
82     .I rpict,
83     the computation time will be proportional to the number of views from
84     .I pdfblur.
85     We have found a
86     .I nsamp
87     setting somewhere between 5 and 10 to be adequate for most images.
88     Relatively larger values are appropriate for larger aperatures.
89 greg 1.3 .PP
90     The
91     .I \-pd
92     option of
93     .I rpict
94     may be used instead or in combination with or instead of
95     .I pdfblur
96     to blur depth-of-field.
97     If used in combination,
98     it is best to set the
99     .I \-pd
100     option to the overall
101     .I aperture
102     divided by
103     .I nsamp
104     to minimize ghosting in the output.
105 greg 1.5 .PP
106     To simulate a particular camera's aperture, divide the focal length of
107     the lens by the f-number, then convert to the corresponding
108     world coordinate units.
109     For example, if you wish to simulate a 50mm lens at f/2.0 in
110     a scene modeled in meters, then you divide 50mm by 2.0 to get 25mm,
111     which corresponds to an effective aperture of 0.025 meters.
112 greg 1.1 .SH EXAMPLES
113     To use
114     .I pinterp
115     to simulate an aperture of 0.5 inches on a lens focused at a
116     distance of 57 inches:
117     .IP "" .2i
118 greg 1.6 rpict \-vf myview \-x 640 \-y 480 \-z orig.zbf scene.oct > orig.pic
119 greg 1.1 .br
120 greg 1.6 pdfblur 0.5 57 8 orig.pic | pinterp \-B \-vf orig.pic \-x 640 \-y 480
121 greg 1.1 orig.pic orig.zbf > blurry.pic
122     .PP
123     To use
124     .I rpict
125     exclusively to do the same:
126     .IP "" .2i
127 greg 1.6 pdfblur .5 57 5 myview | rpict \-S 1 \-vf myview \-x 640 \-y 480
128     \-o view%d.pic scene.oct
129 greg 1.1 .br
130 greg 1.6 pcomb \-s .2 view1.pic \-s .2 view2.pic \-s .2 view3.pic \-s .2
131     view4.pic \-s .2 view5.pic > blurry.pic
132 greg 1.1 .SH AUTHOR
133     Greg Ward
134     .SH BUGS
135     This program really only works with perspective views.
136     .SH "SEE ALSO"
137 greg 1.4 pcomb(1), pinterp(1), pmblur(1), pmdblur(1), rcalc(1), rpict(1), vwright(1)
