root/Development/ray/doc/man/man1/pdfblur.1
Revision: 1.1
Committed: Tue Mar 11 19:20:21 2003 UTC (22 years, 9 months ago) by greg
Added documentation to repository
1 .\" RCSid "$Id"
2 .TH PDFBLUR 1 1/24/96 RADIANCE
3 .SH NAME
4 pdfblur - generate views for depth-of-field blurring
5 .SH SYNOPSIS
6 .B pdfblur
7 .B aperture
8 .B distance
9 .B nsamp
10 .B viewfile
11 .SH DESCRIPTION
12 .I Pdfblur
13 takes the given
14 .I viewfile
15 and computes
16 .I nsamp
17 views based on a focus distance of
18 .I distance
19 and an aperture diameter of
20 .I aperture
21 (both in world coordinate units).
22 When rendered and averaged together, these views will result in
23 a picture with the specified depth of field.
24 Either
25 .I pinterp(1)
26 or
27 .I rpict(1)
28 may be called to do the actual work.
29 (The given
30 .I viewfile
31 must also be passed on the command line to the chosen renderer, since
32 .I pdfblur
33 provides supplemental view specifications only.)\0
34 .PP
35 For
36 .I pinterp,
37 feed the output of
38 .I pdfblur
39 to the standard input of
40 .I pinterp
41 and apply the
42 .I \-B
43 option to blur views together.
44 In most cases, a single picture with z-buffer is all that is required
45 to get a satisfactory result, though the perfectionist may wish to
46 apply three pictures arranged in a triangle about the aperature, or
47 alternatively apply the
48 .I \-ff
49 option together with the
50 .I \-fr
51 option of
52 .I pinterp.
53 (The latter may actually work out to be faster, since rendering
54 three views takes three times as long as a single view, and the
55 .I \-fr
56 option will end up recomputing relatively few pixels by
57 comparison.)\0
58 .PP
59 To use
60 .I pdfblur
61 with
62 .I rpict,
63 apply the
64 .I \-S
65 option to indicate a rendering sequence, and set the
66 .I \-o
67 option with a formatted file name to save multiple output
68 pictures.
69 When all the renderings are finished, combine them with the
70 .I pcomb(1)
71 program, using appropriate scalefactors to achieve an average.
72 Note that using
73 .I rpict
74 is MUCH more expensive than using
75 .I pinterp,
76 and it is only recommended if the scene and application
77 absolutely demand it (e.g. there is prominent refraction that
78 must be modeled accurately).
79 .PP
80 For both
81 .I pinterp
82 and
83 .I rpict,
84 the computation time will be proportional to the number of views from
85 .I pdfblur.
86 We have found a
87 .I nsamp
88 setting somewhere between 5 and 10 to be adequate for most images.
89 Relatively larger values are appropriate for larger aperatures.
90 .SH EXAMPLES
91 To use
92 .I pinterp
93 to simulate an aperture of 0.5 inches on a lens focused at a
94 distance of 57 inches:
95 .IP "" .2i
96 rpict -vf myview -x 640 -y 480 -z orig.zbf scene.oct > orig.pic
97 .br
98 pdfblur 0.5 57 8 orig.pic | pinterp -B -vf orig.pic -x 640 -y 480
99 orig.pic orig.zbf > blurry.pic
100 .PP
101 To use
102 .I rpict
103 exclusively to do the same:
104 .IP "" .2i
105 pdfblur .5 57 5 myview | rpict -S 1 -vf myview -x 640 -y 480
106 -o view%d.pic scene.oct
107 .br
108 pcomb -s .2 view1.pic -s .2 view2.pic -s .2 view3.pic -s .2
109 view4.pic -s .2 view5.pic > blurry.pic
110 .SH AUTHOR
111 Greg Ward
112 .SH BUGS
113 This program really only works with perspective views.
114 .SH "SEE ALSO"
115 pcomb(1), pinterp(1), pmblur(1), rcalc(1), rpict(1), vwright(1)
