1 |
.\" RCSid "$Id: pcond.1,v 1.4 2008/11/10 19:08:17 greg Exp $" |
2 |
.TH PCOND 1 10/27/98 RADIANCE |
3 |
.SH NAME |
4 |
pcond - condition a RADIANCE picture for output |
5 |
.SH SYNOPSIS |
6 |
.B pcond |
7 |
8 |
.B options |
9 |
10 |
.B input |
11 |
12 |
.B output |
13 |
14 |
.SH DESCRIPTION |
15 |
.I Pcond |
16 |
conditions a Radiance picture for output to a display or hard copy |
17 |
device. |
18 |
If the dynamic range of the scene exceeds that of the display (as is |
19 |
usually the case), |
20 |
.I pcond |
21 |
will compress the dynamic range of the picture such that both |
22 |
dark and bright regions are visible. |
23 |
In addition, certain limitations in human vision may be mimicked in |
24 |
order to provide an appearance similar to the experience one might |
25 |
have in the actual scene. |
26 |
.PP |
27 |
Command line switches turn flags off and on, changing program behavior. |
28 |
A switch given by itself toggles the flag from off to on or on to |
29 |
off depending on its previous state. |
30 |
A switch followed by a '+' turns the option on explicitly. |
31 |
A switch followed by a '-' turns the option off. |
32 |
The default is all switches off. |
33 |
Other options specify output device parameters in order to get more |
34 |
accurate color and contrast. |
35 |
.TP 10n |
36 |
.BI -h [+-] |
37 |
Mimic human visual response in the output. |
38 |
The goal of this process is to produce output that correlates |
39 |
strongly with a person's subjective impression of a scene. |
40 |
This switch is a bundle of the |
41 |
.I \-a, |
42 |
.I \-v, |
43 |
.I \-s |
44 |
and |
45 |
.I \-c |
46 |
options. |
47 |
.TP |
48 |
.BI -a [+-] |
49 |
Defocus darker regions of the image to simulate human visual acuity loss. |
50 |
This option will not affect well-lit scenes. |
51 |
.TP |
52 |
.BI -v [+-] |
53 |
Add veiling glare due to very bright regions in the image. |
54 |
This simulates internal scattering in the human eye, which |
55 |
results in a loss of visible contrast near bright sources. |
56 |
.TP |
57 |
.BI -s [+-] |
58 |
Use the human contrast sensitivity function in determining the |
59 |
exposure for the image. |
60 |
A darker scene will have relatively lower exposure with lower |
61 |
contrast than a well-lit scene. |
62 |
.TP |
63 |
.BI -c [+-] |
64 |
If parts of the image are in the mesopic or scotopic range where |
65 |
the cone photoreceptors lose their efficiency, this switch will |
66 |
cause a corresponding loss of color visibility in the output and a |
67 |
shift to a scotopic (blue-dominant) response function. |
68 |
.TP |
69 |
.BI -w [+-] |
70 |
Use a center-weighted average for the exposure rather than the |
71 |
default uniform average. |
72 |
This may improve the exposure for scenes with high or low peripheral |
73 |
brightness. |
74 |
.TP |
75 |
.BI -i \ fixfrac |
76 |
Set the relative importance of fixation points to |
77 |
.I fixfrac, |
78 |
which is a value between 0 and 1. |
79 |
If |
80 |
.I fixfrac |
81 |
is zero (the default), then no fixation points are used in |
82 |
determining the local or global adaptation. |
83 |
If |
84 |
.I fixfrac |
85 |
is greater than zero, then a list of fixation points is read from |
86 |
the standard input. |
87 |
These points are given as tab-separated (x,y) picture |
88 |
coordinates, such as those produced by the |
89 |
.I \-op |
90 |
option of |
91 |
.I ximage(1). |
92 |
The foveal samples about these fixation points will then be weighted |
93 |
together with the global averaging scheme such that the fixations receive |
94 |
.I fixfrac |
95 |
of the total weight. |
96 |
If |
97 |
.I fixfrac |
98 |
is one, then only the fixation points are considered for |
99 |
adaptation. |
100 |
.TP |
101 |
.BI -I [+-] |
102 |
Rather than computing a histogram of foveal samples from the source picture, |
103 |
use the precomputed histogram provided on the standard input. |
104 |
This data should be given in pairs of the base-10 logarithm of |
105 |
world luminance and a count for each bin in ascending order, as |
106 |
computed by the |
107 |
.I phisto(1) |
108 |
script. |
109 |
This option is useful for producing identical exposures of multiple |
110 |
pictures (as in an animation), and provides greater control |
111 |
over the histogram computation. |
112 |
.TP |
113 |
.BI -l [+-] |
114 |
Use a linear response function rather than the standard dynamic |
115 |
range compression algorithm. |
116 |
This will prevent the loss of usable physical values in the output |
117 |
picture, although some parts of the resulting image may be too |
118 |
dark or too bright to see. |
119 |
.TP |
120 |
.BI -e \ expval |
121 |
Set the exposure adjustment for the picture to |
122 |
.I expval. |
123 |
This may either be a real multiplier, or a (fractional) number of |
124 |
f-stops preceeded by a '+' or '-'. |
125 |
This option implies a linear response (see the |
126 |
.I \-l |
127 |
option above). |
128 |
.TP |
129 |
.BI -u \ Ldmax |
130 |
Specifies the top of the luminance range for the target output device. |
131 |
That is, the luminance (in candelas/m^2) for an output pixel value |
132 |
of (R,G,B)=(1,1,1). |
133 |
The default value is 100 cd/m^2. |
134 |
.TP |
135 |
.BI -d \ Lddyn |
136 |
Specifies the dynamic range for the target output device, which is |
137 |
the ratio of the maximum and minimum usable display luminances. |
138 |
The default value is 100. |
139 |
.TP |
140 |
.BI -p " xr yr xg yg xb yb xw yw" |
141 |
Specifies the RGB primaries for the target output device. |
142 |
These are the 1931 CIE (x,y) chromaticity values for red, green, |
143 |
blue and white, respectively. |
144 |
.TP |
145 |
.BI -f \ macbeth.cal |
146 |
Use the given output file from |
147 |
.I macbethcal(1) |
148 |
to precorrect the color and contrast for the target output device. |
149 |
This does a more thorough job than a simple primary correction |
150 |
using the |
151 |
.I \-p |
152 |
option. |
153 |
Only one of |
154 |
.I \-f |
155 |
or |
156 |
.I \-p |
157 |
may be given. |
158 |
.TP |
159 |
.BI -x \ mapfile |
160 |
Put out the final mapping from world luminance to display luminance to |
161 |
.I mapfile. |
162 |
This file will contain values from the minimum usable world |
163 |
luminance to the maximum (in candelas/m^2) in one column, and their |
164 |
corresponding display luminance values (also in candelas/m^2) in the |
165 |
second column. |
166 |
This file may be used for debugging purposes, or to plot the mapping |
167 |
function created by |
168 |
.I pcond. |
169 |
.SH EXAMPLES |
170 |
To display an image as a person might perceive it |
171 |
in the actual scene: |
172 |
.IP "" .2i |
173 |
pcond \-h final.hdr > display.hdr |
174 |
.br |
175 |
ximage display.hdr ; rm display.hdr & |
176 |
.PP |
177 |
To do the same on a 24\-bit display with known primary values: |
178 |
.IP "" .2i |
179 |
setenv DISPLAY_PRIMARIES ".580 .340 .281 .570 .153 .079 .333 .333" |
180 |
.br |
181 |
pcond \-h \-p $DISPLAY_PRIMARIES final.hdr | ximage & |
182 |
.PP |
183 |
To prepare a picture to be sent to a film recorder destined eventually |
184 |
for a slide projector with a minimum and maximum screen luminance of |
185 |
1.5 and 125 candelas/m^2, respectively: |
186 |
.IP "" .2i |
187 |
pcond \-d 83 \-u 125 final.hdr > film.hdr |
188 |
.PP |
189 |
To do the same if the output colors of the standard image |
190 |
"ray/lib/lib/macbeth_spec.hdr" have been measured: |
191 |
.IP "" .2i |
192 |
macbethcal \-c mbfilm.xyY > film.cal |
193 |
.br |
194 |
pcond \-d 83 \-u 125 \-f film.cal final.hdr > film.hdr |
195 |
.PP |
196 |
To further tweak the exposure to bring out certain areas indicated by |
197 |
dragging the right mouse button over them in |
198 |
.I ximage: |
199 |
.IP "" .2i |
200 |
ximage \-op \-t 75 final.hdr | pcond \-i .5 \-d 83 \-u 125 \-f film.cal |
201 |
202 |
.PP |
203 |
To use a histogram computed on every 10th animation frame: |
204 |
.IP "" .2i |
205 |
phisto frame*0.hdr > global.hist |
206 |
.br |
207 |
pcond \-I \-s \-c frame0352.hdr < global.hist | ra_tiff \- frame0352.tif |
208 |
.SH REFERENCE |
209 |
Greg Ward Larson, Holly Rushmeier, Christine Piatko, |
210 |
``A Visibility Matching Tone Reproduction Operator for High Dynamic Range |
211 |
Scenes,'' |
212 |
.I "IEEE Transactions on Visualization and Computer Graphics", |
213 |
December 1997. |
214 |
.PP |
215 |
http://www.sgi.com/Technology/pixformat/Larsonetal.html |
216 |
.SH AUTHOR |
217 |
Greg Ward Larson |
218 |
.SH "SEE ALSO" |
219 |
getinfo(1), macbethcal(1), normtiff(1), |
220 |
pcompos(1), pflip(1), phisto(1), pinterp(1), |
221 |
pvalue(1), protate(1), ra_xyze(1), rad(1), rpict(1), ximage(1) |
