1 |
.\" RCSid "$Id: pcompos.1,v 1.5 2008/11/10 19:08:17 greg Exp $" |
2 |
.TH PCOMPOS 1 12/18/97 RADIANCE |
3 |
.SH NAME |
4 |
pcompos - composite RADIANCE pictures. |
5 |
.SH SYNOPSIS |
6 |
.B pcompos |
7 |
8 |
.B \-h |
9 |
10 |
.B "\-x xres" |
11 |
12 |
.B "\-y yres" |
13 |
14 |
.B "\-b r g b" |
15 |
16 |
.B "\-lh h" |
17 |
18 |
.B \-la |
19 |
20 |
21 |
.B "\-t min1" |
22 |
23 |
.B "\+t max1" |
24 |
25 |
.B "\-l lab" |
26 |
27 |
.B "=SS" |
28 |
29 |
.B "pic1 x1 y1 .." |
30 |
.br |
31 |
or |
32 |
.br |
33 |
.B pcompos |
34 |
35 |
.B "\-a ncols" |
36 |
37 |
.B "\-s spacing" |
38 |
39 |
.B "\-o x0 y0" |
40 |
41 |
options |
42 |
43 |
.B "pic1 pic2 .." |
44 |
.SH DESCRIPTION |
45 |
.I Pcompos |
46 |
arranges and composites RADIANCE pictures and sends the result to the |
47 |
standard output. |
48 |
Each input picture must be accompanied by an anchor point (unless the |
49 |
.I \-a |
50 |
option is used, see below). |
51 |
This anchor point is the usually position of the picture's |
52 |
left lower corner in the final output, but can be changed |
53 |
for individual pictures with an |
54 |
.I =SS |
55 |
option, where |
56 |
.I S |
57 |
is one of '-', '+' or '0', indicating the minimum, maximum or center |
58 |
of the image, respectively. |
59 |
(For example, |
60 |
.I =+- |
61 |
would indicate the anchor is relative to the right lower corner, and |
62 |
.I =-0 |
63 |
would indicate the anchor is relative to the center of the left |
64 |
edge.)\0 |
65 |
Negative anchor coordinates result in the input being cropped at the origin. |
66 |
By default, the size of the output picture will be just large enough |
67 |
to encompass all the input files. |
68 |
By specifying a smaller dimension using the |
69 |
.I \-x |
70 |
and |
71 |
.I \-y |
72 |
options, input files can be cropped at the upper boundary. |
73 |
Specifying a larger dimension produces a border. |
74 |
The |
75 |
.I \-b |
76 |
option specifies a background color to appear wherever input |
77 |
files do not cover. |
78 |
The default value is black (0 0 0). |
79 |
The |
80 |
.I \-h |
81 |
option may be used to reduce the information header size, which |
82 |
can grow disproportionately after multiple runs of |
83 |
.I pcompos |
84 |
and/or |
85 |
.I pcomb(1). |
86 |
.PP |
87 |
If input files overlap, later pictures will overwrite earlier ones. |
88 |
By default, input files are copied unconditionally within the output |
89 |
boundaries. |
90 |
The |
91 |
.I \-t |
92 |
option specifies a lower threshold intensity under which input pixels |
93 |
will not be copied to the output. |
94 |
The |
95 |
.I \+t |
96 |
option specifies an upper threshold. |
97 |
These options are useful for cutting around irregular boundaries in |
98 |
the input. |
99 |
.PP |
100 |
The |
101 |
.I \-l |
102 |
option can be used to specify a label for a specific picture, which |
103 |
will be given a height determined by the |
104 |
.I \-lh |
105 |
option (default 24 pixels) and placed in the upper left corner of |
106 |
the picture. |
107 |
This label is generated by the program |
108 |
.I psign(1). |
109 |
The |
110 |
.I \-la |
111 |
option instructs |
112 |
.I pcompos |
113 |
to label each picture automatically by its name. |
114 |
This is particularly useful in conjunction with the |
115 |
.I \-a |
116 |
option for producing a catalog of images (see example below). |
117 |
The |
118 |
.I \-l |
119 |
option may still be used to override the default label |
120 |
for a picture. |
121 |
.PP |
122 |
The |
123 |
.I \-a |
124 |
option can be used to automatically compute anchor points |
125 |
that place successive pictures next to each other in |
126 |
.I ncols |
127 |
columns. |
128 |
The ordering will place the first picture in the lower left corner, |
129 |
the next just to the right of it, and so on for |
130 |
.I ncols |
131 |
pictures. |
132 |
Then, the next row up repeats the pattern until all the input |
133 |
pictures have been added to the output. |
134 |
If the pictures are of different size, |
135 |
.I pcompos |
136 |
will end up leaving some background areas in the output picture. |
137 |
There will also be an unfinished row at the top if the number |
138 |
of pictures is not evenly divided by |
139 |
.I ncols. |
140 |
The |
141 |
.I "\-s N" |
142 |
option will cause each image to be separated by at least N pixels. |
143 |
The |
144 |
.I "\-o x0 y0" |
145 |
option specifies a nonzero anchor point for the bottom left image. |
146 |
.PP |
147 |
The standard input can be specified with a hyphen ('-'). |
148 |
A command that produces a RADIANCE picture can be given in place of a file |
149 |
by preceeding it with an exclamation point ('!'). |
150 |
.SH EXAMPLE |
151 |
To put a copyright label at the bottom of a picture: |
152 |
.IP "" .2i |
153 |
psign Copyright 1987 | pcompos inp.hdr 0 0 +t .5 - 384 64 > out.hdr |
154 |
.PP |
155 |
To make a catalog of images separated by white 10-pixel borders: |
156 |
.IP "" .2i |
157 |
pcompos \-la \-a 4 \-s 10 \-b 1 1 1 dog*.hdr > alldogs.hdr |
158 |
.SH NOTES |
159 |
Since there is a limit to the number of open files and processes, |
160 |
large collections of images must be created in stages. |
161 |
Even if the system limit on open files is large, |
162 |
.I pcompos |
163 |
places an artificial limit of 1024 on the number of open files and/or |
164 |
processes. |
165 |
.SH AUTHOR |
166 |
Greg Ward |
167 |
.SH "SEE ALSO" |
168 |
getinfo(1), pcomb(1), pfilt(1), psign(1), rpict(1) |
