| 1 |
.\" RCSid "$Id: pcompos.1,v 1.4 2007/09/04 17:36:40 greg Exp $"
| 2 |
.TH PCOMPOS 1 12/18/97 RADIANCE
| 3 |
.SH NAME
| 4 |
pcompos - composite RADIANCE pictures.
| 5 |
.SH SYNOPSIS
| 6 |
.B pcompos
| 7 |
| 8 |
.B \-h
| 9 |
| 10 |
.B "\-x xres"
| 11 |
| 12 |
.B "\-y yres"
| 13 |
| 14 |
.B "\-b r g b"
| 15 |
| 16 |
.B "\-lh h"
| 17 |
| 18 |
.B \-la
| 19 |
| 20 |
| 21 |
.B "\-t min1"
| 22 |
| 23 |
.B "\+t max1"
| 24 |
| 25 |
.B "\-l lab"
| 26 |
| 27 |
.B "=SS"
| 28 |
| 29 |
.B "pic1 x1 y1 .."
| 30 |
.br
| 31 |
or
| 32 |
.br
| 33 |
.B pcompos
| 34 |
| 35 |
.B "\-a ncols"
| 36 |
| 37 |
.B "\-s spacing"
| 38 |
| 39 |
.B "\-o x0 y0"
| 40 |
| 41 |
options
| 42 |
| 43 |
.B "pic1 pic2 .."
| 44 |
.SH DESCRIPTION
| 45 |
.I Pcompos
| 46 |
arranges and composites RADIANCE pictures and sends the result to the
| 47 |
standard output.
| 48 |
Each input picture must be accompanied by an anchor point (unless the
| 49 |
.I \-a
| 50 |
option is used, see below).
| 51 |
This anchor point is the usually position of the picture's
| 52 |
left lower corner in the final output, but can be changed
| 53 |
for individual pictures with an
| 54 |
.I =SS
| 55 |
option, where
| 56 |
.I S
| 57 |
is one of '-', '+' or '0', indicating the minimum, maximum or center
| 58 |
of the image, respectively.
| 59 |
(For example,
| 60 |
.I =+-
| 61 |
would indicate the anchor is relative to the right lower corner, and
| 62 |
.I =-0
| 63 |
would indicate the anchor is relative to the center of the left
| 64 |
edge.)\0
| 65 |
Negative anchor coordinates result in the input being cropped at the origin.
| 66 |
By default, the size of the output picture will be just large enough
| 67 |
to encompass all the input files.
| 68 |
By specifying a smaller dimension using the
| 69 |
.I \-x
| 70 |
and
| 71 |
.I \-y
| 72 |
options, input files can be cropped at the upper boundary.
| 73 |
Specifying a larger dimension produces a border.
| 74 |
The
| 75 |
.I \-b
| 76 |
option specifies a background color to appear wherever input
| 77 |
files do not cover.
| 78 |
The default value is black (0 0 0).
| 79 |
The
| 80 |
.I \-h
| 81 |
option may be used to reduce the information header size, which
| 82 |
can grow disproportionately after multiple runs of
| 83 |
.I pcompos
| 84 |
and/or
| 85 |
.I pcomb(1).
| 86 |
.PP
| 87 |
If input files overlap, later pictures will overwrite earlier ones.
| 88 |
By default, input files are copied unconditionally within the output
| 89 |
boundaries.
| 90 |
The
| 91 |
.I \-t
| 92 |
option specifies a lower threshold intensity under which input pixels
| 93 |
will not be copied to the output.
| 94 |
The
| 95 |
.I \+t
| 96 |
option specifies an upper threshold.
| 97 |
These options are useful for cutting around irregular boundaries in
| 98 |
the input.
| 99 |
.PP
| 100 |
The
| 101 |
.I \-l
| 102 |
option can be used to specify a label for a specific picture, which
| 103 |
will be given a height determined by the
| 104 |
.I \-lh
| 105 |
option (default 24 pixels) and placed in the upper left corner of
| 106 |
the picture.
| 107 |
This label is generated by the program
| 108 |
.I psign(1).
| 109 |
The
| 110 |
.I \-la
| 111 |
option instructs
| 112 |
.I pcompos
| 113 |
to label each picture automatically by its name.
| 114 |
This is particularly useful in conjunction with the
| 115 |
.I \-a
| 116 |
option for producing a catalog of images (see example below).
| 117 |
The
| 118 |
.I \-l
| 119 |
option may still be used to override the default label
| 120 |
for a picture.
| 121 |
.PP
| 122 |
The
| 123 |
.I \-a
| 124 |
option can be used to automatically compute anchor points
| 125 |
that place successive pictures next to each other in
| 126 |
.I ncols
| 127 |
columns.
| 128 |
The ordering will place the first picture in the lower left corner,
| 129 |
the next just to the right of it, and so on for
| 130 |
.I ncols
| 131 |
pictures.
| 132 |
Then, the next row up repeats the pattern until all the input
| 133 |
pictures have been added to the output.
| 134 |
If the pictures are of different size,
| 135 |
.I pcompos
| 136 |
will end up leaving some background areas in the output picture.
| 137 |
There will also be an unfinished row at the top if the number
| 138 |
of pictures is not evenly divided by
| 139 |
.I ncols.
| 140 |
The
| 141 |
.I "\-s N"
| 142 |
option will cause each image to be separated by at least N pixels.
| 143 |
The
| 144 |
.I "\-o x0 y0"
| 145 |
option specifies a nonzero anchor point for the bottom left image.
| 146 |
.PP
| 147 |
The standard input can be specified with a hyphen ('-').
| 148 |
A command that produces a RADIANCE picture can be given in place of a file
| 149 |
by preceeding it with an exclamation point ('!').
| 150 |
.SH EXAMPLE
| 151 |
To put a copyright label at the bottom of a picture:
| 152 |
.IP "" .2i
| 153 |
psign Copyright 1987 | pcompos inp.hdr 0 0 +t .5 - 384 64 > out.hdr
| 154 |
.PP
| 155 |
To make a catalog of images separated by white 10-pixel borders:
| 156 |
.IP "" .2i
| 157 |
pcompos \-la \-a 4 \-s 10 \-b 1 1 1 dog*.hdr > alldogs.hdr
| 158 |
.SH NOTES
| 159 |
Since there is a limit to the number of open files and processes,
| 160 |
large collections of images must be created in stages.
| 161 |
Even if the system limit on open files is large,
| 162 |
.I pcompos
| 163 |
places an artificial limit of 64 on the number of open files and/or
| 164 |
processes.
| 165 |
.SH AUTHOR
| 166 |
Greg Ward
| 167 |
.SH "SEE ALSO"
| 168 |
getinfo(1), pcomb(1), pfilt(1), psign(1), rpict(1)
