1 |
.\" RCSid "$Id$" |
2 |
.TH PCOMPOS 1 12/18/97 RADIANCE |
3 |
.SH NAME |
4 |
pcompos - composite RADIANCE pictures. |
5 |
.SH SYNOPSIS |
6 |
.B pcompos |
7 |
8 |
.B "\-x xres" |
9 |
10 |
.B "\-y yres" |
11 |
12 |
.B "\-b r g b" |
13 |
14 |
.B "\-lh h" |
15 |
16 |
.B \-la |
17 |
18 |
19 |
.B "\-t min1" |
20 |
21 |
.B "\+t max1" |
22 |
23 |
.B "\-l lab" |
24 |
25 |
.B "=SS" |
26 |
27 |
.B "pic1 x1 y1 .." |
28 |
.br |
29 |
or |
30 |
.br |
31 |
.B pcompos |
32 |
33 |
.B "\-a ncols" |
34 |
35 |
.B "\-s spacing" |
36 |
37 |
.B "\-o x0 y0" |
38 |
39 |
options |
40 |
41 |
.B "pic1 pic2 .." |
42 |
.SH DESCRIPTION |
43 |
.I Pcompos |
44 |
arranges and composites RADIANCE pictures and sends the result to the |
45 |
standard output. |
46 |
Each input picture must be accompanied by an anchor point (unless the |
47 |
.I \-a |
48 |
option is used, see below). |
49 |
This anchor point is the usually position of the picture's |
50 |
left lower corner in the final output, but can be changed |
51 |
for individual pictures with an |
52 |
.I =SS |
53 |
option, where |
54 |
.I S |
55 |
is one of '-', '+' or '0', indicating the minimum, maximum or center |
56 |
of the image, respectively. |
57 |
(For example, |
58 |
.I =+- |
59 |
would indicate the anchor is relative to the right lower corner, and |
60 |
.I =-0 |
61 |
would indicate the anchor is relative to the center of the left |
62 |
edge.)\0 |
63 |
Negative anchor coordinates result in the input being cropped at the origin. |
64 |
By default, the size of the output picture will be just large enough |
65 |
to encompass all the input files. |
66 |
By specifying a smaller dimension using the |
67 |
.I \-x |
68 |
and |
69 |
.I \-y |
70 |
options, input files can be cropped at the upper boundary. |
71 |
Specifying a larger dimension produces a border. |
72 |
The |
73 |
.I \-b |
74 |
option specifies a background color to appear wherever input |
75 |
files do not cover. |
76 |
The default value is black (0 0 0). |
77 |
.PP |
78 |
If input files overlap, later pictures will overwrite earlier ones. |
79 |
By default, input files are copied unconditionally within the output |
80 |
boundaries. |
81 |
The |
82 |
.I \-t |
83 |
option specifies a lower threshold intensity under which input pixels |
84 |
will not be copied to the output. |
85 |
The |
86 |
.I \+t |
87 |
option specifies an upper threshold. |
88 |
These options are useful for cutting around irregular boundaries in |
89 |
the input. |
90 |
.PP |
91 |
The |
92 |
.I \-l |
93 |
option can be used to specify a label for a specific picture, which |
94 |
will be given a height determined by the |
95 |
.I \-lh |
96 |
option (default 24 pixels) and placed in the upper left corner of |
97 |
the picture. |
98 |
This label is generated by the program |
99 |
.I psign(1). |
100 |
The |
101 |
.I \-la |
102 |
option instructs |
103 |
.I pcompos |
104 |
to label each picture automatically by its name. |
105 |
This is particularly useful in conjunction with the |
106 |
.I \-a |
107 |
option for producing a catalog of images (see example below). |
108 |
The |
109 |
.I \-l |
110 |
option may still be used to override the default label |
111 |
for a picture. |
112 |
.PP |
113 |
The |
114 |
.I \-a |
115 |
option can be used to automatically compute anchor points |
116 |
that place successive pictures next to each other in |
117 |
.I ncols |
118 |
columns. |
119 |
The ordering will place the first picture in the lower left corner, |
120 |
the next just to the right of it, and so on for |
121 |
.I ncols |
122 |
pictures. |
123 |
Then, the next row up repeats the pattern until all the input |
124 |
pictures have been added to the output. |
125 |
If the pictures are of different size, |
126 |
.I pcompos |
127 |
will end up leaving some background areas in the output picture. |
128 |
There will also be an unfinished row at the top if the number |
129 |
of pictures is not evenly divided by |
130 |
.I ncols. |
131 |
The |
132 |
.I "\-s N" |
133 |
option will cause each image to be separated by at least N pixels. |
134 |
The |
135 |
.I "\-o x0 y0" |
136 |
option specifies a nonzero anchor point for the bottom left image. |
137 |
.PP |
138 |
The standard input can be specified with a hyphen ('-'). |
139 |
A command that produces a RADIANCE picture can be given in place of a file |
140 |
by preceeding it with an exclamation point ('!'). |
141 |
.SH EXAMPLE |
142 |
To put a copyright label at the bottom of a picture: |
143 |
.IP "" .2i |
144 |
psign Copyright 1987 | pcompos pic.inp 0 0 +t .5 - 384 64 > pic.out |
145 |
.PP |
146 |
To make a catalog of images separated by white 10-pixel borders: |
147 |
.IP "" .2i |
148 |
pcompos -la -a 4 -s 10 -b 1 1 1 dog*.pic > alldogs.pic |
149 |
.SH NOTES |
150 |
Since there is a limit to the number of open files and processes, |
151 |
large collections of images must be created in stages. |
152 |
Even if the system limit on open files is large, |
153 |
.I pcompos |
154 |
places an artificial limit of 64 on the number of open files and/or |
155 |
processes. |
156 |
.SH AUTHOR |
157 |
Greg Ward |
158 |
.SH "SEE ALSO" |
159 |
getinfo(1), pfilt(1), psign(1), rpict(1) |
