root/radiance/ray/doc/man/man1/pcompos.1
Revision: 1.2
Committed: Tue Dec 9 15:59:06 2003 UTC (21 years, 6 months ago) by greg
CVS Tags: rad3R7P2, rad3R7P1, rad3R6, rad3R6P1
Fixed RCSid specification
1 .\" RCSid "$Id$"
2 .TH PCOMPOS 1 12/18/97 RADIANCE
3 .SH NAME
4 pcompos - composite RADIANCE pictures.
5 .SH SYNOPSIS
6 .B pcompos
7 [
8 .B "\-x xres"
9 ][
10 .B "\-y yres"
11 ][
12 .B "\-b r g b"
13 ][
14 .B "\-lh h"
15 ][
16 .B \-la
17 ]
18 [
19 .B "\-t min1"
20 ][
21 .B "\+t max1"
22 ][
23 .B "\-l lab"
24 ][
25 .B "=SS"
26 ]
27 .B "pic1 x1 y1 .."
28 .br
29 or
30 .br
31 .B pcompos
32 [
33 .B "\-a ncols"
34 ][
35 .B "\-s spacing"
36 ][
37 .B "\-o x0 y0"
38 ][
39 options
40 ]
41 .B "pic1 pic2 .."
42 .SH DESCRIPTION
43 .I Pcompos
44 arranges and composites RADIANCE pictures and sends the result to the
45 standard output.
46 Each input picture must be accompanied by an anchor point (unless the
47 .I \-a
48 option is used, see below).
49 This anchor point is the usually position of the picture's
50 left lower corner in the final output, but can be changed
51 for individual pictures with an
52 .I =SS
53 option, where
54 .I S
55 is one of '-', '+' or '0', indicating the minimum, maximum or center
56 of the image, respectively.
57 (For example,
58 .I =+-
59 would indicate the anchor is relative to the right lower corner, and
60 .I =-0
61 would indicate the anchor is relative to the center of the left
62 edge.)\0
63 Negative anchor coordinates result in the input being cropped at the origin.
64 By default, the size of the output picture will be just large enough
65 to encompass all the input files.
66 By specifying a smaller dimension using the
67 .I \-x
68 and
69 .I \-y
70 options, input files can be cropped at the upper boundary.
71 Specifying a larger dimension produces a border.
72 The
73 .I \-b
74 option specifies a background color to appear wherever input
75 files do not cover.
76 The default value is black (0 0 0).
77 .PP
78 If input files overlap, later pictures will overwrite earlier ones.
79 By default, input files are copied unconditionally within the output
80 boundaries.
81 The
82 .I \-t
83 option specifies a lower threshold intensity under which input pixels
84 will not be copied to the output.
85 The
86 .I \+t
87 option specifies an upper threshold.
88 These options are useful for cutting around irregular boundaries in
89 the input.
90 .PP
91 The
92 .I \-l
93 option can be used to specify a label for a specific picture, which
94 will be given a height determined by the
95 .I \-lh
96 option (default 24 pixels) and placed in the upper left corner of
97 the picture.
98 This label is generated by the program
99 .I psign(1).
100 The
101 .I \-la
102 option instructs
103 .I pcompos
104 to label each picture automatically by its name.
105 This is particularly useful in conjunction with the
106 .I \-a
107 option for producing a catalog of images (see example below).
108 The
109 .I \-l
110 option may still be used to override the default label
111 for a picture.
112 .PP
113 The
114 .I \-a
115 option can be used to automatically compute anchor points
116 that place successive pictures next to each other in
117 .I ncols
118 columns.
119 The ordering will place the first picture in the lower left corner,
120 the next just to the right of it, and so on for
121 .I ncols
122 pictures.
123 Then, the next row up repeats the pattern until all the input
124 pictures have been added to the output.
125 If the pictures are of different size,
126 .I pcompos
127 will end up leaving some background areas in the output picture.
128 There will also be an unfinished row at the top if the number
129 of pictures is not evenly divided by
130 .I ncols.
131 The
132 .I "\-s N"
133 option will cause each image to be separated by at least N pixels.
134 The
135 .I "\-o x0 y0"
136 option specifies a nonzero anchor point for the bottom left image.
137 .PP
138 The standard input can be specified with a hyphen ('-').
139 A command that produces a RADIANCE picture can be given in place of a file
140 by preceeding it with an exclamation point ('!').
141 .SH EXAMPLE
142 To put a copyright label at the bottom of a picture:
143 .IP "" .2i
144 psign Copyright 1987 | pcompos pic.inp 0 0 +t .5 - 384 64 > pic.out
145 .PP
146 To make a catalog of images separated by white 10-pixel borders:
147 .IP "" .2i
148 pcompos -la -a 4 -s 10 -b 1 1 1 dog*.pic > alldogs.pic
149 .SH NOTES
150 Since there is a limit to the number of open files and processes,
151 large collections of images must be created in stages.
152 Even if the system limit on open files is large,
153 .I pcompos
154 places an artificial limit of 64 on the number of open files and/or
155 processes.
156 .SH AUTHOR
157 Greg Ward
158 .SH "SEE ALSO"
159 getinfo(1), pfilt(1), psign(1), rpict(1)
