| 1 |
greg |
1.9 |
.\" RCSid "$Id: pcompos.1,v 1.8 2022/03/15 00:25:50 greg Exp $" |
| 2 |
greg |
1.1 |
.TH PCOMPOS 1 12/18/97 RADIANCE |
| 3 |
.SH NAME |
| 4 |
pcompos - composite RADIANCE pictures. |
| 5 |
.SH SYNOPSIS |
| 6 |
.B pcompos |
| 7 |
| 8 |
greg |
1.3 |
.B \-h |
| 9 |
| 10 |
greg |
1.1 |
.B "\-x xres" |
| 11 |
| 12 |
.B "\-y yres" |
| 13 |
| 14 |
.B "\-b r g b" |
| 15 |
| 16 |
.B "\-lh h" |
| 17 |
| 18 |
.B \-la |
| 19 |
| 20 |
| 21 |
.B "\-t min1" |
| 22 |
| 23 |
.B "\+t max1" |
| 24 |
| 25 |
.B "\-l lab" |
| 26 |
| 27 |
.B "=SS" |
| 28 |
| 29 |
.B "pic1 x1 y1 .." |
| 30 |
.br |
| 31 |
or |
| 32 |
.br |
| 33 |
.B pcompos |
| 34 |
| 35 |
.B "\-a ncols" |
| 36 |
| 37 |
.B "\-s spacing" |
| 38 |
| 39 |
.B "\-o x0 y0" |
| 40 |
| 41 |
options |
| 42 |
| 43 |
.B "pic1 pic2 .." |
| 44 |
.SH DESCRIPTION |
| 45 |
.I Pcompos |
| 46 |
arranges and composites RADIANCE pictures and sends the result to the |
| 47 |
standard output. |
| 48 |
Each input picture must be accompanied by an anchor point (unless the |
| 49 |
.I \-a |
| 50 |
option is used, see below). |
| 51 |
This anchor point is the usually position of the picture's |
| 52 |
left lower corner in the final output, but can be changed |
| 53 |
for individual pictures with an |
| 54 |
.I =SS |
| 55 |
option, where |
| 56 |
.I S |
| 57 |
is one of '-', '+' or '0', indicating the minimum, maximum or center |
| 58 |
of the image, respectively. |
| 59 |
(For example, |
| 60 |
.I =+- |
| 61 |
would indicate the anchor is relative to the right lower corner, and |
| 62 |
.I =-0 |
| 63 |
would indicate the anchor is relative to the center of the left |
| 64 |
edge.)\0 |
| 65 |
Negative anchor coordinates result in the input being cropped at the origin. |
| 66 |
By default, the size of the output picture will be just large enough |
| 67 |
to encompass all the input files. |
| 68 |
By specifying a smaller dimension using the |
| 69 |
.I \-x |
| 70 |
and |
| 71 |
.I \-y |
| 72 |
options, input files can be cropped at the upper boundary. |
| 73 |
Specifying a larger dimension produces a border. |
| 74 |
The |
| 75 |
.I \-b |
| 76 |
option specifies a background color to appear wherever input |
| 77 |
files do not cover. |
| 78 |
The default value is black (0 0 0). |
| 79 |
greg |
1.3 |
The |
| 80 |
.I \-h |
| 81 |
option may be used to reduce the information header size, which |
| 82 |
can grow disproportionately after multiple runs of |
| 83 |
.I pcompos |
| 84 |
and/or |
| 85 |
.I pcomb(1). |
| 86 |
greg |
1.1 |
.PP |
| 87 |
If input files overlap, later pictures will overwrite earlier ones. |
| 88 |
By default, input files are copied unconditionally within the output |
| 89 |
boundaries. |
| 90 |
The |
| 91 |
.I \-t |
| 92 |
option specifies a lower threshold intensity under which input pixels |
| 93 |
will not be copied to the output. |
| 94 |
The |
| 95 |
.I \+t |
| 96 |
option specifies an upper threshold. |
| 97 |
These options are useful for cutting around irregular boundaries in |
| 98 |
the input. |
| 99 |
.PP |
| 100 |
The |
| 101 |
.I \-l |
| 102 |
option can be used to specify a label for a specific picture, which |
| 103 |
will be given a height determined by the |
| 104 |
.I \-lh |
| 105 |
option (default 24 pixels) and placed in the upper left corner of |
| 106 |
the picture. |
| 107 |
This label is generated by the program |
| 108 |
.I psign(1). |
| 109 |
The |
| 110 |
.I \-la |
| 111 |
option instructs |
| 112 |
.I pcompos |
| 113 |
to label each picture automatically by its name. |
| 114 |
This is particularly useful in conjunction with the |
| 115 |
.I \-a |
| 116 |
option for producing a catalog of images (see example below). |
| 117 |
The |
| 118 |
.I \-l |
| 119 |
option may still be used to override the default label |
| 120 |
for a picture. |
| 121 |
.PP |
| 122 |
The |
| 123 |
.I \-a |
| 124 |
option can be used to automatically compute anchor points |
| 125 |
that place successive pictures next to each other in |
| 126 |
.I ncols |
| 127 |
columns. |
| 128 |
The ordering will place the first picture in the lower left corner, |
| 129 |
the next just to the right of it, and so on for |
| 130 |
.I ncols |
| 131 |
pictures. |
| 132 |
Then, the next row up repeats the pattern until all the input |
| 133 |
pictures have been added to the output. |
| 134 |
If the pictures are of different size, |
| 135 |
.I pcompos |
| 136 |
will end up leaving some background areas in the output picture. |
| 137 |
There will also be an unfinished row at the top if the number |
| 138 |
of pictures is not evenly divided by |
| 139 |
.I ncols. |
| 140 |
The |
| 141 |
.I "\-s N" |
| 142 |
option will cause each image to be separated by at least N pixels. |
| 143 |
The |
| 144 |
.I "\-o x0 y0" |
| 145 |
option specifies a nonzero anchor point for the bottom left image. |
| 146 |
greg |
1.7 |
If a negative value is given for ncols, then the rows are reversed, |
| 147 |
so they start from the top rather than the bottom. |
| 148 |
This gives a more natural ordering in most cases, but has the |
| 149 |
side-effect of moving any labels from the upper-left of each placed |
| 150 |
subimage to the lower-left. |
| 151 |
Also, the |
| 152 |
.I \-o |
| 153 |
option is interpreted differently, where the y0 value is number of |
| 154 |
pixels from the top (rather than the bottom). |
| 155 |
greg |
1.1 |
.PP |
| 156 |
The standard input can be specified with a hyphen ('-'). |
| 157 |
A command that produces a RADIANCE picture can be given in place of a file |
| 158 |
by preceeding it with an exclamation point ('!'). |
| 159 |
.SH EXAMPLE |
| 160 |
To put a copyright label at the bottom of a picture: |
| 161 |
.IP "" .2i |
| 162 |
greg |
1.5 |
psign Copyright 1987 | pcompos inp.hdr 0 0 +t .5 - 384 64 > out.hdr |
| 163 |
greg |
1.1 |
.PP |
| 164 |
greg |
1.7 |
To make a catalog of images separated by white 10-pixel borders and |
| 165 |
ordered four images per row starting from the top-left: |
| 166 |
greg |
1.1 |
.IP "" .2i |
| 167 |
greg |
1.7 |
pcompos -la -a -4 -s 10 -b 1 1 1 dog*.hdr > alldogs.hdr |
| 168 |
greg |
1.1 |
.SH NOTES |
| 169 |
Since there is a limit to the number of open files and processes, |
| 170 |
large collections of images must be created in stages. |
| 171 |
Even if the system limit on open files is large, |
| 172 |
.I pcompos |
| 173 |
greg |
1.6 |
places an artificial limit of 1024 on the number of open files and/or |
| 174 |
greg |
1.1 |
processes. |
| 175 |
greg |
1.9 |
.PP |
| 176 |
The EXPOSURE= line is ignored on the input except when there is only |
| 177 |
a single input picture, or mutliple pictures all have the same |
| 178 |
exposure value. |
| 179 |
In such cases, |
| 180 |
.I pcompos |
| 181 |
will echo the exposure line to the output header appropriately, |
| 182 |
so that absolute calibration is maintained. |
| 183 |
greg |
1.1 |
.SH AUTHOR |
| 184 |
Greg Ward |
| 185 |
.SH "SEE ALSO" |
| 186 |
greg |
1.8 |
getinfo(1), pcomb(1), pfilt(1), psign(1), rcrop(1), rpict(1) |
