--- ray/doc/man/man1/pcomb.1 2018/02/05 20:07:17 1.10 +++ ray/doc/man/man1/pcomb.1 2023/12/06 01:27:00 1.13 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: pcomb.1,v 1.10 2018/02/05 20:07:17 greg Exp $" +.\" RCSid "$Id: pcomb.1,v 1.13 2023/12/06 01:27:00 greg Exp $" .TH PCOMB 1 8/31/96 RADIANCE .SH NAME pcomb - combine RADIANCE pictures @@ -42,6 +42,10 @@ but an arbitrary mapping can be assigned with the and .I \-f options. +(The variable and function definitions in each +.I \-f source +file are read and compiled from the RADIANCE library +where it is found.)\0 Negative coefficients and functions are allowed, and .I pcomb will produce color values of zero where they would be negative. @@ -115,6 +119,9 @@ give the exposure values for picture and .I pa(n) gives the corresponding pixel aspect ratio. +Exposure values will be set to 1.0 for inputs with the +.I \-o +option set. Finally, for pictures with stored view parameters, the functions .I "Ox(n), Oy(n)" @@ -217,7 +224,9 @@ pcomb \-f myfilt.cal \-x xmax/2 \-y ymax/2 input.hdr > To make a picture of a dot: .IP "" .2i pcomb \-x 100 \-y 100 \-e 'ro=b;go=b;bo=b;b=if((x-50)^2+(y-50)^2\-25^2,0,1)' > dot +.SH ENVIRONMENT +RAYPATH the directories to check for auxiliary files. .SH AUTHOR Greg Ward .SH "SEE ALSO" -getinfo(1), icalc(1), pcompos(1), pfilt(1), rpict(1) +getinfo(1), icalc(1), pcompos(1), pfilt(1), rmtxcomb(1), rmtxop(1), rpict(1)
