--- ray/doc/man/man1/pcomb.1 2003/03/11 19:20:21 1.1 +++ ray/doc/man/man1/pcomb.1 2018/05/04 23:56:49 1.11 @@ -1,10 +1,12 @@ -.\" RCSid "$Id" +.\" RCSid "$Id: pcomb.1,v 1.11 2018/05/04 23:56:49 greg Exp $" .TH PCOMB 1 8/31/96 RADIANCE .SH NAME -pcomb - combine RADIANCE pictures. +pcomb - combine RADIANCE pictures .SH SYNOPSIS .B pcomb [ +.B -h +][ .B -w ][ .B "\-x xres" @@ -40,6 +42,9 @@ but an arbitrary mapping can be assigned with the and .I \-f options. +The variable and function definitions in each +.I \-f source +file are read and compiled from the RADIANCE library where it is found. Negative coefficients and functions are allowed, and .I pcomb will produce color values of zero where they would be negative. @@ -68,7 +73,7 @@ For example, would return the red component of the pixel from picture 3 that is left 2 and up 1 from the current position. Although x offsets may be as large as width of the picture, -y offsets are limited to a small window (+/- 8 pixels) due to efficiency +y offsets are limited to a small window (+/- 32 pixels) due to efficiency considerations. However, it is not usually necessary to worry about this problem -- if the requested offset is not available, the next best pixel is @@ -85,7 +90,11 @@ The constant gives the number of input files present, and .I WE -gives the white efficacy (lumens/brightness) for pixel values. +gives the white efficacy (lumens/brightness) for pixel values, +which may be used with the +.I \-o +option or the le(n) values to convert to absolute +photometric units (see below). The variables .I x and @@ -134,8 +143,17 @@ If the current pixel is outside the view region, will return a negative value, and .I S(n) will return zero. +The first input picture with a view is assumed to correspond to the +view of the output picture, which is written into the header. .PP The +.I \-h +option may be used to reduce the information header size, which +can grow disproportionately after multiple runs of +.I pcomb +and/or +.I pcompos(1). +The .I \-w option can be used to suppress warning messages about invalid calculations. @@ -185,24 +203,26 @@ by preceeding it with an exclamation point ('!'). .SH EXAMPLES To produce a picture showing the difference between pic1 and pic2: .IP "" .2i -pcomb -e 'ro=ri(1)-ri(2);go=gi(1)-gi(2);bo=bi(1)-bi(2)' pic1 pic2 > diff +pcomb \-e 'ro=ri(1)\-ri(2);go=gi(1)\-gi(2);bo=bi(1)\-bi(2)' pic1 pic2 > diff .PP Or, more efficiently: .IP "" .2i -pcomb pic1 -s -1 pic2 > diff +pcomb pic1 \-s \-1 pic2 > diff .PP To precompute the gamma correction for a picture: .IP "" .2i -pcomb -e 'ro=ri(1)^.4;go=gi(1)^.4;bo=bi(1)^.4' pic > pic.gam +pcomb \-e 'ro=ri(1)^.4;go=gi(1)^.4;bo=bi(1)^.4' inp.hdr > gam.hdr .PP To perform some special filtering: .IP "" .2i -pcomb -f myfilt.cal -x xmax/2 -y ymax/2 input.pic > filtered.pic +pcomb \-f myfilt.cal \-x xmax/2 \-y ymax/2 input.hdr > filtered.hdr .PP To make a picture of a dot: .IP "" .2i -pcomb -x 100 -y 100 -e 'ro=b;go=b;bo=b;b=if((x-50)^2+(y-50)^2-25^2,0,1)' > dot +pcomb \-x 100 \-y 100 \-e 'ro=b;go=b;bo=b;b=if((x-50)^2+(y-50)^2\-25^2,0,1)' > dot +.SH ENVIRONMENT +RAYPATH the directories to check for auxiliary files. .SH AUTHOR Greg Ward .SH "SEE ALSO" -calc(1), getinfo(1), pcompos(1), pfilt(1), rpict(1) +getinfo(1), icalc(1), pcompos(1), pfilt(1), rpict(1)
