--- ray/doc/man/man1/pcomb.1 2018/02/05 20:07:17 1.10 +++ ray/doc/man/man1/pcomb.1 2023/12/09 23:46:50 1.15 @@ -1,7 +1,7 @@ -.\" RCSid "$Id: pcomb.1,v 1.10 2018/02/05 20:07:17 greg Exp $" +.\" RCSid "$Id: pcomb.1,v 1.15 2023/12/09 23:46:50 greg Exp $" .TH PCOMB 1 8/31/96 RADIANCE .SH NAME -pcomb - combine RADIANCE pictures +pcomb - combine RADIANCE pictures and/or float matrices .SH SYNOPSIS .B pcomb [ @@ -9,6 +9,8 @@ pcomb - combine RADIANCE pictures ][ .B -w ][ +.B -ff +][ .B "\-x xres" ][ .B "\-y yres" @@ -29,10 +31,10 @@ pcomb - combine RADIANCE pictures ] .SH DESCRIPTION .I Pcomb -combines equal-sized RADIANCE pictures and sends the result to the -standard output. +combines equal-sized RADIANCE pictures or raw float matrices +and sends the result to the standard output. By default, the result is just a linear combination of -the input pictures multiplied by +the input pixels multiplied by .I \-s and .I \-c @@ -41,10 +43,18 @@ but an arbitrary mapping can be assigned with the .I \-e and .I \-f -options. +options, similar to +.I rcalc(1). +(The variable and function definitions in each +.I \-f source +file are read and compiled from the RADIANCE library +where it is found.)\0 Negative coefficients and functions are allowed, and .I pcomb -will produce color values of zero where they would be negative. +will produce color values of zero where they would be negative +unless the +.I \-ff +option is used to specify floating-point matrix output. .PP The variables .I ro, @@ -60,16 +70,16 @@ The predefined functions .I gi(n) and .I bi(n) -give the red, green and blue input values for -picture +give the red, green and blue values for +input .I n. To access a pixel that is nearby the current one, these functions also accept optional x and y offsets. For example, .I ri(3,-2,1) -would return the red component of the pixel from picture 3 +would return the red component of the pixel from input 3 that is left 2 and up 1 from the current position. -Although x offsets may be as large as width of the picture, +Although x offsets may be as large as width of the input, y offsets are limited to a small window (+/- 32 pixels) due to efficiency considerations. However, it is not usually necessary to worry about this problem -- @@ -78,7 +88,7 @@ returned instead. .PP For additional convenience, the function .I li(n) -is defined as the input brightness for picture +is defined as the input brightness for input .I n. This function also accepts x and y offsets. .PP @@ -110,18 +120,21 @@ The constant functions .I "re(n), ge(n), be(n)," and .I le(n) -give the exposure values for picture +give the exposure values for input .I n, and .I pa(n) gives the corresponding pixel aspect ratio. -Finally, for pictures with stored view parameters, +Exposure values will be set to 1.0 for inputs with the +.I \-o +option set. +Finally, for inputs with stored view parameters, the functions .I "Ox(n), Oy(n)" and .I Oz(n) return the ray origin in world coordinates for the current pixel -in picture +in input .I n, and .I "Dx(n), Dy(n)" @@ -140,8 +153,8 @@ If the current pixel is outside the view region, will return a negative value, and .I S(n) will return zero. -The first input picture with a view is assumed to correspond to the -view of the output picture, which is written into the header. +The first input input with a view is assumed to correspond to the +view of the output, which is written into the header. .PP The .I \-h @@ -157,7 +170,7 @@ calculations. The .I \-o option indicates that original pixel values are to be used for the next -picture, undoing any previous exposure changes or color correction. +input, undoing any previous exposure changes or color correction. .PP The .I \-x @@ -189,13 +202,14 @@ the definitions of and .I bo will be used to compute each output pixel. -This is useful for producing simple test pictures for various +This is useful for producing simple test inputs for various purposes. (Theoretically, one could write a complete renderer using just the functional language...) .PP The standard input can be specified with a hyphen ('-'). -A command that produces a RADIANCE picture can be given in place of a file +A command that produces a RADIANCE picture or float matrix +can be given in place of a file by preceeding it with an exclamation point ('!'). .SH EXAMPLES To produce a picture showing the difference between pic1 and pic2: @@ -217,7 +231,10 @@ pcomb \-f myfilt.cal \-x xmax/2 \-y ymax/2 input.hdr > To make a picture of a dot: .IP "" .2i pcomb \-x 100 \-y 100 \-e 'ro=b;go=b;bo=b;b=if((x-50)^2+(y-50)^2\-25^2,0,1)' > dot +.SH ENVIRONMENT +RAYPATH the directories to check for auxiliary files. .SH AUTHOR Greg Ward .SH "SEE ALSO" -getinfo(1), icalc(1), pcompos(1), pfilt(1), rpict(1) +getinfo(1), icalc(1), pcompos(1), pfilt(1), rcalc(1), +rmtxcomb(1), rmtxop(1), rpict(1)
