--- ray/doc/man/man1/pcomb.1 2018/02/05 20:07:17 1.10 +++ ray/doc/man/man1/pcomb.1 2022/03/18 21:09:16 1.12 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: pcomb.1,v 1.10 2018/02/05 20:07:17 greg Exp $" +.\" RCSid "$Id: pcomb.1,v 1.12 2022/03/18 21:09:16 greg Exp $" .TH PCOMB 1 8/31/96 RADIANCE .SH NAME pcomb - combine RADIANCE pictures @@ -42,6 +42,9 @@ but an arbitrary mapping can be assigned with the and .I \-f options. +The variable and function definitions in each +.I \-f source +file are read and compiled from the RADIANCE library where it is found. Negative coefficients and functions are allowed, and .I pcomb will produce color values of zero where they would be negative. @@ -115,6 +118,9 @@ give the exposure values for picture and .I pa(n) gives the corresponding pixel aspect ratio. +Exposure values will be set to 1.0 for inputs with the +.I \-o +option set. Finally, for pictures with stored view parameters, the functions .I "Ox(n), Oy(n)" @@ -217,6 +223,8 @@ pcomb \-f myfilt.cal \-x xmax/2 \-y ymax/2 input.hdr > To make a picture of a dot: .IP "" .2i pcomb \-x 100 \-y 100 \-e 'ro=b;go=b;bo=b;b=if((x-50)^2+(y-50)^2\-25^2,0,1)' > dot +.SH ENVIRONMENT +RAYPATH the directories to check for auxiliary files. .SH AUTHOR Greg Ward .SH "SEE ALSO"
