--- ray/doc/man/man1/pcomb.1 2018/02/05 20:07:17 1.10 +++ ray/doc/man/man1/pcomb.1 2018/05/04 23:56:49 1.11 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: pcomb.1,v 1.10 2018/02/05 20:07:17 greg Exp $" +.\" RCSid "$Id: pcomb.1,v 1.11 2018/05/04 23:56:49 greg Exp $" .TH PCOMB 1 8/31/96 RADIANCE .SH NAME pcomb - combine RADIANCE pictures @@ -42,6 +42,9 @@ but an arbitrary mapping can be assigned with the and .I \-f options. +The variable and function definitions in each +.I \-f source +file are read and compiled from the RADIANCE library where it is found. Negative coefficients and functions are allowed, and .I pcomb will produce color values of zero where they would be negative. @@ -217,6 +220,8 @@ pcomb \-f myfilt.cal \-x xmax/2 \-y ymax/2 input.hdr > To make a picture of a dot: .IP "" .2i pcomb \-x 100 \-y 100 \-e 'ro=b;go=b;bo=b;b=if((x-50)^2+(y-50)^2\-25^2,0,1)' > dot +.SH ENVIRONMENT +RAYPATH the directories to check for auxiliary files. .SH AUTHOR Greg Ward .SH "SEE ALSO"
