| 1 |
.\" RCSid "$Id: pcomb.1,v 1.5 2004/01/01 19:31:45 greg Exp $"
| 2 |
.TH PCOMB 1 8/31/96 RADIANCE
| 3 |
.SH NAME
| 4 |
pcomb - combine RADIANCE pictures
| 5 |
.SH SYNOPSIS
| 6 |
.B pcomb
| 7 |
| 8 |
.B -w
| 9 |
| 10 |
.B "\-x xres"
| 11 |
| 12 |
.B "\-y yres"
| 13 |
| 14 |
.B "\-f file"
| 15 |
| 16 |
.B "\-e expr"
| 17 |
| 18 |
| 19 |
| 20 |
.B -o
| 21 |
| 22 |
.B "\-s factor"
| 23 |
| 24 |
.B "\-c r g b"
| 25 |
| 26 |
.B "input .."
| 27 |
| 28 |
.SH DESCRIPTION
| 29 |
.I Pcomb
| 30 |
combines equal-sized RADIANCE pictures and sends the result to the
| 31 |
standard output.
| 32 |
By default, the result is just a linear combination of
| 33 |
the input pictures multiplied by
| 34 |
.I \-s
| 35 |
and
| 36 |
.I \-c
| 37 |
coefficients,
| 38 |
but an arbitrary mapping can be assigned with the
| 39 |
.I \-e
| 40 |
and
| 41 |
.I \-f
| 42 |
options.
| 43 |
Negative coefficients and functions are allowed, and
| 44 |
.I pcomb
| 45 |
will produce color values of zero where they would be negative.
| 46 |
.PP
| 47 |
The variables
| 48 |
.I ro,
| 49 |
.I go
| 50 |
and
| 51 |
.I bo
| 52 |
specify the red, green and blue output values, respectively.
| 53 |
Alternatively, the single variable
| 54 |
.I lo
| 55 |
can be used to specify a brightness value for black and white output.
| 56 |
The predefined functions
| 57 |
.I ri(n),
| 58 |
.I gi(n)
| 59 |
and
| 60 |
.I bi(n)
| 61 |
give the red, green and blue input values for
| 62 |
| 63 |
.I n.
| 64 |
To access a pixel that is nearby the current one, these functions
| 65 |
also accept optional x and y offsets.
| 66 |
For example,
| 67 |
.I ri(3,-2,1)
| 68 |
would return the red component of the pixel from picture 3
| 69 |
that is left 2 and up 1 from the current position.
| 70 |
Although x offsets may be as large as width of the picture,
| 71 |
y offsets are limited to a small window (+/- 32 pixels) due to efficiency
| 72 |
considerations.
| 73 |
However, it is not usually necessary to worry about this problem --
| 74 |
if the requested offset is not available, the next best pixel is
| 75 |
returned instead.
| 76 |
.PP
| 77 |
For additional convenience, the function
| 78 |
.I li(n)
| 79 |
is defined as the input brightness for picture
| 80 |
.I n.
| 81 |
This function also accepts x and y offsets.
| 82 |
.PP
| 83 |
The constant
| 84 |
.I nfiles
| 85 |
gives the number of input files present,
| 86 |
and
| 87 |
.I WE
| 88 |
gives the white efficacy (lumens/brightness) for pixel values,
| 89 |
which may be used with the
| 90 |
.I \-o
| 91 |
option or the le(n) values to convert to absolute
| 92 |
photometric units (see below).
| 93 |
The variables
| 94 |
.I x
| 95 |
and
| 96 |
.I y
| 97 |
give the current output pixel location for use in
| 98 |
spatially dependent functions, the constants
| 99 |
.I xmax
| 100 |
and
| 101 |
.I ymax
| 102 |
give the input resolution, and the constants
| 103 |
.I xres
| 104 |
and
| 105 |
.I yres
| 106 |
give the output resolution (usually the same, but see below).
| 107 |
The constant functions
| 108 |
.I "re(n), ge(n), be(n),"
| 109 |
and
| 110 |
.I le(n)
| 111 |
give the exposure values for picture
| 112 |
.I n,
| 113 |
and
| 114 |
.I pa(n)
| 115 |
gives the corresponding pixel aspect ratio.
| 116 |
Finally, for pictures with stored view parameters,
| 117 |
the functions
| 118 |
.I "Ox(n), Oy(n)"
| 119 |
and
| 120 |
.I Oz(n)
| 121 |
return the ray origin in world coordinates for the current pixel
| 122 |
in picture
| 123 |
.I n,
| 124 |
and
| 125 |
.I "Dx(n), Dy(n)"
| 126 |
and
| 127 |
.I Dz(n)
| 128 |
return the normalized ray direction.
| 129 |
In addition, the function
| 130 |
.I T(n)
| 131 |
returns the distance from the origin to the aft clipping plane
| 132 |
(or zero if there is no aft plane), and the function
| 133 |
.I S(n)
| 134 |
returns the solid angle of the current pixel in steradians
| 135 |
(always zero for parallel views).
| 136 |
If the current pixel is outside the view region,
| 137 |
.I T(n)
| 138 |
will return a negative value, and
| 139 |
.I S(n)
| 140 |
will return zero.
| 141 |
.PP
| 142 |
The
| 143 |
.I \-w
| 144 |
option can be used to suppress warning messages about invalid
| 145 |
calculations.
| 146 |
The
| 147 |
.I \-o
| 148 |
option indicates that original pixel values are to be used for the next
| 149 |
picture, undoing any previous exposure changes or color correction.
| 150 |
.PP
| 151 |
The
| 152 |
.I \-x
| 153 |
and
| 154 |
.I \-y
| 155 |
options can be used to specify the desired output resolution,
| 156 |
.I xres
| 157 |
and
| 158 |
.I yres,
| 159 |
and can be expressions involving other constants such as
| 160 |
.I xmax
| 161 |
and
| 162 |
.I ymax.
| 163 |
The constants
| 164 |
.I xres
| 165 |
and
| 166 |
.I yres
| 167 |
may also be specified in a file or expression.
| 168 |
The default output resolution is the same as the input resolution.
| 169 |
.PP
| 170 |
The
| 171 |
.I \-x
| 172 |
and
| 173 |
.I \-y
| 174 |
options must be present if there are no input files, when
| 175 |
the definitions of
| 176 |
.I ro,
| 177 |
.I go
| 178 |
and
| 179 |
.I bo
| 180 |
will be used to compute each output pixel.
| 181 |
This is useful for producing simple test pictures for various
| 182 |
purposes.
| 183 |
(Theoretically, one could write a complete renderer using just the
| 184 |
functional language...)
| 185 |
.PP
| 186 |
The standard input can be specified with a hyphen ('-').
| 187 |
A command that produces a RADIANCE picture can be given in place of a file
| 188 |
by preceeding it with an exclamation point ('!').
| 189 |
.SH EXAMPLES
| 190 |
To produce a picture showing the difference between pic1 and pic2:
| 191 |
.IP "" .2i
| 192 |
pcomb -e 'ro=ri(1)-ri(2);go=gi(1)-gi(2);bo=bi(1)-bi(2)' pic1 pic2 > diff
| 193 |
.PP
| 194 |
Or, more efficiently:
| 195 |
.IP "" .2i
| 196 |
pcomb pic1 -s -1 pic2 > diff
| 197 |
.PP
| 198 |
To precompute the gamma correction for a picture:
| 199 |
.IP "" .2i
| 200 |
pcomb -e 'ro=ri(1)^.4;go=gi(1)^.4;bo=bi(1)^.4' pic > pic.gam
| 201 |
.PP
| 202 |
To perform some special filtering:
| 203 |
.IP "" .2i
| 204 |
pcomb -f myfilt.cal -x xmax/2 -y ymax/2 input.pic > filtered.pic
| 205 |
.PP
| 206 |
To make a picture of a dot:
| 207 |
.IP "" .2i
| 208 |
pcomb -x 100 -y 100 -e 'ro=b;go=b;bo=b;b=if((x-50)^2+(y-50)^2-25^2,0,1)' > dot
| 209 |
.SH AUTHOR
| 210 |
Greg Ward
| 211 |
.SH "SEE ALSO"
| 212 |
getinfo(1), icalc(1), pcompos(1), pfilt(1), rpict(1)
