root/Development/ray/doc/man/man1/pcomb.1
Revision: 1.17
Committed: Mon Dec 11 01:02:18 2023 UTC (23 months ago) by greg
Changes since 1.16: +3 -3 lines
docs(pcomb): Added missing command references
1 .\" RCSid "$Id: pcomb.1,v 1.16 2023/12/11 01:00:27 greg Exp $"
2 .TH PCOMB 1 8/31/96 RADIANCE
3 .SH NAME
4 pcomb - combine RADIANCE pictures and/or float matrices
5 .SH SYNOPSIS
6 .B pcomb
7 [
8 .B -h
9 ][
10 .B -w
11 ][
12 .B -ff
13 ][
14 .B "\-x xres"
15 ][
16 .B "\-y yres"
17 ][
18 .B "\-f file"
19 ][
20 .B "\-e expr"
21 ]
22 [
23 [
24 .B -o
25 ][
26 .B "\-s factor"
27 ][
28 .B "\-c r g b"
29 ]
30 .B "input .."
31 ]
32 .SH DESCRIPTION
33 .I Pcomb
34 combines equal-sized RADIANCE pictures or raw float matrices
35 and sends the result to the standard output.
36 By default, the result is just a linear combination of
37 the input pixels multiplied by
38 .I \-s
39 and
40 .I \-c
41 coefficients,
42 but an arbitrary mapping can be assigned with the
43 .I \-e
44 and
45 .I \-f
46 options, similar to
47 .I rcalc(1).
48 (The variable and function definitions in each
49 .I \-f source
50 file are read and compiled from the RADIANCE library
51 where it is found.)\0
52 Negative coefficients and functions are allowed, and
53 .I pcomb
54 will produce color values of zero where they would be negative
55 unless the
56 .I \-ff
57 option is used to specify floating-point matrix output.
58 .PP
59 The variables
60 .I ro,
61 .I go
62 and
63 .I bo
64 specify the red, green and blue output values, respectively.
65 Alternatively, the single variable
66 .I lo
67 can be used to specify a brightness value for black and white output.
68 The predefined functions
69 .I ri(n),
70 .I gi(n)
71 and
72 .I bi(n)
73 give the red, green and blue values for
74 input
75 .I n.
76 To access a pixel that is nearby the current one, these functions
77 also accept optional x and y offsets.
78 For example,
79 .I ri(3,-2,1)
80 would return the red component of the pixel from input 3
81 that is left 2 and up 1 from the current position.
82 Although x offsets may be as large as width of the input,
83 y offsets are limited to a small window (+/- 32 pixels) due to efficiency
84 considerations.
85 However, it is not usually necessary to worry about this problem --
86 if the requested offset is not available, the next best pixel is
87 returned instead.
88 .PP
89 For additional convenience, the function
90 .I li(n)
91 is defined as the input brightness for input
92 .I n.
93 This function also accepts x and y offsets.
94 .PP
95 The constant
96 .I nfiles
97 gives the number of input files present,
98 and
99 .I WE
100 gives the white efficacy (lumens/brightness) for pixel values,
101 which may be used with the
102 .I \-o
103 option or the le(n) values to convert to absolute
104 photometric units (see below).
105 The variables
106 .I x
107 and
108 .I y
109 give the current output pixel location for use in
110 spatially dependent functions, the constants
111 .I xmax
112 and
113 .I ymax
114 give the input resolution, and the constants
115 .I xres
116 and
117 .I yres
118 give the output resolution (usually the same, but see below).
119 The constant functions
120 .I "re(n), ge(n), be(n),"
121 and
122 .I le(n)
123 give the exposure values for input
124 .I n,
125 and
126 .I pa(n)
127 gives the corresponding pixel aspect ratio.
128 Exposure values will be set to 1.0 for inputs with the
129 .I \-o
130 option set.
131 Finally, for inputs with stored view parameters,
132 the functions
133 .I "Ox(n), Oy(n)"
134 and
135 .I Oz(n)
136 return the ray origin in world coordinates for the current pixel
137 in input
138 .I n,
139 and
140 .I "Dx(n), Dy(n)"
141 and
142 .I Dz(n)
143 return the normalized ray direction.
144 In addition, the function
145 .I T(n)
146 returns the distance from the origin to the aft clipping plane
147 (or zero if there is no aft plane), and the function
148 .I S(n)
149 returns the solid angle of the current pixel in steradians
150 (always zero for parallel views).
151 If the current pixel is outside the view region,
152 .I T(n)
153 will return a negative value, and
154 .I S(n)
155 will return zero.
156 The first input input with a view is assumed to correspond to the
157 view of the output, which is written into the header.
158 .PP
159 The
160 .I \-h
161 option may be used to reduce the information header size, which
162 can grow disproportionately after multiple runs of
163 .I pcomb
164 and/or
165 .I pcompos(1).
166 The
167 .I \-w
168 option can be used to suppress warning messages about invalid
169 calculations.
170 The
171 .I \-o
172 option indicates that original pixel values are to be used for the next
173 input, undoing any previous exposure changes or color correction.
174 .PP
175 The
176 .I \-x
177 and
178 .I \-y
179 options can be used to specify the desired output resolution,
180 .I xres
181 and
182 .I yres,
183 and can be expressions involving other constants such as
184 .I xmax
185 and
186 .I ymax.
187 The constants
188 .I xres
189 and
190 .I yres
191 may also be specified in a file or expression.
192 The default output resolution is the same as the input resolution.
193 .PP
194 The
195 .I \-x
196 and
197 .I \-y
198 options must be present if there are no input files, when
199 the definitions of
200 .I ro,
201 .I go
202 and
203 .I bo
204 will be used to compute each output pixel.
205 This is useful for producing simple test inputs for various
206 purposes.
207 (Theoretically, one could write a complete renderer using just the
208 functional language...)
209 .PP
210 The standard input can be specified with a hyphen ('-').
211 A command that produces a RADIANCE picture or float matrix
212 can be given in place of a file
213 by preceeding it with an exclamation point ('!').
214 .SH EXAMPLES
215 To produce a picture showing the difference between pic1 and pic2:
216 .IP "" .2i
217 pcomb \-e 'ro=ri(1)\-ri(2);go=gi(1)\-gi(2);bo=bi(1)\-bi(2)' pic1 pic2 > diff
218 .PP
219 Or, more efficiently:
220 .IP "" .2i
221 pcomb pic1 \-s \-1 pic2 > diff
222 .PP
223 To precompute the gamma correction for a picture:
224 .IP "" .2i
225 pcomb \-e 'ro=ri(1)^.4;go=gi(1)^.4;bo=bi(1)^.4' inp.hdr > gam.hdr
226 .PP
227 To perform some special filtering:
228 .IP "" .2i
229 pcomb \-f myfilt.cal \-x xmax/2 \-y ymax/2 input.hdr > filtered.hdr
230 .PP
231 To make a picture of a dot:
232 .IP "" .2i
233 pcomb \-x 100 \-y 100 \-e 'ro=b;go=b;bo=b;b=if((x-50)^2+(y-50)^2\-25^2,0,1)' > dot
234 .PP
235 Use a depth buffer to superimpose 3-D gridlines on rendered image:
236 .IP "" .2i
237 rcollate -hi -ff -o 3000x3000 raw_orig.zbf
238 | pcomb -e 't=gi(2);Px=Ox(1)+t*Dx(1);Py=Oy(1)+t*Dy(1);Pz=Oz(1)+t*Dz(1)'
239 -e 'frac(x):x-floor(x)' -e 'Rg:0;Gg:0;Bg:1;gsiz:0.04'
240 -e 'ingr=gsiz-min(frac(Px),frac(Py),frac(Pz))'
241 -e 'ro=if(ingr,Rg,ri(1));go=if(ingr,Gg,gi(1));bo=if(ingr,Bg,bi(1))'
242 raw_orig.hdr - > trans_def_grid.hdr
243 .SH ENVIRONMENT
244 RAYPATH the directories to check for auxiliary files.
245 .SH AUTHOR
246 Greg Ward
247 .SH "SEE ALSO"
248 getinfo(1), icalc(1), pcompos(1), pfilt(1), pvalue(1), rcalc(1),
249 rcollate(1), rmtxcomb(1), rmtxop(1), rpict(1)
