root/radiance/ray/doc/man/man1/pcomb.1
Revision: 1.9
Committed: Mon Nov 10 19:08:17 2008 UTC (16 years, 7 months ago) by greg
CVS Tags: rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R1, rad4R0, rad4R2P1
1 .\" RCSid "$Id: pcomb.1,v 1.8 2007/09/04 17:36:40 greg Exp $"
2 .TH PCOMB 1 8/31/96 RADIANCE
3 .SH NAME
4 pcomb - combine RADIANCE pictures
5 .SH SYNOPSIS
6 .B pcomb
7 [
8 .B -h
9 ][
10 .B -w
11 ][
12 .B "\-x xres"
13 ][
14 .B "\-y yres"
15 ][
16 .B "\-f file"
17 ][
18 .B "\-e expr"
19 ]
20 [
21 [
22 .B -o
23 ][
24 .B "\-s factor"
25 ][
26 .B "\-c r g b"
27 ]
28 .B "input .."
29 ]
30 .SH DESCRIPTION
31 .I Pcomb
32 combines equal-sized RADIANCE pictures and sends the result to the
33 standard output.
34 By default, the result is just a linear combination of
35 the input pictures multiplied by
36 .I \-s
37 and
38 .I \-c
39 coefficients,
40 but an arbitrary mapping can be assigned with the
41 .I \-e
42 and
43 .I \-f
44 options.
45 Negative coefficients and functions are allowed, and
46 .I pcomb
47 will produce color values of zero where they would be negative.
48 .PP
49 The variables
50 .I ro,
51 .I go
52 and
53 .I bo
54 specify the red, green and blue output values, respectively.
55 Alternatively, the single variable
56 .I lo
57 can be used to specify a brightness value for black and white output.
58 The predefined functions
59 .I ri(n),
60 .I gi(n)
61 and
62 .I bi(n)
63 give the red, green and blue input values for
64 picture
65 .I n.
66 To access a pixel that is nearby the current one, these functions
67 also accept optional x and y offsets.
68 For example,
69 .I ri(3,-2,1)
70 would return the red component of the pixel from picture 3
71 that is left 2 and up 1 from the current position.
72 Although x offsets may be as large as width of the picture,
73 y offsets are limited to a small window (+/- 32 pixels) due to efficiency
74 considerations.
75 However, it is not usually necessary to worry about this problem --
76 if the requested offset is not available, the next best pixel is
77 returned instead.
78 .PP
79 For additional convenience, the function
80 .I li(n)
81 is defined as the input brightness for picture
82 .I n.
83 This function also accepts x and y offsets.
84 .PP
85 The constant
86 .I nfiles
87 gives the number of input files present,
88 and
89 .I WE
90 gives the white efficacy (lumens/brightness) for pixel values,
91 which may be used with the
92 .I \-o
93 option or the le(n) values to convert to absolute
94 photometric units (see below).
95 The variables
96 .I x
97 and
98 .I y
99 give the current output pixel location for use in
100 spatially dependent functions, the constants
101 .I xmax
102 and
103 .I ymax
104 give the input resolution, and the constants
105 .I xres
106 and
107 .I yres
108 give the output resolution (usually the same, but see below).
109 The constant functions
110 .I "re(n), ge(n), be(n),"
111 and
112 .I le(n)
113 give the exposure values for picture
114 .I n,
115 and
116 .I pa(n)
117 gives the corresponding pixel aspect ratio.
118 Finally, for pictures with stored view parameters,
119 the functions
120 .I "Ox(n), Oy(n)"
121 and
122 .I Oz(n)
123 return the ray origin in world coordinates for the current pixel
124 in picture
125 .I n,
126 and
127 .I "Dx(n), Dy(n)"
128 and
129 .I Dz(n)
130 return the normalized ray direction.
131 In addition, the function
132 .I T(n)
133 returns the distance from the origin to the aft clipping plane
134 (or zero if there is no aft plane), and the function
135 .I S(n)
136 returns the solid angle of the current pixel in steradians
137 (always zero for parallel views).
138 If the current pixel is outside the view region,
139 .I T(n)
140 will return a negative value, and
141 .I S(n)
142 will return zero.
143 .PP
144 The
145 .I \-h
146 option may be used to reduce the information header size, which
147 can grow disproportionately after multiple runs of
148 .I pcomb
149 and/or
150 .I pcompos(1).
151 The
152 .I \-w
153 option can be used to suppress warning messages about invalid
154 calculations.
155 The
156 .I \-o
157 option indicates that original pixel values are to be used for the next
158 picture, undoing any previous exposure changes or color correction.
159 .PP
160 The
161 .I \-x
162 and
163 .I \-y
164 options can be used to specify the desired output resolution,
165 .I xres
166 and
167 .I yres,
168 and can be expressions involving other constants such as
169 .I xmax
170 and
171 .I ymax.
172 The constants
173 .I xres
174 and
175 .I yres
176 may also be specified in a file or expression.
177 The default output resolution is the same as the input resolution.
178 .PP
179 The
180 .I \-x
181 and
182 .I \-y
183 options must be present if there are no input files, when
184 the definitions of
185 .I ro,
186 .I go
187 and
188 .I bo
189 will be used to compute each output pixel.
190 This is useful for producing simple test pictures for various
191 purposes.
192 (Theoretically, one could write a complete renderer using just the
193 functional language...)
194 .PP
195 The standard input can be specified with a hyphen ('-').
196 A command that produces a RADIANCE picture can be given in place of a file
197 by preceeding it with an exclamation point ('!').
198 .SH EXAMPLES
199 To produce a picture showing the difference between pic1 and pic2:
200 .IP "" .2i
201 pcomb \-e 'ro=ri(1)\-ri(2);go=gi(1)\-gi(2);bo=bi(1)\-bi(2)' pic1 pic2 > diff
202 .PP
203 Or, more efficiently:
204 .IP "" .2i
205 pcomb pic1 \-s \-1 pic2 > diff
206 .PP
207 To precompute the gamma correction for a picture:
208 .IP "" .2i
209 pcomb \-e 'ro=ri(1)^.4;go=gi(1)^.4;bo=bi(1)^.4' inp.hdr > gam.hdr
210 .PP
211 To perform some special filtering:
212 .IP "" .2i
213 pcomb \-f myfilt.cal \-x xmax/2 \-y ymax/2 input.hdr > filtered.hdr
214 .PP
215 To make a picture of a dot:
216 .IP "" .2i
217 pcomb \-x 100 \-y 100 \-e 'ro=b;go=b;bo=b;b=if((x-50)^2+(y-50)^2\-25^2,0,1)' > dot
218 .SH AUTHOR
219 Greg Ward
220 .SH "SEE ALSO"
221 getinfo(1), icalc(1), pcompos(1), pfilt(1), rpict(1)
