1 |
.\" RCSid "$Id: pcomb.1,v 1.8 2007/09/04 17:36:40 greg Exp $" |
2 |
.TH PCOMB 1 8/31/96 RADIANCE |
3 |
.SH NAME |
4 |
pcomb - combine RADIANCE pictures |
5 |
.SH SYNOPSIS |
6 |
.B pcomb |
7 |
8 |
.B -h |
9 |
10 |
.B -w |
11 |
12 |
.B "\-x xres" |
13 |
14 |
.B "\-y yres" |
15 |
16 |
.B "\-f file" |
17 |
18 |
.B "\-e expr" |
19 |
20 |
21 |
22 |
.B -o |
23 |
24 |
.B "\-s factor" |
25 |
26 |
.B "\-c r g b" |
27 |
28 |
.B "input .." |
29 |
30 |
.SH DESCRIPTION |
31 |
.I Pcomb |
32 |
combines equal-sized RADIANCE pictures and sends the result to the |
33 |
standard output. |
34 |
By default, the result is just a linear combination of |
35 |
the input pictures multiplied by |
36 |
.I \-s |
37 |
and |
38 |
.I \-c |
39 |
coefficients, |
40 |
but an arbitrary mapping can be assigned with the |
41 |
.I \-e |
42 |
and |
43 |
.I \-f |
44 |
options. |
45 |
Negative coefficients and functions are allowed, and |
46 |
.I pcomb |
47 |
will produce color values of zero where they would be negative. |
48 |
.PP |
49 |
The variables |
50 |
.I ro, |
51 |
.I go |
52 |
and |
53 |
.I bo |
54 |
specify the red, green and blue output values, respectively. |
55 |
Alternatively, the single variable |
56 |
.I lo |
57 |
can be used to specify a brightness value for black and white output. |
58 |
The predefined functions |
59 |
.I ri(n), |
60 |
.I gi(n) |
61 |
and |
62 |
.I bi(n) |
63 |
give the red, green and blue input values for |
64 |
picture |
65 |
.I n. |
66 |
To access a pixel that is nearby the current one, these functions |
67 |
also accept optional x and y offsets. |
68 |
For example, |
69 |
.I ri(3,-2,1) |
70 |
would return the red component of the pixel from picture 3 |
71 |
that is left 2 and up 1 from the current position. |
72 |
Although x offsets may be as large as width of the picture, |
73 |
y offsets are limited to a small window (+/- 32 pixels) due to efficiency |
74 |
considerations. |
75 |
However, it is not usually necessary to worry about this problem -- |
76 |
if the requested offset is not available, the next best pixel is |
77 |
returned instead. |
78 |
.PP |
79 |
For additional convenience, the function |
80 |
.I li(n) |
81 |
is defined as the input brightness for picture |
82 |
.I n. |
83 |
This function also accepts x and y offsets. |
84 |
.PP |
85 |
The constant |
86 |
.I nfiles |
87 |
gives the number of input files present, |
88 |
and |
89 |
.I WE |
90 |
gives the white efficacy (lumens/brightness) for pixel values, |
91 |
which may be used with the |
92 |
.I \-o |
93 |
option or the le(n) values to convert to absolute |
94 |
photometric units (see below). |
95 |
The variables |
96 |
.I x |
97 |
and |
98 |
.I y |
99 |
give the current output pixel location for use in |
100 |
spatially dependent functions, the constants |
101 |
.I xmax |
102 |
and |
103 |
.I ymax |
104 |
give the input resolution, and the constants |
105 |
.I xres |
106 |
and |
107 |
.I yres |
108 |
give the output resolution (usually the same, but see below). |
109 |
The constant functions |
110 |
.I "re(n), ge(n), be(n)," |
111 |
and |
112 |
.I le(n) |
113 |
give the exposure values for picture |
114 |
.I n, |
115 |
and |
116 |
.I pa(n) |
117 |
gives the corresponding pixel aspect ratio. |
118 |
Finally, for pictures with stored view parameters, |
119 |
the functions |
120 |
.I "Ox(n), Oy(n)" |
121 |
and |
122 |
.I Oz(n) |
123 |
return the ray origin in world coordinates for the current pixel |
124 |
in picture |
125 |
.I n, |
126 |
and |
127 |
.I "Dx(n), Dy(n)" |
128 |
and |
129 |
.I Dz(n) |
130 |
return the normalized ray direction. |
131 |
In addition, the function |
132 |
.I T(n) |
133 |
returns the distance from the origin to the aft clipping plane |
134 |
(or zero if there is no aft plane), and the function |
135 |
.I S(n) |
136 |
returns the solid angle of the current pixel in steradians |
137 |
(always zero for parallel views). |
138 |
If the current pixel is outside the view region, |
139 |
.I T(n) |
140 |
will return a negative value, and |
141 |
.I S(n) |
142 |
will return zero. |
143 |
.PP |
144 |
The |
145 |
.I \-h |
146 |
option may be used to reduce the information header size, which |
147 |
can grow disproportionately after multiple runs of |
148 |
.I pcomb |
149 |
and/or |
150 |
.I pcompos(1). |
151 |
The |
152 |
.I \-w |
153 |
option can be used to suppress warning messages about invalid |
154 |
calculations. |
155 |
The |
156 |
.I \-o |
157 |
option indicates that original pixel values are to be used for the next |
158 |
picture, undoing any previous exposure changes or color correction. |
159 |
.PP |
160 |
The |
161 |
.I \-x |
162 |
and |
163 |
.I \-y |
164 |
options can be used to specify the desired output resolution, |
165 |
.I xres |
166 |
and |
167 |
.I yres, |
168 |
and can be expressions involving other constants such as |
169 |
.I xmax |
170 |
and |
171 |
.I ymax. |
172 |
The constants |
173 |
.I xres |
174 |
and |
175 |
.I yres |
176 |
may also be specified in a file or expression. |
177 |
The default output resolution is the same as the input resolution. |
178 |
.PP |
179 |
The |
180 |
.I \-x |
181 |
and |
182 |
.I \-y |
183 |
options must be present if there are no input files, when |
184 |
the definitions of |
185 |
.I ro, |
186 |
.I go |
187 |
and |
188 |
.I bo |
189 |
will be used to compute each output pixel. |
190 |
This is useful for producing simple test pictures for various |
191 |
purposes. |
192 |
(Theoretically, one could write a complete renderer using just the |
193 |
functional language...) |
194 |
.PP |
195 |
The standard input can be specified with a hyphen ('-'). |
196 |
A command that produces a RADIANCE picture can be given in place of a file |
197 |
by preceeding it with an exclamation point ('!'). |
198 |
.SH EXAMPLES |
199 |
To produce a picture showing the difference between pic1 and pic2: |
200 |
.IP "" .2i |
201 |
pcomb \-e 'ro=ri(1)\-ri(2);go=gi(1)\-gi(2);bo=bi(1)\-bi(2)' pic1 pic2 > diff |
202 |
.PP |
203 |
Or, more efficiently: |
204 |
.IP "" .2i |
205 |
pcomb pic1 \-s \-1 pic2 > diff |
206 |
.PP |
207 |
To precompute the gamma correction for a picture: |
208 |
.IP "" .2i |
209 |
pcomb \-e 'ro=ri(1)^.4;go=gi(1)^.4;bo=bi(1)^.4' inp.hdr > gam.hdr |
210 |
.PP |
211 |
To perform some special filtering: |
212 |
.IP "" .2i |
213 |
pcomb \-f myfilt.cal \-x xmax/2 \-y ymax/2 input.hdr > filtered.hdr |
214 |
.PP |
215 |
To make a picture of a dot: |
216 |
.IP "" .2i |
217 |
pcomb \-x 100 \-y 100 \-e 'ro=b;go=b;bo=b;b=if((x-50)^2+(y-50)^2\-25^2,0,1)' > dot |
218 |
.SH AUTHOR |
219 |
Greg Ward |
220 |
.SH "SEE ALSO" |
221 |
getinfo(1), icalc(1), pcompos(1), pfilt(1), rpict(1) |
