root/radiance/ray/doc/man/man1/pcomb.1
Revision: 1.4
Committed: Tue Dec 9 15:59:06 2003 UTC (21 years, 5 months ago) by greg
Fixed RCSid specification
1 .\" RCSid "$Id$"
2 .TH PCOMB 1 8/31/96 RADIANCE
3 .SH NAME
4 pcomb - combine RADIANCE pictures
5 .SH SYNOPSIS
6 .B pcomb
7 [
8 .B -w
9 ][
10 .B "\-x xres"
11 ][
12 .B "\-y yres"
13 ][
14 .B "\-f file"
15 ][
16 .B "\-e expr"
17 ]
18 [
19 [
20 .B -o
21 ][
22 .B "\-s factor"
23 ][
24 .B "\-c r g b"
25 ]
26 .B "input .."
27 ]
28 .SH DESCRIPTION
29 .I Pcomb
30 combines equal-sized RADIANCE pictures and sends the result to the
31 standard output.
32 By default, the result is just a linear combination of
33 the input pictures multiplied by
34 .I \-s
35 and
36 .I \-c
37 coefficients,
38 but an arbitrary mapping can be assigned with the
39 .I \-e
40 and
41 .I \-f
42 options.
43 Negative coefficients and functions are allowed, and
44 .I pcomb
45 will produce color values of zero where they would be negative.
46 .PP
47 The variables
48 .I ro,
49 .I go
50 and
51 .I bo
52 specify the red, green and blue output values, respectively.
53 Alternatively, the single variable
54 .I lo
55 can be used to specify a brightness value for black and white output.
56 The predefined functions
57 .I ri(n),
58 .I gi(n)
59 and
60 .I bi(n)
61 give the red, green and blue input values for
62 picture
63 .I n.
64 To access a pixel that is nearby the current one, these functions
65 also accept optional x and y offsets.
66 For example,
67 .I ri(3,-2,1)
68 would return the red component of the pixel from picture 3
69 that is left 2 and up 1 from the current position.
70 Although x offsets may be as large as width of the picture,
71 y offsets are limited to a small window (+/- 8 pixels) due to efficiency
72 considerations.
73 However, it is not usually necessary to worry about this problem --
74 if the requested offset is not available, the next best pixel is
75 returned instead.
76 .PP
77 For additional convenience, the function
78 .I li(n)
79 is defined as the input brightness for picture
80 .I n.
81 This function also accepts x and y offsets.
82 .PP
83 The constant
84 .I nfiles
85 gives the number of input files present,
86 and
87 .I WE
88 gives the white efficacy (lumens/brightness) for pixel values,
89 which may be used with the
90 .I \-o
91 option or the le(n) values to convert to absolute
92 photometric units (see below).
93 The variables
94 .I x
95 and
96 .I y
97 give the current output pixel location for use in
98 spatially dependent functions, the constants
99 .I xmax
100 and
101 .I ymax
102 give the input resolution, and the constants
103 .I xres
104 and
105 .I yres
106 give the output resolution (usually the same, but see below).
107 The constant functions
108 .I "re(n), ge(n), be(n),"
109 and
110 .I le(n)
111 give the exposure values for picture
112 .I n,
113 and
114 .I pa(n)
115 gives the corresponding pixel aspect ratio.
116 Finally, for pictures with stored view parameters,
117 the functions
118 .I "Ox(n), Oy(n)"
119 and
120 .I Oz(n)
121 return the ray origin in world coordinates for the current pixel
122 in picture
123 .I n,
124 and
125 .I "Dx(n), Dy(n)"
126 and
127 .I Dz(n)
128 return the normalized ray direction.
129 In addition, the function
130 .I T(n)
131 returns the distance from the origin to the aft clipping plane
132 (or zero if there is no aft plane), and the function
133 .I S(n)
134 returns the solid angle of the current pixel in steradians
135 (always zero for parallel views).
136 If the current pixel is outside the view region,
137 .I T(n)
138 will return a negative value, and
139 .I S(n)
140 will return zero.
141 .PP
142 The
143 .I \-w
144 option can be used to suppress warning messages about invalid
145 calculations.
146 The
147 .I \-o
148 option indicates that original pixel values are to be used for the next
149 picture, undoing any previous exposure changes or color correction.
150 .PP
151 The
152 .I \-x
153 and
154 .I \-y
155 options can be used to specify the desired output resolution,
156 .I xres
157 and
158 .I yres,
159 and can be expressions involving other constants such as
160 .I xmax
161 and
162 .I ymax.
163 The constants
164 .I xres
165 and
166 .I yres
167 may also be specified in a file or expression.
168 The default output resolution is the same as the input resolution.
169 .PP
170 The
171 .I \-x
172 and
173 .I \-y
174 options must be present if there are no input files, when
175 the definitions of
176 .I ro,
177 .I go
178 and
179 .I bo
180 will be used to compute each output pixel.
181 This is useful for producing simple test pictures for various
182 purposes.
183 (Theoretically, one could write a complete renderer using just the
184 functional language...)
185 .PP
186 The standard input can be specified with a hyphen ('-').
187 A command that produces a RADIANCE picture can be given in place of a file
188 by preceeding it with an exclamation point ('!').
189 .SH EXAMPLES
190 To produce a picture showing the difference between pic1 and pic2:
191 .IP "" .2i
192 pcomb -e 'ro=ri(1)-ri(2);go=gi(1)-gi(2);bo=bi(1)-bi(2)' pic1 pic2 > diff
193 .PP
194 Or, more efficiently:
195 .IP "" .2i
196 pcomb pic1 -s -1 pic2 > diff
197 .PP
198 To precompute the gamma correction for a picture:
199 .IP "" .2i
200 pcomb -e 'ro=ri(1)^.4;go=gi(1)^.4;bo=bi(1)^.4' pic > pic.gam
201 .PP
202 To perform some special filtering:
203 .IP "" .2i
204 pcomb -f myfilt.cal -x xmax/2 -y ymax/2 input.pic > filtered.pic
205 .PP
206 To make a picture of a dot:
207 .IP "" .2i
208 pcomb -x 100 -y 100 -e 'ro=b;go=b;bo=b;b=if((x-50)^2+(y-50)^2-25^2,0,1)' > dot
209 .SH AUTHOR
210 Greg Ward
211 .SH "SEE ALSO"
212 calc(1), getinfo(1), pcompos(1), pfilt(1), rpict(1)
