1 |
.\" RCSid "$Id" |
2 |
.TH PCOMB 1 8/31/96 RADIANCE |
3 |
.SH NAME |
4 |
pcomb - combine RADIANCE pictures |
5 |
.SH SYNOPSIS |
6 |
.B pcomb |
7 |
8 |
.B -w |
9 |
10 |
.B "\-x xres" |
11 |
12 |
.B "\-y yres" |
13 |
14 |
.B "\-f file" |
15 |
16 |
.B "\-e expr" |
17 |
18 |
19 |
20 |
.B -o |
21 |
22 |
.B "\-s factor" |
23 |
24 |
.B "\-c r g b" |
25 |
26 |
.B "input .." |
27 |
28 |
.SH DESCRIPTION |
29 |
.I Pcomb |
30 |
combines equal-sized RADIANCE pictures and sends the result to the |
31 |
standard output. |
32 |
By default, the result is just a linear combination of |
33 |
the input pictures multiplied by |
34 |
.I \-s |
35 |
and |
36 |
.I \-c |
37 |
coefficients, |
38 |
but an arbitrary mapping can be assigned with the |
39 |
.I \-e |
40 |
and |
41 |
.I \-f |
42 |
options. |
43 |
Negative coefficients and functions are allowed, and |
44 |
.I pcomb |
45 |
will produce color values of zero where they would be negative. |
46 |
.PP |
47 |
The variables |
48 |
.I ro, |
49 |
.I go |
50 |
and |
51 |
.I bo |
52 |
specify the red, green and blue output values, respectively. |
53 |
Alternatively, the single variable |
54 |
.I lo |
55 |
can be used to specify a brightness value for black and white output. |
56 |
The predefined functions |
57 |
.I ri(n), |
58 |
.I gi(n) |
59 |
and |
60 |
.I bi(n) |
61 |
give the red, green and blue input values for |
62 |
picture |
63 |
.I n. |
64 |
To access a pixel that is nearby the current one, these functions |
65 |
also accept optional x and y offsets. |
66 |
For example, |
67 |
.I ri(3,-2,1) |
68 |
would return the red component of the pixel from picture 3 |
69 |
that is left 2 and up 1 from the current position. |
70 |
Although x offsets may be as large as width of the picture, |
71 |
y offsets are limited to a small window (+/- 8 pixels) due to efficiency |
72 |
considerations. |
73 |
However, it is not usually necessary to worry about this problem -- |
74 |
if the requested offset is not available, the next best pixel is |
75 |
returned instead. |
76 |
.PP |
77 |
For additional convenience, the function |
78 |
.I li(n) |
79 |
is defined as the input brightness for picture |
80 |
.I n. |
81 |
This function also accepts x and y offsets. |
82 |
.PP |
83 |
The constant |
84 |
.I nfiles |
85 |
gives the number of input files present, |
86 |
and |
87 |
.I WE |
88 |
gives the white efficacy (lumens/brightness) for pixel values. |
89 |
The variables |
90 |
.I x |
91 |
and |
92 |
.I y |
93 |
give the current output pixel location for use in |
94 |
spatially dependent functions, the constants |
95 |
.I xmax |
96 |
and |
97 |
.I ymax |
98 |
give the input resolution, and the constants |
99 |
.I xres |
100 |
and |
101 |
.I yres |
102 |
give the output resolution (usually the same, but see below). |
103 |
The constant functions |
104 |
.I "re(n), ge(n), be(n)," |
105 |
and |
106 |
.I le(n) |
107 |
give the exposure values for picture |
108 |
.I n, |
109 |
and |
110 |
.I pa(n) |
111 |
gives the corresponding pixel aspect ratio. |
112 |
Finally, for pictures with stored view parameters, |
113 |
the functions |
114 |
.I "Ox(n), Oy(n)" |
115 |
and |
116 |
.I Oz(n) |
117 |
return the ray origin in world coordinates for the current pixel |
118 |
in picture |
119 |
.I n, |
120 |
and |
121 |
.I "Dx(n), Dy(n)" |
122 |
and |
123 |
.I Dz(n) |
124 |
return the normalized ray direction. |
125 |
In addition, the function |
126 |
.I T(n) |
127 |
returns the distance from the origin to the aft clipping plane |
128 |
(or zero if there is no aft plane), and the function |
129 |
.I S(n) |
130 |
returns the solid angle of the current pixel in steradians |
131 |
(always zero for parallel views). |
132 |
If the current pixel is outside the view region, |
133 |
.I T(n) |
134 |
will return a negative value, and |
135 |
.I S(n) |
136 |
will return zero. |
137 |
.PP |
138 |
The |
139 |
.I \-w |
140 |
option can be used to suppress warning messages about invalid |
141 |
calculations. |
142 |
The |
143 |
.I \-o |
144 |
option indicates that original pixel values are to be used for the next |
145 |
picture, undoing any previous exposure changes or color correction. |
146 |
.PP |
147 |
The |
148 |
.I \-x |
149 |
and |
150 |
.I \-y |
151 |
options can be used to specify the desired output resolution, |
152 |
.I xres |
153 |
and |
154 |
.I yres, |
155 |
and can be expressions involving other constants such as |
156 |
.I xmax |
157 |
and |
158 |
.I ymax. |
159 |
The constants |
160 |
.I xres |
161 |
and |
162 |
.I yres |
163 |
may also be specified in a file or expression. |
164 |
The default output resolution is the same as the input resolution. |
165 |
.PP |
166 |
The |
167 |
.I \-x |
168 |
and |
169 |
.I \-y |
170 |
options must be present if there are no input files, when |
171 |
the definitions of |
172 |
.I ro, |
173 |
.I go |
174 |
and |
175 |
.I bo |
176 |
will be used to compute each output pixel. |
177 |
This is useful for producing simple test pictures for various |
178 |
purposes. |
179 |
(Theoretically, one could write a complete renderer using just the |
180 |
functional language...) |
181 |
.PP |
182 |
The standard input can be specified with a hyphen ('-'). |
183 |
A command that produces a RADIANCE picture can be given in place of a file |
184 |
by preceeding it with an exclamation point ('!'). |
185 |
.SH EXAMPLES |
186 |
To produce a picture showing the difference between pic1 and pic2: |
187 |
.IP "" .2i |
188 |
pcomb -e 'ro=ri(1)-ri(2);go=gi(1)-gi(2);bo=bi(1)-bi(2)' pic1 pic2 > diff |
189 |
.PP |
190 |
Or, more efficiently: |
191 |
.IP "" .2i |
192 |
pcomb pic1 -s -1 pic2 > diff |
193 |
.PP |
194 |
To precompute the gamma correction for a picture: |
195 |
.IP "" .2i |
196 |
pcomb -e 'ro=ri(1)^.4;go=gi(1)^.4;bo=bi(1)^.4' pic > pic.gam |
197 |
.PP |
198 |
To perform some special filtering: |
199 |
.IP "" .2i |
200 |
pcomb -f myfilt.cal -x xmax/2 -y ymax/2 input.pic > filtered.pic |
201 |
.PP |
202 |
To make a picture of a dot: |
203 |
.IP "" .2i |
204 |
pcomb -x 100 -y 100 -e 'ro=b;go=b;bo=b;b=if((x-50)^2+(y-50)^2-25^2,0,1)' > dot |
205 |
.SH AUTHOR |
206 |
Greg Ward |
207 |
.SH "SEE ALSO" |
208 |
calc(1), getinfo(1), pcompos(1), pfilt(1), rpict(1) |
