root/radiance/ray/doc/man/man1/pcomb.1
Revision: 1.14
Committed: Wed Dec 6 17:56:57 2023 UTC (18 months, 3 weeks ago) by greg
Changes since 1.13: +5 -3 lines
docs(rmtxcomb): Added example and described -h option
1 .\" RCSid "$Id: pcomb.1,v 1.13 2023/12/06 01:27:00 greg Exp $"
2 .TH PCOMB 1 8/31/96 RADIANCE
3 .SH NAME
4 pcomb - combine RADIANCE pictures
5 .SH SYNOPSIS
6 .B pcomb
7 [
8 .B -h
9 ][
10 .B -w
11 ][
12 .B "\-x xres"
13 ][
14 .B "\-y yres"
15 ][
16 .B "\-f file"
17 ][
18 .B "\-e expr"
19 ]
20 [
21 [
22 .B -o
23 ][
24 .B "\-s factor"
25 ][
26 .B "\-c r g b"
27 ]
28 .B "input .."
29 ]
30 .SH DESCRIPTION
31 .I Pcomb
32 combines equal-sized RADIANCE pictures and sends the result to the
33 standard output.
34 By default, the result is just a linear combination of
35 the input pictures multiplied by
36 .I \-s
37 and
38 .I \-c
39 coefficients,
40 but an arbitrary mapping can be assigned with the
41 .I \-e
42 and
43 .I \-f
44 options, similar to
45 .I rcalc(1).
46 (The variable and function definitions in each
47 .I \-f source
48 file are read and compiled from the RADIANCE library
49 where it is found.)\0
50 Negative coefficients and functions are allowed, and
51 .I pcomb
52 will produce color values of zero where they would be negative.
53 .PP
54 The variables
55 .I ro,
56 .I go
57 and
58 .I bo
59 specify the red, green and blue output values, respectively.
60 Alternatively, the single variable
61 .I lo
62 can be used to specify a brightness value for black and white output.
63 The predefined functions
64 .I ri(n),
65 .I gi(n)
66 and
67 .I bi(n)
68 give the red, green and blue input values for
69 picture
70 .I n.
71 To access a pixel that is nearby the current one, these functions
72 also accept optional x and y offsets.
73 For example,
74 .I ri(3,-2,1)
75 would return the red component of the pixel from picture 3
76 that is left 2 and up 1 from the current position.
77 Although x offsets may be as large as width of the picture,
78 y offsets are limited to a small window (+/- 32 pixels) due to efficiency
79 considerations.
80 However, it is not usually necessary to worry about this problem --
81 if the requested offset is not available, the next best pixel is
82 returned instead.
83 .PP
84 For additional convenience, the function
85 .I li(n)
86 is defined as the input brightness for picture
87 .I n.
88 This function also accepts x and y offsets.
89 .PP
90 The constant
91 .I nfiles
92 gives the number of input files present,
93 and
94 .I WE
95 gives the white efficacy (lumens/brightness) for pixel values,
96 which may be used with the
97 .I \-o
98 option or the le(n) values to convert to absolute
99 photometric units (see below).
100 The variables
101 .I x
102 and
103 .I y
104 give the current output pixel location for use in
105 spatially dependent functions, the constants
106 .I xmax
107 and
108 .I ymax
109 give the input resolution, and the constants
110 .I xres
111 and
112 .I yres
113 give the output resolution (usually the same, but see below).
114 The constant functions
115 .I "re(n), ge(n), be(n),"
116 and
117 .I le(n)
118 give the exposure values for picture
119 .I n,
120 and
121 .I pa(n)
122 gives the corresponding pixel aspect ratio.
123 Exposure values will be set to 1.0 for inputs with the
124 .I \-o
125 option set.
126 Finally, for pictures with stored view parameters,
127 the functions
128 .I "Ox(n), Oy(n)"
129 and
130 .I Oz(n)
131 return the ray origin in world coordinates for the current pixel
132 in picture
133 .I n,
134 and
135 .I "Dx(n), Dy(n)"
136 and
137 .I Dz(n)
138 return the normalized ray direction.
139 In addition, the function
140 .I T(n)
141 returns the distance from the origin to the aft clipping plane
142 (or zero if there is no aft plane), and the function
143 .I S(n)
144 returns the solid angle of the current pixel in steradians
145 (always zero for parallel views).
146 If the current pixel is outside the view region,
147 .I T(n)
148 will return a negative value, and
149 .I S(n)
150 will return zero.
151 The first input picture with a view is assumed to correspond to the
152 view of the output picture, which is written into the header.
153 .PP
154 The
155 .I \-h
156 option may be used to reduce the information header size, which
157 can grow disproportionately after multiple runs of
158 .I pcomb
159 and/or
160 .I pcompos(1).
161 The
162 .I \-w
163 option can be used to suppress warning messages about invalid
164 calculations.
165 The
166 .I \-o
167 option indicates that original pixel values are to be used for the next
168 picture, undoing any previous exposure changes or color correction.
169 .PP
170 The
171 .I \-x
172 and
173 .I \-y
174 options can be used to specify the desired output resolution,
175 .I xres
176 and
177 .I yres,
178 and can be expressions involving other constants such as
179 .I xmax
180 and
181 .I ymax.
182 The constants
183 .I xres
184 and
185 .I yres
186 may also be specified in a file or expression.
187 The default output resolution is the same as the input resolution.
188 .PP
189 The
190 .I \-x
191 and
192 .I \-y
193 options must be present if there are no input files, when
194 the definitions of
195 .I ro,
196 .I go
197 and
198 .I bo
199 will be used to compute each output pixel.
200 This is useful for producing simple test pictures for various
201 purposes.
202 (Theoretically, one could write a complete renderer using just the
203 functional language...)
204 .PP
205 The standard input can be specified with a hyphen ('-').
206 A command that produces a RADIANCE picture can be given in place of a file
207 by preceeding it with an exclamation point ('!').
208 .SH EXAMPLES
209 To produce a picture showing the difference between pic1 and pic2:
210 .IP "" .2i
211 pcomb \-e 'ro=ri(1)\-ri(2);go=gi(1)\-gi(2);bo=bi(1)\-bi(2)' pic1 pic2 > diff
212 .PP
213 Or, more efficiently:
214 .IP "" .2i
215 pcomb pic1 \-s \-1 pic2 > diff
216 .PP
217 To precompute the gamma correction for a picture:
218 .IP "" .2i
219 pcomb \-e 'ro=ri(1)^.4;go=gi(1)^.4;bo=bi(1)^.4' inp.hdr > gam.hdr
220 .PP
221 To perform some special filtering:
222 .IP "" .2i
223 pcomb \-f myfilt.cal \-x xmax/2 \-y ymax/2 input.hdr > filtered.hdr
224 .PP
225 To make a picture of a dot:
226 .IP "" .2i
227 pcomb \-x 100 \-y 100 \-e 'ro=b;go=b;bo=b;b=if((x-50)^2+(y-50)^2\-25^2,0,1)' > dot
228 .SH ENVIRONMENT
229 RAYPATH the directories to check for auxiliary files.
230 .SH AUTHOR
231 Greg Ward
232 .SH "SEE ALSO"
233 getinfo(1), icalc(1), pcompos(1), pfilt(1), rcalc(1),
234 rmtxcomb(1), rmtxop(1), rpict(1)
