root/radiance/ray/doc/man/man1/pcomb.1
Revision: 1.12
Committed: Fri Mar 18 21:09:16 2022 UTC (3 years, 3 months ago) by greg
docs(pcomb, pcompos): Added remarks about EXPOSURE settings
1 .\" RCSid "$Id: pcomb.1,v 1.11 2018/05/04 23:56:49 greg Exp $"
2 .TH PCOMB 1 8/31/96 RADIANCE
3 .SH NAME
4 pcomb - combine RADIANCE pictures
5 .SH SYNOPSIS
6 .B pcomb
7 [
8 .B -h
9 ][
10 .B -w
11 ][
12 .B "\-x xres"
13 ][
14 .B "\-y yres"
15 ][
16 .B "\-f file"
17 ][
18 .B "\-e expr"
19 ]
20 [
21 [
22 .B -o
23 ][
24 .B "\-s factor"
25 ][
26 .B "\-c r g b"
27 ]
28 .B "input .."
29 ]
30 .SH DESCRIPTION
31 .I Pcomb
32 combines equal-sized RADIANCE pictures and sends the result to the
33 standard output.
34 By default, the result is just a linear combination of
35 the input pictures multiplied by
36 .I \-s
37 and
38 .I \-c
39 coefficients,
40 but an arbitrary mapping can be assigned with the
41 .I \-e
42 and
43 .I \-f
44 options.
45 The variable and function definitions in each
46 .I \-f source
47 file are read and compiled from the RADIANCE library where it is found.
48 Negative coefficients and functions are allowed, and
49 .I pcomb
50 will produce color values of zero where they would be negative.
51 .PP
52 The variables
53 .I ro,
54 .I go
55 and
56 .I bo
57 specify the red, green and blue output values, respectively.
58 Alternatively, the single variable
59 .I lo
60 can be used to specify a brightness value for black and white output.
61 The predefined functions
62 .I ri(n),
63 .I gi(n)
64 and
65 .I bi(n)
66 give the red, green and blue input values for
67 picture
68 .I n.
69 To access a pixel that is nearby the current one, these functions
70 also accept optional x and y offsets.
71 For example,
72 .I ri(3,-2,1)
73 would return the red component of the pixel from picture 3
74 that is left 2 and up 1 from the current position.
75 Although x offsets may be as large as width of the picture,
76 y offsets are limited to a small window (+/- 32 pixels) due to efficiency
77 considerations.
78 However, it is not usually necessary to worry about this problem --
79 if the requested offset is not available, the next best pixel is
80 returned instead.
81 .PP
82 For additional convenience, the function
83 .I li(n)
84 is defined as the input brightness for picture
85 .I n.
86 This function also accepts x and y offsets.
87 .PP
88 The constant
89 .I nfiles
90 gives the number of input files present,
91 and
92 .I WE
93 gives the white efficacy (lumens/brightness) for pixel values,
94 which may be used with the
95 .I \-o
96 option or the le(n) values to convert to absolute
97 photometric units (see below).
98 The variables
99 .I x
100 and
101 .I y
102 give the current output pixel location for use in
103 spatially dependent functions, the constants
104 .I xmax
105 and
106 .I ymax
107 give the input resolution, and the constants
108 .I xres
109 and
110 .I yres
111 give the output resolution (usually the same, but see below).
112 The constant functions
113 .I "re(n), ge(n), be(n),"
114 and
115 .I le(n)
116 give the exposure values for picture
117 .I n,
118 and
119 .I pa(n)
120 gives the corresponding pixel aspect ratio.
121 Exposure values will be set to 1.0 for inputs with the
122 .I \-o
123 option set.
124 Finally, for pictures with stored view parameters,
125 the functions
126 .I "Ox(n), Oy(n)"
127 and
128 .I Oz(n)
129 return the ray origin in world coordinates for the current pixel
130 in picture
131 .I n,
132 and
133 .I "Dx(n), Dy(n)"
134 and
135 .I Dz(n)
136 return the normalized ray direction.
137 In addition, the function
138 .I T(n)
139 returns the distance from the origin to the aft clipping plane
140 (or zero if there is no aft plane), and the function
141 .I S(n)
142 returns the solid angle of the current pixel in steradians
143 (always zero for parallel views).
144 If the current pixel is outside the view region,
145 .I T(n)
146 will return a negative value, and
147 .I S(n)
148 will return zero.
149 The first input picture with a view is assumed to correspond to the
150 view of the output picture, which is written into the header.
151 .PP
152 The
153 .I \-h
154 option may be used to reduce the information header size, which
155 can grow disproportionately after multiple runs of
156 .I pcomb
157 and/or
158 .I pcompos(1).
159 The
160 .I \-w
161 option can be used to suppress warning messages about invalid
162 calculations.
163 The
164 .I \-o
165 option indicates that original pixel values are to be used for the next
166 picture, undoing any previous exposure changes or color correction.
167 .PP
168 The
169 .I \-x
170 and
171 .I \-y
172 options can be used to specify the desired output resolution,
173 .I xres
174 and
175 .I yres,
176 and can be expressions involving other constants such as
177 .I xmax
178 and
179 .I ymax.
180 The constants
181 .I xres
182 and
183 .I yres
184 may also be specified in a file or expression.
185 The default output resolution is the same as the input resolution.
186 .PP
187 The
188 .I \-x
189 and
190 .I \-y
191 options must be present if there are no input files, when
192 the definitions of
193 .I ro,
194 .I go
195 and
196 .I bo
197 will be used to compute each output pixel.
198 This is useful for producing simple test pictures for various
199 purposes.
200 (Theoretically, one could write a complete renderer using just the
201 functional language...)
202 .PP
203 The standard input can be specified with a hyphen ('-').
204 A command that produces a RADIANCE picture can be given in place of a file
205 by preceeding it with an exclamation point ('!').
206 .SH EXAMPLES
207 To produce a picture showing the difference between pic1 and pic2:
208 .IP "" .2i
209 pcomb \-e 'ro=ri(1)\-ri(2);go=gi(1)\-gi(2);bo=bi(1)\-bi(2)' pic1 pic2 > diff
210 .PP
211 Or, more efficiently:
212 .IP "" .2i
213 pcomb pic1 \-s \-1 pic2 > diff
214 .PP
215 To precompute the gamma correction for a picture:
216 .IP "" .2i
217 pcomb \-e 'ro=ri(1)^.4;go=gi(1)^.4;bo=bi(1)^.4' inp.hdr > gam.hdr
218 .PP
219 To perform some special filtering:
220 .IP "" .2i
221 pcomb \-f myfilt.cal \-x xmax/2 \-y ymax/2 input.hdr > filtered.hdr
222 .PP
223 To make a picture of a dot:
224 .IP "" .2i
225 pcomb \-x 100 \-y 100 \-e 'ro=b;go=b;bo=b;b=if((x-50)^2+(y-50)^2\-25^2,0,1)' > dot
226 .SH ENVIRONMENT
227 RAYPATH the directories to check for auxiliary files.
228 .SH AUTHOR
229 Greg Ward
230 .SH "SEE ALSO"
231 getinfo(1), icalc(1), pcompos(1), pfilt(1), rpict(1)
