root/radiance/ray/doc/man/man1/pabopto2xyz.1
Revision: 1.3
Committed: Fri Apr 11 20:54:38 2025 UTC (3 weeks, 1 day ago) by greg
Changes since 1.2: +9 -6 lines
docs(pabopto2xyz): Wording improvements
1 .\" RCSid "$Id: pabopto2xyz.1,v 1.2 2021/06/21 17:19:01 greg Exp $"
2 .TH PABOPTO2XYZ 1 3/1/2021 RADIANCE
3 .SH NAME
4 pabopto2xyz - convert a collection of single-channel BSDF measurements to CIE-XYZ colorimetry
5 .SH SYNOPSIS
6 .B pabopto2xyz
7 [
8 .B "\-m X1 X2 X3 Y1 Y2 Y3 Z1 Z2 Z3"
9 ][
10 .B "\-o basename"
11 ][
12 .B "\-n nprocs"
13 ]
14 .B "s1files.txt s2files.txt s3files.txt"
15 .SH DESCRIPTION
16 .I Pabopto2xyz
17 takes three sets of standard single-channel BSDF files, each
18 measured with a different light source and/or sensor filter to select
19 different wavelengths, combining them into an equivalent set of 3-channel BSDF data
20 files with CIE-XYZ colorimetry.
21 The 3x3 transform from the input file measurements to CIE XYZ color space is
22 set by the
23 .I \-m
24 option.
25 The default coefficients correspond to a specific set of filters in use at LBNL,
26 and are probably not applicable to any other instrument.
27 .PP
28 The
29 .I \-o
30 option is used to set the base output file name, which defaults to "pabopto_xyz".
31 To this base name, the theta and phi angles are added, along with a ".txt" suffix.
32 .PP
33 The
34 .I \-n
35 option may be supplied on Unix systems for multiple processes to speed up
36 the conversion.
37 .PP
38 The BSDF measurement file names must be listed in
39 the three required input files,
40 dileneated in each by white space.
41 File names or paths therein may not contain white space, and quoting/escaping
42 is not supported.
43 The same incident directions must be provided in all three measurement sets,
44 but may be broken into different files.
45 (I.e., two or more BSDF files may correspond to the same incident direction.)\0
46 Only one file will be produced for each incident direction in the output.
47 .PP
48 .I Pabopto2xyz
49 works by resampling the second and third input channels to correspond to the
50 exiting directions measured in the first channel.
51 A 2-D interpolant is applied at each incident direction for channels 2 and 3,
52 the given 3x3 matrix is applied,
53 and a combined virtual measurement is produced in output files beginning with
54 the given base name.
55 For this reason, it is often preferably to place the "green" or "near-Y"
56 channel first.
57 .PP
58 The combined data files produced by
59 .I pabopto2xyz
60 are subsequently passed to
61 .I pabopto2bsdf(1)
62 to produce a Scattering Interpolant Representation (SIR) file for further
63 processing.
64 .SH EXAMPLE
65 To combine three sets of measurements in a REC709 color space and produce
66 a CIE-XYZ file for pabopto2bsdf, which produces a color SIR file:
67 .IP "" .2i
68 pabopto2xyz -m .358 .412 .180 .715 .213 .072 .119 .019 .951 -o blinds_xyz filesG.txt filesR.txt filesB.txt
69 .br
70 pabopto2bsdf blinds_xyz*.txt > blinds_xyz.sir
71 .SH AUTHOR
72 Greg Ward
73 .SH "SEE ALSO"
74 bsdf2klems(1), bsdf2rad(1), bsdf2ttree(1), bsdfview(1), genBSDF(1),
75 pabopto2bsdf(1)
