| 1 |
greg |
1.11 |
.\" RCSid "$Id: pabopto2bsdf.1,v 1.10 2022/06/14 17:45:53 greg Exp $"
| 2 |
greg |
1.1 |
.TH PABOPTO2BSDF 1 2/24/2021 RADIANCE
| 3 |
.SH NAME
| 4 |
greg |
1.2 |
pabopto2bsdf - convert BSDF measurements to a scattering interpolant representation
| 5 |
greg |
1.1 |
.SH SYNOPSIS
| 6 |
.B pabopto2bsdf
| 7 |
| 8 |
.B \-t
| 9 |
| 10 |
.B "\-n nproc"
| 11 |
| 12 |
.B "\-s symmetry"
| 13 |
greg |
1.5 |
| 14 |
greg |
1.6 |
.B "\-g angle | 'A'"
| 15 |
greg |
1.1 |
| 16 |
.B "meas1 meas2 .."
| 17 |
.SH DESCRIPTION
| 18 |
.I Pabopto2bsdf
| 19 |
takes two or more pab-opto
| 20 |
.I Mountain
| 21 |
greg |
1.8 |
files, each nominally containing
| 22 |
different incident beam angles or sampling patterns,
| 23 |
and produces a Scattering Interpolant Representation (SIR)
| 24 |
greg |
1.1 |
on the standard output for further processing.
| 25 |
The binary SIR contains a Radial Basis Function fitting
| 26 |
each incident BSDF data file
| 27 |
greg |
1.8 |
and a "transport plan" matrix for each pair of neighboring RBF
| 28 |
greg |
1.1 |
directions in a spherical Delaunay mesh.
| 29 |
.PP
| 30 |
The SIR provides a complete 4-dimensional
| 31 |
BSDF description that may be resampled for other
| 32 |
formats such as Klems and tensor tree.
| 33 |
However, a separate run of
| 34 |
.I pabopto2bsdf
| 35 |
is needed to produce an SIR for each
| 36 |
incident and scattered hemisphere pair.
| 37 |
At most, there will be 4 such hemisphere pairs for
| 38 |
front reflection, back reflection, front transmission,
| 39 |
and back transmission.
| 40 |
Theoretically, only one transmission direction is required,
| 41 |
greg |
1.3 |
but it is often safest to measure both if they are to
| 42 |
greg |
1.2 |
be used in a simulation.
| 43 |
(See
| 44 |
greg |
1.1 |
.I bsdf2klems(1)
| 45 |
and
| 46 |
.I bsdf2ttree(1)
| 47 |
for details.
| 48 |
The
| 49 |
.I bsdf2rad(1)
| 50 |
and
| 51 |
.I bsdfview(1)
| 52 |
greg |
1.2 |
tools are also useful for visualizaing SIR and XML files.)
| 53 |
greg |
1.1 |
.PP
| 54 |
The
| 55 |
.I pabopto2bsdf
| 56 |
.I \-t
| 57 |
option reverses the assumed sample orientation front-to-back,
| 58 |
and is discussed below under the "#intheta" header entry.
| 59 |
greg |
1.9 |
.PP
| 60 |
greg |
1.1 |
Multi-processing may be used to accelerate the program
| 61 |
on systems that support it via the
| 62 |
.I \-n
| 63 |
option.
| 64 |
.PP
| 65 |
BSDF symmetry may be specified with the
| 66 |
.I \-s
| 67 |
option, which is one of "isotropic", "quadrilateral",
| 68 |
"bilateral", "up", or "anisotropic".
| 69 |
Any of these may be abbreviated with as little as a single
| 70 |
letter, and case is ignored.
| 71 |
.PP
| 72 |
Normally,
| 73 |
.I pabopto2bsdf
| 74 |
greg |
1.2 |
will assume a BSDF symmetry from the incident phi angles provided.
| 75 |
greg |
1.1 |
If every input data file uses the same incident phi angle, the
| 76 |
greg |
1.2 |
BSDF is assumed to be "isotropic", or rotationally symmetric.
| 77 |
greg |
1.1 |
If input phi angles only cover one quarter of the incident hemisphere,
| 78 |
then the sample is assumed to have quadrilateral symmetry.
| 79 |
Similarly, half-hemisphere coverage implies "bilateral" symmetry,
| 80 |
although it is also compatible with "up" symmetry, which must be specified
| 81 |
on the command line.
| 82 |
The difference is crucial.
| 83 |
Similar to quadrilateral symmetry, bilateral symmetry is "mirrored,"
| 84 |
meaning that the sample material looks identical when viewed in a mirror.
| 85 |
However, "up" symmetry means that the sample looks the same when
| 86 |
rotated by 180-degree (upside-down), but does not look the same in a mirror.
| 87 |
The "up" symmetry was a late addition, and involves rotating and copying the
| 88 |
input data, treating the result as anisotropic.
| 89 |
It is therefore less efficient, and should only be used when necessary.
| 90 |
greg |
1.2 |
Finally, if the incident hemisphere is fully covered, the final BSDF
| 91 |
is anisotropic.
| 92 |
greg |
1.1 |
.PP
| 93 |
If a
| 94 |
.I \-s
| 95 |
symmetry option is specified and it does not agree with the input
| 96 |
data provided, an error message is issued and no output is produced.
| 97 |
Note that only the "up" and "bilateral" symmetry options have
| 98 |
identical input coverage, so this is the only time the
| 99 |
.I \-s
| 100 |
greg |
1.2 |
option must be specified if the default mirroring is not appropriate.
| 101 |
greg |
1.1 |
.PP
| 102 |
greg |
1.5 |
If a
| 103 |
.I \-g
| 104 |
option is present, it will cull scattered measurements that are nearer
| 105 |
to grazing than the given angle in degrees.
| 106 |
If the word "auto" (which can be abbreviated as 'a' or 'A') is given
| 107 |
instead of an angle, then the near-grazing angle will be determined
| 108 |
by the lowest incident angle measurement present in the input data.
| 109 |
This is sometimes necessary to eliminate noise and edge effects that
| 110 |
some measurements exhibit near grazing.
| 111 |
.PP
| 112 |
greg |
1.1 |
The
| 113 |
.I Mountain
| 114 |
greg |
1.10 |
program, written by Peter Apian-Bennewitz, stores data taken by
| 115 |
his pg2 goniophotometer in separate
| 116 |
BSDF scattering files for each incident angle, beginning with a header
| 117 |
greg |
1.1 |
whose lines each start with a pound sign ('#').
| 118 |
Some header settings require colons and others do not, as indicated below.
| 119 |
The
| 120 |
.i pabopto2bsdf
| 121 |
program understands the following lines from each header and ignores
| 122 |
the rest:
| 123 |
.TP
| 124 |
.BR #sample_name
| 125 |
A double-quoted string containing the name associated with this sample.
| 126 |
greg |
1.7 |
If input files contain different sample names, the final sample name read
| 127 |
will be the one passed to the SIR output.
| 128 |
greg |
1.1 |
.TP
| 129 |
.BR #format:
| 130 |
The data format, typically one of "theta phi DSF" or "theta phi BSDF".
| 131 |
These differ only in their inclusion of a cosine factor.
| 132 |
The word "BRDF" or "BTDF" is accepted in place of "BSDF".
| 133 |
Any other specification or a format missing generates an error.
| 134 |
.TP
| 135 |
.BR #intheta
| 136 |
The incident theta (polar) angle in degrees, measured from the sample's
| 137 |
surface normal.
| 138 |
Theta values should be between 0 and 180, where values less than 90
| 139 |
are considered incident to the "front" side of the sample, and
| 140 |
theta values greater than 90 are incident to the "back" side in
| 141 |
the standard coordinate system.
| 142 |
greg |
1.2 |
Notions of "front" and "back" may be reversed using the
| 143 |
greg |
1.1 |
.I -t
| 144 |
option if desired.
| 145 |
.TP
| 146 |
.BR #inphi
| 147 |
The incident phi (azimuthal) angle in degrees counter-clockwise as
| 148 |
seen from the "front" side of the sample.
| 149 |
.TP
| 150 |
.BR #incident_angle
| 151 |
The incident theta and phi angles are each given in this header
| 152 |
line, offered as an alternative to separate "#intheta" and "#inphi"
| 153 |
angles.
| 154 |
The interpretation is the same as above.
| 155 |
.TP
| 156 |
.BR #upphi
| 157 |
If present, this phi angle that corresponds to
| 158 |
the sample "up" orientation.
| 159 |
greg |
1.2 |
By default, it is assumed to be 0, meaning that "up"
| 160 |
greg |
1.1 |
is phi=0.
| 161 |
To get the standard RADIANCE coordinates for BSDFs, "#upphi" should
| 162 |
greg |
1.2 |
be set to 90 (degrees).
| 163 |
greg |
1.1 |
.TP
| 164 |
.BR #colorimetry:
| 165 |
greg |
1.2 |
Two colorimetry values are currently understood: "CIE-Y" and "CIE-XYZ".
| 166 |
The default "CIE-Y" colorimetry
| 167 |
greg |
1.1 |
takes each DSF or BSDF value as photometric.
| 168 |
If "CIE-XYZ" is specified, then the DSF or BSDF values must be triplets
| 169 |
corresponding to CIE XYZ values.
| 170 |
Such files are typically produced by the
| 171 |
.I pabopto2xyz(1)
| 172 |
tool rather than
| 173 |
.I Mountain,
| 174 |
directly.
| 175 |
.PP
| 176 |
The BSDF scattering data follows the header in unspecified order,
| 177 |
where each line in the file
| 178 |
contains the scattered theta and phi angles measured in the same
| 179 |
coordinate system as incident theta and phi, followed by the DSF
| 180 |
or BSDF value, which may either be a single photometric quantity
| 181 |
for "CIE-Y" colorimetry or a triplet if the colorimetry is "CIE-XYZ".
| 182 |
A minimal incident BSDF data file might contain:
| 183 |
.sp
| 184 |
.nf
| 185 |
#incident_angle 82.5 180
| 186 |
#format: theta phi DSF
| 187 |
84.968 125.790 0.009744
| 188 |
84.889 125.610 0.007737
| 189 |
84.805 125.427 0.008569
| 190 |
| 191 |
.fi
| 192 |
.sp
| 193 |
The above header is equivalent to the more complete version below:
| 194 |
.sp
| 195 |
.nf
| 196 |
| 197 |
| 198 |
#intheta 82.5
| 199 |
#inphi 180
| 200 |
#upphi 0
| 201 |
#colorimetry: CIE-Y
| 202 |
| 203 |
| 204 |
| 205 |
| 206 |
.fi
| 207 |
.sp
| 208 |
The ordering of the header and data lines is unimportant,
| 209 |
but all header lines must precede all data lines in each input file.
| 210 |
.SH EXAMPLE
| 211 |
To generate an SIR file from a collection of transmission measurements
| 212 |
of a material with 180-degree symmetry using 4 processes:
| 213 |
.IP "" .2i
| 214 |
pabopto2bsdf -n 4 -s up f*_Tvis.txt > front_trans.sir
| 215 |
.PP
| 216 |
To combine this with front reflection measurements into a Klems BSDF file:
| 217 |
.IP "" .2i
| 218 |
pabopto2bsdf -n 4 -s up f*_Rvis.txt > front_refl.sir
| 219 |
.br
| 220 |
bsdf2klems front_trans.sir front_refl.sir > Klems_bsdf.xml
| 221 |
greg |
1.2 |
.SH NOTES
| 222 |
If the BSDF is being mirrored and there is no measured theta=0 incident
| 223 |
angle data file, this part of the distribution is filled in
| 224 |
by a special procedure.
| 225 |
This is important because there is no way to extrapolate missing
| 226 |
data at normal incidence.
| 227 |
.PP
| 228 |
The BSDF is extrapolated past the last measured theta angles towards
| 229 |
grazing using a constant value plus a single Gaussian lobe if one can
| 230 |
be reasonably fit to the near-grazing data.
| 231 |
This lobe will always be in the mirror direction in the case of
| 232 |
reflection, or the "through" direction in the case
| 233 |
of transmission.
| 234 |
The magnitude and width of this lobe is stored in the output header,
| 235 |
along with the constant value.
| 236 |
Both the lobe and the constant are neutral values, even with CIE-XYZ
| 237 |
colorimetry.
| 238 |
.PP
| 239 |
While there is no explicit handling of infrared or solar radiometry,
| 240 |
any single-channel BSDF will be created the same, and the final XML
| 241 |
file generated by
| 242 |
.I bsdf2klems
| 243 |
or
| 244 |
.I bsdf2ttree
| 245 |
can be edited to specify a different radiometry.
| 246 |
The interpolation process in
| 247 |
.I pabopto2bsdf
| 248 |
is not affected by this.
| 249 |
.PP
| 250 |
The standard BSDF coordinates in RADIANCE have the theta=0 direction
| 251 |
corresponding to the front-side surface normal.
| 252 |
The phi=0 direction points to the right as seen from the front, and
| 253 |
phi=90 degrees corresponds to the "up" orientation for the sample.
| 254 |
The same theta and phi are used for incoming and scattered angles,
| 255 |
so theta=180 is the opposite side surface normal.
| 256 |
This differs from the WINDOW, which use separate
| 257 |
coordinate systems for the front and the back.
| 258 |
greg |
1.11 |
To confuse things further, notions of "front" and "back" are
| 259 |
greg |
1.2 |
opposite in WINDOW and RADIANCE.
| 260 |
In RADIANCE, the normal of a window surface usually faces the
| 261 |
greg |
1.11 |
interior of a space, where the WINDOW convention uses "FRONT"
| 262 |
for the exterior of a building.
| 263 |
greg |
1.2 |
.PP
| 264 |
In the
| 265 |
.I genBSDF(1)
| 266 |
utility, the world coordinate system follows trigonometric
| 267 |
conventions with theta=0 aligning to the Z-axis,
| 268 |
the X-axis matches (theta,phi)=(90,0), and the Y-axis
| 269 |
greg |
1.4 |
corresponds to (theta,phi)=(90,90).
| 270 |
greg |
1.2 |
The latter is thought of as the "up" direction for the sample.
| 271 |
This usually needs to be rotated into position, since most
| 272 |
RADIANCE models use the Z-axis as the world "up" direction.
| 273 |
greg |
1.1 |
.SH AUTHOR
| 274 |
Greg Ward
| 275 |
.SH "SEE ALSO"
| 276 |
greg |
1.2 |
bsdf2klems(1), bsdf2rad(1), bsdf2ttree(1), bsdfview(1), genBSDF(1),
| 277 |
greg |
1.3 |
pabopto2xyz(1)
