root/radiance/ray/doc/man/man1/pabopto2bsdf.1
Revision: 1.10
Committed: Tue Jun 14 17:45:53 2022 UTC (2 years, 11 months ago) by greg
CVS Tags: rad5R4, HEAD
Changes since 1.9: +4 -4 lines
docs(pabopto2bsdf): Clarified Mountain and pg2 authorship
# User Rev Content
1 greg 1.10 .\" RCSid "$Id: pabopto2bsdf.1,v 1.9 2021/08/25 04:42:38 greg Exp $"
2 greg 1.1 .TH PABOPTO2BSDF 1 2/24/2021 RADIANCE
3     .SH NAME
4 greg 1.2 pabopto2bsdf - convert BSDF measurements to a scattering interpolant representation
5 greg 1.1 .SH SYNOPSIS
6     .B pabopto2bsdf
7     [
8     .B \-t
9     ][
10     .B "\-n nproc"
11     ][
12     .B "\-s symmetry"
13 greg 1.5 ][
14 greg 1.6 .B "\-g angle | 'A'"
15 greg 1.1 ]
16     .B "meas1 meas2 .."
17     .SH DESCRIPTION
18     .I Pabopto2bsdf
19     takes two or more pab-opto
20     .I Mountain
21 greg 1.8 files, each nominally containing
22     different incident beam angles or sampling patterns,
23     and produces a Scattering Interpolant Representation (SIR)
24 greg 1.1 on the standard output for further processing.
25     The binary SIR contains a Radial Basis Function fitting
26     each incident BSDF data file
27 greg 1.8 and a "transport plan" matrix for each pair of neighboring RBF
28 greg 1.1 directions in a spherical Delaunay mesh.
29     .PP
30     The SIR provides a complete 4-dimensional
31     BSDF description that may be resampled for other
32     formats such as Klems and tensor tree.
33     However, a separate run of
34     .I pabopto2bsdf
35     is needed to produce an SIR for each
36     incident and scattered hemisphere pair.
37     At most, there will be 4 such hemisphere pairs for
38     front reflection, back reflection, front transmission,
39     and back transmission.
40     Theoretically, only one transmission direction is required,
41 greg 1.3 but it is often safest to measure both if they are to
42 greg 1.2 be used in a simulation.
43     (See
44 greg 1.1 .I bsdf2klems(1)
45     and
46     .I bsdf2ttree(1)
47     for details.
48     The
49     .I bsdf2rad(1)
50     and
51     .I bsdfview(1)
52 greg 1.2 tools are also useful for visualizaing SIR and XML files.)
53 greg 1.1 .PP
54     The
55     .I pabopto2bsdf
56     .I \-t
57     option reverses the assumed sample orientation front-to-back,
58     and is discussed below under the "#intheta" header entry.
59 greg 1.9 .PP
60 greg 1.1 Multi-processing may be used to accelerate the program
61     on systems that support it via the
62     .I \-n
63     option.
64     .PP
65     BSDF symmetry may be specified with the
66     .I \-s
67     option, which is one of "isotropic", "quadrilateral",
68     "bilateral", "up", or "anisotropic".
69     Any of these may be abbreviated with as little as a single
70     letter, and case is ignored.
71     .PP
72     Normally,
73     .I pabopto2bsdf
74 greg 1.2 will assume a BSDF symmetry from the incident phi angles provided.
75 greg 1.1 If every input data file uses the same incident phi angle, the
76 greg 1.2 BSDF is assumed to be "isotropic", or rotationally symmetric.
77 greg 1.1 If input phi angles only cover one quarter of the incident hemisphere,
78     then the sample is assumed to have quadrilateral symmetry.
79     Similarly, half-hemisphere coverage implies "bilateral" symmetry,
80     although it is also compatible with "up" symmetry, which must be specified
81     on the command line.
82     The difference is crucial.
83     Similar to quadrilateral symmetry, bilateral symmetry is "mirrored,"
84     meaning that the sample material looks identical when viewed in a mirror.
85     However, "up" symmetry means that the sample looks the same when
86     rotated by 180-degree (upside-down), but does not look the same in a mirror.
87     The "up" symmetry was a late addition, and involves rotating and copying the
88     input data, treating the result as anisotropic.
89     It is therefore less efficient, and should only be used when necessary.
90 greg 1.2 Finally, if the incident hemisphere is fully covered, the final BSDF
91     is anisotropic.
92 greg 1.1 .PP
93     If a
94     .I \-s
95     symmetry option is specified and it does not agree with the input
96     data provided, an error message is issued and no output is produced.
97     Note that only the "up" and "bilateral" symmetry options have
98     identical input coverage, so this is the only time the
99     .I \-s
100 greg 1.2 option must be specified if the default mirroring is not appropriate.
101 greg 1.1 .PP
102 greg 1.5 If a
103     .I \-g
104     option is present, it will cull scattered measurements that are nearer
105     to grazing than the given angle in degrees.
106     If the word "auto" (which can be abbreviated as 'a' or 'A') is given
107     instead of an angle, then the near-grazing angle will be determined
108     by the lowest incident angle measurement present in the input data.
109     This is sometimes necessary to eliminate noise and edge effects that
110     some measurements exhibit near grazing.
111     .PP
112 greg 1.1 The
113     .I Mountain
114 greg 1.10 program, written by Peter Apian-Bennewitz, stores data taken by
115     his pg2 goniophotometer in separate
116     BSDF scattering files for each incident angle, beginning with a header
117 greg 1.1 whose lines each start with a pound sign ('#').
118     Some header settings require colons and others do not, as indicated below.
119     The
120     .i pabopto2bsdf
121     program understands the following lines from each header and ignores
122     the rest:
123     .TP
124     .BR #sample_name
125     A double-quoted string containing the name associated with this sample.
126 greg 1.7 If input files contain different sample names, the final sample name read
127     will be the one passed to the SIR output.
128 greg 1.1 .TP
129     .BR #format:
130     The data format, typically one of "theta phi DSF" or "theta phi BSDF".
131     These differ only in their inclusion of a cosine factor.
132     The word "BRDF" or "BTDF" is accepted in place of "BSDF".
133     Any other specification or a format missing generates an error.
134     .TP
135     .BR #intheta
136     The incident theta (polar) angle in degrees, measured from the sample's
137     surface normal.
138     Theta values should be between 0 and 180, where values less than 90
139     are considered incident to the "front" side of the sample, and
140     theta values greater than 90 are incident to the "back" side in
141     the standard coordinate system.
142 greg 1.2 Notions of "front" and "back" may be reversed using the
143 greg 1.1 .I -t
144     option if desired.
145     .TP
146     .BR #inphi
147     The incident phi (azimuthal) angle in degrees counter-clockwise as
148     seen from the "front" side of the sample.
149     .TP
150     .BR #incident_angle
151     The incident theta and phi angles are each given in this header
152     line, offered as an alternative to separate "#intheta" and "#inphi"
153     angles.
154     The interpretation is the same as above.
155     .TP
156     .BR #upphi
157     If present, this phi angle that corresponds to
158     the sample "up" orientation.
159 greg 1.2 By default, it is assumed to be 0, meaning that "up"
160 greg 1.1 is phi=0.
161     To get the standard RADIANCE coordinates for BSDFs, "#upphi" should
162 greg 1.2 be set to 90 (degrees).
163 greg 1.1 .TP
164     .BR #colorimetry:
165 greg 1.2 Two colorimetry values are currently understood: "CIE-Y" and "CIE-XYZ".
166     The default "CIE-Y" colorimetry
167 greg 1.1 takes each DSF or BSDF value as photometric.
168     If "CIE-XYZ" is specified, then the DSF or BSDF values must be triplets
169     corresponding to CIE XYZ values.
170     Such files are typically produced by the
171     .I pabopto2xyz(1)
172     tool rather than
173     .I Mountain,
174     directly.
175     .PP
176     The BSDF scattering data follows the header in unspecified order,
177     where each line in the file
178     contains the scattered theta and phi angles measured in the same
179     coordinate system as incident theta and phi, followed by the DSF
180     or BSDF value, which may either be a single photometric quantity
181     for "CIE-Y" colorimetry or a triplet if the colorimetry is "CIE-XYZ".
182     A minimal incident BSDF data file might contain:
183     .sp
184     .nf
185     #incident_angle 82.5 180
186     #format: theta phi DSF
187     84.968 125.790 0.009744
188     84.889 125.610 0.007737
189     84.805 125.427 0.008569
190     ...
191     .fi
192     .sp
193     The above header is equivalent to the more complete version below:
194     .sp
195     .nf
196     #format: theta phi DSF
197     #incident_angle 82.5 180
198     #intheta 82.5
199     #inphi 180
200     #upphi 0
201     #colorimetry: CIE-Y
202     84.968 125.790 0.009744
203     84.889 125.610 0.007737
204     84.805 125.427 0.008569
205     ...
206     .fi
207     .sp
208     The ordering of the header and data lines is unimportant,
209     but all header lines must precede all data lines in each input file.
210     .SH EXAMPLE
211     To generate an SIR file from a collection of transmission measurements
212     of a material with 180-degree symmetry using 4 processes:
213     .IP "" .2i
214     pabopto2bsdf -n 4 -s up f*_Tvis.txt > front_trans.sir
215     .PP
216     To combine this with front reflection measurements into a Klems BSDF file:
217     .IP "" .2i
218     pabopto2bsdf -n 4 -s up f*_Rvis.txt > front_refl.sir
219     .br
220     bsdf2klems front_trans.sir front_refl.sir > Klems_bsdf.xml
221 greg 1.2 .SH NOTES
222     If the BSDF is being mirrored and there is no measured theta=0 incident
223     angle data file, this part of the distribution is filled in
224     by a special procedure.
225     This is important because there is no way to extrapolate missing
226     data at normal incidence.
227     .PP
228     The BSDF is extrapolated past the last measured theta angles towards
229     grazing using a constant value plus a single Gaussian lobe if one can
230     be reasonably fit to the near-grazing data.
231     This lobe will always be in the mirror direction in the case of
232     reflection, or the "through" direction in the case
233     of transmission.
234     The magnitude and width of this lobe is stored in the output header,
235     along with the constant value.
236     Both the lobe and the constant are neutral values, even with CIE-XYZ
237     colorimetry.
238     .PP
239     While there is no explicit handling of infrared or solar radiometry,
240     any single-channel BSDF will be created the same, and the final XML
241     file generated by
242     .I bsdf2klems
243     or
244     .I bsdf2ttree
245     can be edited to specify a different radiometry.
246     The interpolation process in
247     .I pabopto2bsdf
248     is not affected by this.
249     .PP
250     The standard BSDF coordinates in RADIANCE have the theta=0 direction
251     corresponding to the front-side surface normal.
252     The phi=0 direction points to the right as seen from the front, and
253     phi=90 degrees corresponds to the "up" orientation for the sample.
254     The same theta and phi are used for incoming and scattered angles,
255     so theta=180 is the opposite side surface normal.
256     This differs from the WINDOW, which use separate
257     coordinate systems for the front and the back.
258     To confusing things further, notions of "front" and "back" are
259     opposite in WINDOW and RADIANCE.
260     In RADIANCE, the normal of a window surface usually faces the
261     interior of a space.
262     .PP
263     In the
264     .I genBSDF(1)
265     utility, the world coordinate system follows trigonometric
266     conventions with theta=0 aligning to the Z-axis,
267     the X-axis matches (theta,phi)=(90,0), and the Y-axis
268 greg 1.4 corresponds to (theta,phi)=(90,90).
269 greg 1.2 The latter is thought of as the "up" direction for the sample.
270     This usually needs to be rotated into position, since most
271     RADIANCE models use the Z-axis as the world "up" direction.
272 greg 1.1 .SH AUTHOR
273     Greg Ward
274     .SH "SEE ALSO"
275 greg 1.2 bsdf2klems(1), bsdf2rad(1), bsdf2ttree(1), bsdfview(1), genBSDF(1),
276 greg 1.3 pabopto2xyz(1)
