root/radiance/ray/doc/man/man1/pabopto2bsdf.1
Revision: 1.4
Committed: Fri Mar 26 19:48:22 2021 UTC (4 years, 2 months ago) by greg
docs: fixed typo
1 .\" RCSid "$Id: pabopto2bsdf.1,v 1.3 2021/03/03 19:14:51 greg Exp $"
2 .TH PABOPTO2BSDF 1 2/24/2021 RADIANCE
3 .SH NAME
4 pabopto2bsdf - convert BSDF measurements to a scattering interpolant representation
5 .SH SYNOPSIS
6 .B pabopto2bsdf
7 [
8 .B \-t
9 ][
10 .B "\-n nproc"
11 ][
12 .B "\-s symmetry"
13 ]
14 .B "meas1 meas2 .."
15 .SH DESCRIPTION
16 .I Pabopto2bsdf
17 takes two or more pab-opto
18 .I Mountain
19 files, each corresponding
20 to a different incident beam angle, and produces a
21 Scattering Interpolant Representation (SIR)
22 on the standard output for further processing.
23 The binary SIR contains a Radial Basis Function fitting
24 each incident BSDF data file
25 and a "transport plan" between neighboring RBF
26 directions in a spherical Delaunay mesh.
27 .PP
28 The SIR provides a complete 4-dimensional
29 BSDF description that may be resampled for other
30 formats such as Klems and tensor tree.
31 However, a separate run of
32 .I pabopto2bsdf
33 is needed to produce an SIR for each
34 incident and scattered hemisphere pair.
35 At most, there will be 4 such hemisphere pairs for
36 front reflection, back reflection, front transmission,
37 and back transmission.
38 Theoretically, only one transmission direction is required,
39 but it is often safest to measure both if they are to
40 be used in a simulation.
41 (See
42 .I bsdf2klems(1)
43 and
44 .I bsdf2ttree(1)
45 for details.
46 The
47 .I bsdf2rad(1)
48 and
49 .I bsdfview(1)
50 tools are also useful for visualizaing SIR and XML files.)
51 .PP
52 The
53 .I pabopto2bsdf
54 .I \-t
55 option reverses the assumed sample orientation front-to-back,
56 and is discussed below under the "#intheta" header entry.
57 Multi-processing may be used to accelerate the program
58 on systems that support it via the
59 .I \-n
60 option.
61 .PP
62 BSDF symmetry may be specified with the
63 .I \-s
64 option, which is one of "isotropic", "quadrilateral",
65 "bilateral", "up", or "anisotropic".
66 Any of these may be abbreviated with as little as a single
67 letter, and case is ignored.
68 .PP
69 Normally,
70 .I pabopto2bsdf
71 will assume a BSDF symmetry from the incident phi angles provided.
72 If every input data file uses the same incident phi angle, the
73 BSDF is assumed to be "isotropic", or rotationally symmetric.
74 If input phi angles only cover one quarter of the incident hemisphere,
75 then the sample is assumed to have quadrilateral symmetry.
76 Similarly, half-hemisphere coverage implies "bilateral" symmetry,
77 although it is also compatible with "up" symmetry, which must be specified
78 on the command line.
79 The difference is crucial.
80 Similar to quadrilateral symmetry, bilateral symmetry is "mirrored,"
81 meaning that the sample material looks identical when viewed in a mirror.
82 However, "up" symmetry means that the sample looks the same when
83 rotated by 180-degree (upside-down), but does not look the same in a mirror.
84 The "up" symmetry was a late addition, and involves rotating and copying the
85 input data, treating the result as anisotropic.
86 It is therefore less efficient, and should only be used when necessary.
87 Finally, if the incident hemisphere is fully covered, the final BSDF
88 is anisotropic.
89 .PP
90 If a
91 .I \-s
92 symmetry option is specified and it does not agree with the input
93 data provided, an error message is issued and no output is produced.
94 Note that only the "up" and "bilateral" symmetry options have
95 identical input coverage, so this is the only time the
96 .I \-s
97 option must be specified if the default mirroring is not appropriate.
98 .PP
99 The
100 .I Mountain
101 software operates the pg2 goniophotometer to
102 capture BSDF scattering data in separate text files for each incident
103 angle, beginning with a header
104 whose lines each start with a pound sign ('#').
105 Some header settings require colons and others do not, as indicated below.
106 The
107 .i pabopto2bsdf
108 program understands the following lines from each header and ignores
109 the rest:
110 .TP
111 .BR #sample_name
112 A double-quoted string containing the name associated with this sample.
113 If input files contain different sample names, the one read
114 will be the sample name passed to the SIR output.
115 .TP
116 .BR #format:
117 The data format, typically one of "theta phi DSF" or "theta phi BSDF".
118 These differ only in their inclusion of a cosine factor.
119 The word "BRDF" or "BTDF" is accepted in place of "BSDF".
120 Any other specification or a format missing generates an error.
121 .TP
122 .BR #intheta
123 The incident theta (polar) angle in degrees, measured from the sample's
124 surface normal.
125 Theta values should be between 0 and 180, where values less than 90
126 are considered incident to the "front" side of the sample, and
127 theta values greater than 90 are incident to the "back" side in
128 the standard coordinate system.
129 Notions of "front" and "back" may be reversed using the
130 .I -t
131 option if desired.
132 .TP
133 .BR #inphi
134 The incident phi (azimuthal) angle in degrees counter-clockwise as
135 seen from the "front" side of the sample.
136 .TP
137 .BR #incident_angle
138 The incident theta and phi angles are each given in this header
139 line, offered as an alternative to separate "#intheta" and "#inphi"
140 angles.
141 The interpretation is the same as above.
142 .TP
143 .BR #upphi
144 If present, this phi angle that corresponds to
145 the sample "up" orientation.
146 By default, it is assumed to be 0, meaning that "up"
147 is phi=0.
148 To get the standard RADIANCE coordinates for BSDFs, "#upphi" should
149 be set to 90 (degrees).
150 .TP
151 .BR #colorimetry:
152 Two colorimetry values are currently understood: "CIE-Y" and "CIE-XYZ".
153 The default "CIE-Y" colorimetry
154 takes each DSF or BSDF value as photometric.
155 If "CIE-XYZ" is specified, then the DSF or BSDF values must be triplets
156 corresponding to CIE XYZ values.
157 Such files are typically produced by the
158 .I pabopto2xyz(1)
159 tool rather than
160 .I Mountain,
161 directly.
162 .PP
163 The BSDF scattering data follows the header in unspecified order,
164 where each line in the file
165 contains the scattered theta and phi angles measured in the same
166 coordinate system as incident theta and phi, followed by the DSF
167 or BSDF value, which may either be a single photometric quantity
168 for "CIE-Y" colorimetry or a triplet if the colorimetry is "CIE-XYZ".
169 A minimal incident BSDF data file might contain:
170 .sp
171 .nf
172 #incident_angle 82.5 180
173 #format: theta phi DSF
174 84.968 125.790 0.009744
175 84.889 125.610 0.007737
176 84.805 125.427 0.008569
177 ...
178 .fi
179 .sp
180 The above header is equivalent to the more complete version below:
181 .sp
182 .nf
183 #format: theta phi DSF
184 #incident_angle 82.5 180
185 #intheta 82.5
186 #inphi 180
187 #upphi 0
188 #colorimetry: CIE-Y
189 84.968 125.790 0.009744
190 84.889 125.610 0.007737
191 84.805 125.427 0.008569
192 ...
193 .fi
194 .sp
195 The ordering of the header and data lines is unimportant,
196 but all header lines must precede all data lines in each input file.
197 .SH EXAMPLE
198 To generate an SIR file from a collection of transmission measurements
199 of a material with 180-degree symmetry using 4 processes:
200 .IP "" .2i
201 pabopto2bsdf -n 4 -s up f*_Tvis.txt > front_trans.sir
202 .PP
203 To combine this with front reflection measurements into a Klems BSDF file:
204 .IP "" .2i
205 pabopto2bsdf -n 4 -s up f*_Rvis.txt > front_refl.sir
206 .br
207 bsdf2klems front_trans.sir front_refl.sir > Klems_bsdf.xml
208 .SH NOTES
209 If the BSDF is being mirrored and there is no measured theta=0 incident
210 angle data file, this part of the distribution is filled in
211 by a special procedure.
212 This is important because there is no way to extrapolate missing
213 data at normal incidence.
214 .PP
215 The BSDF is extrapolated past the last measured theta angles towards
216 grazing using a constant value plus a single Gaussian lobe if one can
217 be reasonably fit to the near-grazing data.
218 This lobe will always be in the mirror direction in the case of
219 reflection, or the "through" direction in the case
220 of transmission.
221 The magnitude and width of this lobe is stored in the output header,
222 along with the constant value.
223 Both the lobe and the constant are neutral values, even with CIE-XYZ
224 colorimetry.
225 .PP
226 While there is no explicit handling of infrared or solar radiometry,
227 any single-channel BSDF will be created the same, and the final XML
228 file generated by
229 .I bsdf2klems
230 or
231 .I bsdf2ttree
232 can be edited to specify a different radiometry.
233 The interpolation process in
234 .I pabopto2bsdf
235 is not affected by this.
236 .PP
237 The standard BSDF coordinates in RADIANCE have the theta=0 direction
238 corresponding to the front-side surface normal.
239 The phi=0 direction points to the right as seen from the front, and
240 phi=90 degrees corresponds to the "up" orientation for the sample.
241 The same theta and phi are used for incoming and scattered angles,
242 so theta=180 is the opposite side surface normal.
243 This differs from the WINDOW, which use separate
244 coordinate systems for the front and the back.
245 To confusing things further, notions of "front" and "back" are
246 opposite in WINDOW and RADIANCE.
247 In RADIANCE, the normal of a window surface usually faces the
248 interior of a space.
249 .PP
250 In the
251 .I genBSDF(1)
252 utility, the world coordinate system follows trigonometric
253 conventions with theta=0 aligning to the Z-axis,
254 the X-axis matches (theta,phi)=(90,0), and the Y-axis
255 corresponds to (theta,phi)=(90,90).
256 The latter is thought of as the "up" direction for the sample.
257 This usually needs to be rotated into position, since most
258 RADIANCE models use the Z-axis as the world "up" direction.
259 .SH AUTHOR
260 Greg Ward
261 .SH "SEE ALSO"
262 bsdf2klems(1), bsdf2rad(1), bsdf2ttree(1), bsdfview(1), genBSDF(1),
263 pabopto2xyz(1)
