1 |
.\" RCSid "$Id: pabopto2bsdf.1,v 1.2 2021/02/25 19:31:36 greg Exp $" |
2 |
.TH PABOPTO2BSDF 1 2/24/2021 RADIANCE |
3 |
.SH NAME |
4 |
pabopto2bsdf - convert BSDF measurements to a scattering interpolant representation |
5 |
.SH SYNOPSIS |
6 |
.B pabopto2bsdf |
7 |
8 |
.B \-t |
9 |
10 |
.B "\-n nproc" |
11 |
12 |
.B "\-s symmetry" |
13 |
14 |
.B "meas1 meas2 .." |
15 |
.SH DESCRIPTION |
16 |
.I Pabopto2bsdf |
17 |
takes two or more pab-opto |
18 |
.I Mountain |
19 |
files, each corresponding |
20 |
to a different incident beam angle, and produces a |
21 |
Scattering Interpolant Representation (SIR) |
22 |
on the standard output for further processing. |
23 |
The binary SIR contains a Radial Basis Function fitting |
24 |
each incident BSDF data file |
25 |
and a "transport plan" between neighboring RBF |
26 |
directions in a spherical Delaunay mesh. |
27 |
.PP |
28 |
The SIR provides a complete 4-dimensional |
29 |
BSDF description that may be resampled for other |
30 |
formats such as Klems and tensor tree. |
31 |
However, a separate run of |
32 |
.I pabopto2bsdf |
33 |
is needed to produce an SIR for each |
34 |
incident and scattered hemisphere pair. |
35 |
At most, there will be 4 such hemisphere pairs for |
36 |
front reflection, back reflection, front transmission, |
37 |
and back transmission. |
38 |
Theoretically, only one transmission direction is required, |
39 |
but it is often safest to measure both if they are to |
40 |
be used in a simulation. |
41 |
(See |
42 |
.I bsdf2klems(1) |
43 |
and |
44 |
.I bsdf2ttree(1) |
45 |
for details. |
46 |
The |
47 |
.I bsdf2rad(1) |
48 |
and |
49 |
.I bsdfview(1) |
50 |
tools are also useful for visualizaing SIR and XML files.) |
51 |
.PP |
52 |
The |
53 |
.I pabopto2bsdf |
54 |
.I \-t |
55 |
option reverses the assumed sample orientation front-to-back, |
56 |
and is discussed below under the "#intheta" header entry. |
57 |
Multi-processing may be used to accelerate the program |
58 |
on systems that support it via the |
59 |
.I \-n |
60 |
option. |
61 |
.PP |
62 |
BSDF symmetry may be specified with the |
63 |
.I \-s |
64 |
option, which is one of "isotropic", "quadrilateral", |
65 |
"bilateral", "up", or "anisotropic". |
66 |
Any of these may be abbreviated with as little as a single |
67 |
letter, and case is ignored. |
68 |
.PP |
69 |
Normally, |
70 |
.I pabopto2bsdf |
71 |
will assume a BSDF symmetry from the incident phi angles provided. |
72 |
If every input data file uses the same incident phi angle, the |
73 |
BSDF is assumed to be "isotropic", or rotationally symmetric. |
74 |
If input phi angles only cover one quarter of the incident hemisphere, |
75 |
then the sample is assumed to have quadrilateral symmetry. |
76 |
Similarly, half-hemisphere coverage implies "bilateral" symmetry, |
77 |
although it is also compatible with "up" symmetry, which must be specified |
78 |
on the command line. |
79 |
The difference is crucial. |
80 |
Similar to quadrilateral symmetry, bilateral symmetry is "mirrored," |
81 |
meaning that the sample material looks identical when viewed in a mirror. |
82 |
However, "up" symmetry means that the sample looks the same when |
83 |
rotated by 180-degree (upside-down), but does not look the same in a mirror. |
84 |
The "up" symmetry was a late addition, and involves rotating and copying the |
85 |
input data, treating the result as anisotropic. |
86 |
It is therefore less efficient, and should only be used when necessary. |
87 |
Finally, if the incident hemisphere is fully covered, the final BSDF |
88 |
is anisotropic. |
89 |
.PP |
90 |
If a |
91 |
.I \-s |
92 |
symmetry option is specified and it does not agree with the input |
93 |
data provided, an error message is issued and no output is produced. |
94 |
Note that only the "up" and "bilateral" symmetry options have |
95 |
identical input coverage, so this is the only time the |
96 |
.I \-s |
97 |
option must be specified if the default mirroring is not appropriate. |
98 |
.PP |
99 |
The |
100 |
.I Mountain |
101 |
software operates the pg2 goniophotometer to |
102 |
capture BSDF scattering data in separate text files for each incident |
103 |
angle, beginning with a header |
104 |
whose lines each start with a pound sign ('#'). |
105 |
Some header settings require colons and others do not, as indicated below. |
106 |
The |
107 |
.i pabopto2bsdf |
108 |
program understands the following lines from each header and ignores |
109 |
the rest: |
110 |
.TP |
111 |
.BR #sample_name |
112 |
A double-quoted string containing the name associated with this sample. |
113 |
If input files contain different sample names, the one read |
114 |
will be the sample name passed to the SIR output. |
115 |
.TP |
116 |
.BR #format: |
117 |
The data format, typically one of "theta phi DSF" or "theta phi BSDF". |
118 |
These differ only in their inclusion of a cosine factor. |
119 |
The word "BRDF" or "BTDF" is accepted in place of "BSDF". |
120 |
Any other specification or a format missing generates an error. |
121 |
.TP |
122 |
.BR #intheta |
123 |
The incident theta (polar) angle in degrees, measured from the sample's |
124 |
surface normal. |
125 |
Theta values should be between 0 and 180, where values less than 90 |
126 |
are considered incident to the "front" side of the sample, and |
127 |
theta values greater than 90 are incident to the "back" side in |
128 |
the standard coordinate system. |
129 |
Notions of "front" and "back" may be reversed using the |
130 |
.I -t |
131 |
option if desired. |
132 |
.TP |
133 |
.BR #inphi |
134 |
The incident phi (azimuthal) angle in degrees counter-clockwise as |
135 |
seen from the "front" side of the sample. |
136 |
.TP |
137 |
.BR #incident_angle |
138 |
The incident theta and phi angles are each given in this header |
139 |
line, offered as an alternative to separate "#intheta" and "#inphi" |
140 |
angles. |
141 |
The interpretation is the same as above. |
142 |
.TP |
143 |
.BR #upphi |
144 |
If present, this phi angle that corresponds to |
145 |
the sample "up" orientation. |
146 |
By default, it is assumed to be 0, meaning that "up" |
147 |
is phi=0. |
148 |
To get the standard RADIANCE coordinates for BSDFs, "#upphi" should |
149 |
be set to 90 (degrees). |
150 |
.TP |
151 |
.BR #colorimetry: |
152 |
Two colorimetry values are currently understood: "CIE-Y" and "CIE-XYZ". |
153 |
The default "CIE-Y" colorimetry |
154 |
takes each DSF or BSDF value as photometric. |
155 |
If "CIE-XYZ" is specified, then the DSF or BSDF values must be triplets |
156 |
corresponding to CIE XYZ values. |
157 |
Such files are typically produced by the |
158 |
.I pabopto2xyz(1) |
159 |
tool rather than |
160 |
.I Mountain, |
161 |
directly. |
162 |
.PP |
163 |
The BSDF scattering data follows the header in unspecified order, |
164 |
where each line in the file |
165 |
contains the scattered theta and phi angles measured in the same |
166 |
coordinate system as incident theta and phi, followed by the DSF |
167 |
or BSDF value, which may either be a single photometric quantity |
168 |
for "CIE-Y" colorimetry or a triplet if the colorimetry is "CIE-XYZ". |
169 |
A minimal incident BSDF data file might contain: |
170 |
.sp |
171 |
.nf |
172 |
#incident_angle 82.5 180 |
173 |
#format: theta phi DSF |
174 |
84.968 125.790 0.009744 |
175 |
84.889 125.610 0.007737 |
176 |
84.805 125.427 0.008569 |
177 |
178 |
.fi |
179 |
.sp |
180 |
The above header is equivalent to the more complete version below: |
181 |
.sp |
182 |
.nf |
183 |
184 |
185 |
#intheta 82.5 |
186 |
#inphi 180 |
187 |
#upphi 0 |
188 |
#colorimetry: CIE-Y |
189 |
190 |
191 |
192 |
193 |
.fi |
194 |
.sp |
195 |
The ordering of the header and data lines is unimportant, |
196 |
but all header lines must precede all data lines in each input file. |
197 |
.SH EXAMPLE |
198 |
To generate an SIR file from a collection of transmission measurements |
199 |
of a material with 180-degree symmetry using 4 processes: |
200 |
.IP "" .2i |
201 |
pabopto2bsdf -n 4 -s up f*_Tvis.txt > front_trans.sir |
202 |
.PP |
203 |
To combine this with front reflection measurements into a Klems BSDF file: |
204 |
.IP "" .2i |
205 |
pabopto2bsdf -n 4 -s up f*_Rvis.txt > front_refl.sir |
206 |
.br |
207 |
bsdf2klems front_trans.sir front_refl.sir > Klems_bsdf.xml |
208 |
.SH NOTES |
209 |
If the BSDF is being mirrored and there is no measured theta=0 incident |
210 |
angle data file, this part of the distribution is filled in |
211 |
by a special procedure. |
212 |
This is important because there is no way to extrapolate missing |
213 |
data at normal incidence. |
214 |
.PP |
215 |
The BSDF is extrapolated past the last measured theta angles towards |
216 |
grazing using a constant value plus a single Gaussian lobe if one can |
217 |
be reasonably fit to the near-grazing data. |
218 |
This lobe will always be in the mirror direction in the case of |
219 |
reflection, or the "through" direction in the case |
220 |
of transmission. |
221 |
The magnitude and width of this lobe is stored in the output header, |
222 |
along with the constant value. |
223 |
Both the lobe and the constant are neutral values, even with CIE-XYZ |
224 |
colorimetry. |
225 |
.PP |
226 |
While there is no explicit handling of infrared or solar radiometry, |
227 |
any single-channel BSDF will be created the same, and the final XML |
228 |
file generated by |
229 |
.I bsdf2klems |
230 |
or |
231 |
.I bsdf2ttree |
232 |
can be edited to specify a different radiometry. |
233 |
The interpolation process in |
234 |
.I pabopto2bsdf |
235 |
is not affected by this. |
236 |
.PP |
237 |
The standard BSDF coordinates in RADIANCE have the theta=0 direction |
238 |
corresponding to the front-side surface normal. |
239 |
The phi=0 direction points to the right as seen from the front, and |
240 |
phi=90 degrees corresponds to the "up" orientation for the sample. |
241 |
The same theta and phi are used for incoming and scattered angles, |
242 |
so theta=180 is the opposite side surface normal. |
243 |
This differs from the WINDOW, which use separate |
244 |
coordinate systems for the front and the back. |
245 |
To confusing things further, notions of "front" and "back" are |
246 |
opposite in WINDOW and RADIANCE. |
247 |
In RADIANCE, the normal of a window surface usually faces the |
248 |
interior of a space. |
249 |
.PP |
250 |
In the |
251 |
.I genBSDF(1) |
252 |
utility, the world coordinate system follows trigonometric |
253 |
conventions with theta=0 aligning to the Z-axis, |
254 |
the X-axis matches (theta,phi)=(90,0), and the Y-axis |
255 |
is has (theta,phi)=(90,90). |
256 |
The latter is thought of as the "up" direction for the sample. |
257 |
This usually needs to be rotated into position, since most |
258 |
RADIANCE models use the Z-axis as the world "up" direction. |
259 |
.SH AUTHOR |
260 |
Greg Ward |
261 |
.SH "SEE ALSO" |
262 |
bsdf2klems(1), bsdf2rad(1), bsdf2ttree(1), bsdfview(1), genBSDF(1), |
263 |
pabopto2xyz(1) |
