--- ray/doc/man/man1/oconv.1 2003/03/11 22:48:20 1.2 +++ ray/doc/man/man1/oconv.1 2004/04/21 15:01:46 1.7 @@ -1,4 +1,4 @@ -.\" RCSid "$Id" +.\" RCSid "$Id: oconv.1,v 1.7 2004/04/21 15:01:46 greg Exp $" .TH OCONV 1 8/15/95 RADIANCE .SH NAME oconv - create an octree from a RADIANCE scene description @@ -64,7 +64,7 @@ each voxel. Larger numbers result in quicker octree generation, but potentially slower rendering. Smaller values may or may not produce faster renderings, -since the default number (5) is close to optimal for most scenes. +since the default number (6) is close to optimal for most scenes. .PP The .I \-r @@ -72,7 +72,7 @@ option specifies the maximum octree resolution. This should be greater than or equal to the ratio of the largest and smallest dimensions in the scene (ie. surface size or distance between surfaces). -The default is 8192. +The default is 16384. .PP The .I \-f @@ -132,15 +132,15 @@ to xform(1) within files to create a hierarchy. .IP "Set overflow in addobject (id)" This error occurs when too many surfaces are close together in a scene. -Sometimes a dense scene can be accomodated by increasing -the maximum resolution (by powers of two) using the -.I \-r -option, but usually this error indicates something is wrong. Either too many surfaces are lying right on top of each other, or the bounding cube is inflated from an oversized object or an improper .I \-b specification. +If hundreds of triangles come together at a common vertex, it may +not be possible to create an octree from the object. +This happens most often when inane CAD systems create spheres using +a polar tessellation. Chances are, the surface "id" is near one of those causing the problem. .IP "Hash table overflow in fullnode" This error is caused by too many surfaces. @@ -169,4 +169,4 @@ or can be used to automate octree creation and maintenance. .SH "SEE ALSO" getbbox(1), getinfo(1), make(1), obj2mesh(1), rad(1), -rpict(1), rview(1), rtrace(1), xform(1) +rpict(1), rvu(1), rtrace(1), xform(1)
