--- ray/doc/man/man1/oconv.1 2004/04/12 17:31:27 1.6 +++ ray/doc/man/man1/oconv.1 2007/09/04 17:36:40 1.8 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: oconv.1,v 1.6 2004/04/12 17:31:27 greg Exp $" +.\" RCSid "$Id: oconv.1,v 1.8 2007/09/04 17:36:40 greg Exp $" .TH OCONV 1 8/15/95 RADIANCE .SH NAME oconv - create an octree from a RADIANCE scene description @@ -109,7 +109,7 @@ Although the octree file format is binary, it is meant between machines. The only limitation is that machines with radically different integer sizes will not work together. -For the best results, the -f option should be used if an octree is +For the best results, the \-f option should be used if an octree is to be used in different environments. .SH DIAGNOSTICS There are four basic error types reported by oconv: @@ -140,7 +140,7 @@ specification. If hundreds of triangles come together at a common vertex, it may not be possible to create an octree from the object. This happens most often when inane CAD systems create spheres using -a polar tesselation. +a polar tessellation. Chances are, the surface "id" is near one of those causing the problem. .IP "Hash table overflow in fullnode" This error is caused by too many surfaces. @@ -152,7 +152,7 @@ option. To add book1, book2 and a transformed book3 to the octree ``scene.oct'': .IP "" .2i -oconv -i scene.oct book1 book2 '\\!xform -rz 30 book3' > newscene.oct +oconv \-i scene.oct book1 book2 '\\!xform \-rz 30 book3' > newscene.oct .SH AUTHOR Greg Ward .SH NOTES
