root/radiance/ray/doc/man/man1/oconv.1
Revision: 1.2
Committed: Tue Mar 11 22:48:20 2003 UTC (22 years, 4 months ago) by greg
1 .\" RCSid "$Id"
2 .TH OCONV 1 8/15/95 RADIANCE
3 .SH NAME
4 oconv - create an octree from a RADIANCE scene description
5 .SH SYNOPSIS
6 .B oconv
7 [
8 .B "\-i octree"
9 |
10 .B "\-b xmin ymin zmin size
11 ][
12 .B "\-n objlim"
13 ][
14 .B "\-r maxres"
15 ][
16 .B \-f
17 ][
18 .B \-w
19 ][
20 -
21 ]
22 [
23 .B "input .."
24 ]
25 .SH DESCRIPTION
26 .I Oconv
27 adds each scene description
28 .I input
29 to
30 .I octree
31 and sends the result to the standard output.
32 Each
33 .I input
34 can be either a file name, or a command (enclosed in quotes
35 and preceded by a `!').
36 Similarly, the octree input may be given as a command preceded
37 by a `!'.
38 If any of the surfaces will not fit in
39 .I octree,
40 an error message is printed and the program aborts.
41 If no
42 .I octree
43 is given, a new one is created large enough for
44 all of the surfaces.
45 .PP
46 The
47 .I \-b
48 option allows the user to give a bounding cube for the
49 scene, starting at
50 .I "xmin ymin zmin"
51 and having a side length
52 .I size.
53 If the cube does not contain all of the surfaces, an error results.
54 The
55 .I \-b
56 and
57 .I \-i
58 options are mutually exclusive.
59 .PP
60 The
61 .I \-n
62 option specifies the maximum surface set size for
63 each voxel.
64 Larger numbers result in quicker octree generation,
65 but potentially slower rendering.
66 Smaller values may or may not produce faster renderings,
67 since the default number (5) is close to optimal for most scenes.
68 .PP
69 The
70 .I \-r
71 option specifies the maximum octree resolution.
72 This should be greater than or equal to the ratio of the largest
73 and smallest dimensions in the scene (ie. surface size or distance between
74 surfaces).
75 The default is 8192.
76 .PP
77 The
78 .I \-f
79 option produces a frozen octree containing all the scene information.
80 Normally, only a reference to the scene files is stored in the
81 octree, and changes to those files may invalidate the result.
82 The freeze option is useful when the octree file's
83 integrity and loading speed is more important than its size, or
84 when the octree is to be relocated to another directory, and is
85 especially useful for creating library objects for the "instance"
86 primitive type.
87 If the input octree is frozen, the output will be also.
88 .PP
89 The
90 .I \-w
91 option suppresses warnings.
92 .PP
93 A hyphen by itself ('-') tells
94 .I oconv
95 to read scene data from its standard input.
96 This also implies the
97 .I \-f
98 option.
99 .PP
100 The only scene file changes that do not require octree regeneration are
101 modifications to non-surface parameters.
102 If the coordinates of a surface are changed, or any primitives are added
103 or deleted, oconv must be run again.
104 Programs will abort with a "stale octree" message
105 if they detect any dangerous inconsistencies between
106 the octree and the input files.
107 .PP
108 Although the octree file format is binary, it is meant to be portable
109 between machines.
110 The only limitation is that machines with radically different integer
111 sizes will not work together.
112 For the best results, the -f option should be used if an octree is
113 to be used in different environments.
114 .SH DIAGNOSTICS
115 There are four basic error types reported by oconv:
116 .IP
117 warning - a non-fatal input-related error
118 .IP
119 fatal - an unrecoverable input-related error
120 .IP
121 system - a system-related error
122 .IP
123 internal - a fatal error related to program limitations
124 .IP
125 consistency - a program-caused error
126 .PP
127 Most errors are self-explanatory.
128 However, the following internal errors should be mentioned:
129 .IP "Too many scene files"
130 Reduce the number of scene files by combining them or using calls
131 to xform(1) within files to create a hierarchy.
132 .IP "Set overflow in addobject (id)"
133 This error occurs when too many surfaces are close together in a
134 scene.
135 Sometimes a dense scene can be accomodated by increasing
136 the maximum resolution (by powers of two) using the
137 .I \-r
138 option, but usually this error indicates something is wrong.
139 Either too many surfaces are lying right on top of each other,
140 or the bounding cube is inflated from an oversized object
141 or an improper
142 .I \-b
143 specification.
144 Chances are, the surface "id" is near one of those causing the problem.
145 .IP "Hash table overflow in fullnode"
146 This error is caused by too many surfaces.
147 If it is possible to create an octree for the scene at all,
148 it will have to be done in stages using the
149 .I \-i
150 option.
151 .SH EXAMPLE
152 To add book1, book2 and a
153 transformed book3 to the octree ``scene.oct'':
154 .IP "" .2i
155 oconv -i scene.oct book1 book2 '\\!xform -rz 30 book3' > newscene.oct
156 .SH AUTHOR
157 Greg Ward
158 .SH NOTES
159 In the octree, the names of the scene files are stored rather
160 than the scene information.
161 This means that a new octree must be generated whenever the
162 scene files are changed or moved.
163 Also, an octree that has been moved to a new directory will not be able to find
164 scene files with relative pathnames.
165 The freeze option avoids these problems.
166 .I make(1)
167 or
168 .I rad(1)
169 can be used to automate octree creation and maintenance.
170 .SH "SEE ALSO"
171 getbbox(1), getinfo(1), make(1), obj2mesh(1), rad(1),
172 rpict(1), rview(1), rtrace(1), xform(1)
