root/radiance/ray/doc/man/man1/objview.1
Revision: 1.6
Committed: Fri Aug 11 21:39:52 2017 UTC (7 years, 10 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R1, rad5R3, HEAD
Changes since 1.5: +8 -5 lines
1 .\" RCSid "$Id: objview.1,v 1.5 2014/04/16 20:48:07 greg Exp $"
2 .TH OBJVIEW 1 6/10/98 RADIANCE
3 .SH NAME
4 objview - view RADIANCE object(s)
5 .SH SYNOPSIS
6 .B objview
7 [
8 .B "\-u updirection"
9 ][
10 rad options
11 ]
12 input ..
13 .br
14 .B objview
15 [
16 .B \-g
17 ][
18 .B "\-u updirection"
19 ][
20 glrad options
21 ]
22 input ..
23 .br
24 [
25 .B "\-n nprocs"
26 ]
27 input ..
28 .br
29 .SH DESCRIPTION
30 .I Objview
31 renders a RADIANCE object interactively using
32 .I rad(1)
33 or
34 .I glrad(1).
35 This program is merely a Perl script that adds some light
36 sources to a scene then calls
37 .I rad(1)
38 or
39 .I glrad(1)
40 to make an octree and view the scene interactively.
41 .PP
42 If the default up vector (+Z) is inappropriate
43 for this object, then specify a different one using the
44 .I \-u
45 option to
46 .I objview.
47 .PP
48 Any number of material and scene files may be given,
49 with no inputs causing
50 .I objview
51 to read a scene from its standard input.
52 .PP
53 The number of processors to use may be specified with the
54 .I \-n
55 option.
56 .SH AUTHOR(s)
57 Greg Ward (original), Axel Jacobs (Perl)
58 .SH "SEE ALSO"
59 glrad(1), oconv(1), rad(1), rvu(1)
